查看: 2034|回复: 7
字符串
发表于 2012-7-26 14:05:28 | 显示全部楼层 |阅读模式
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2012-7-26 14:59:23 | 显示全部楼层
解方多多
Ref:
vl-list->string
vl-string->list
vl-string-position
vl-string-search
发表于 2012-7-26 22:16:33 | 显示全部楼层
用 TeaScript ,很简单:
 楼主| 发表于 2012-7-27 11:14:44 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
 楼主| 发表于 2012-7-27 11:20:12 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2012-7-27 14:05:17 | 显示全部楼层
因为经常会用到,所以我我写了一个函数.晒出来,见笑了.与君共勉.
  1. ;;---------------------------------------将字符串按分隔符解析为表-------------------------------
  2. (defun hj:Str2List (string symble / #REV $STR %ID LEN)
  3.   (setq len (strlen string)
  4.         %id 1
  5.         #rev nil
  6.         $str "" )
  7.   (repeat len
  8.     (if (and (vl-string-search  (substr string %id 1) symble) (/= $str ""))
  9.       (setq #rev (append #rev (list $str))
  10.             $str "")
  11.       (if (not (vl-string-search (substr string %id 1) symble) )
  12.         (setq $str (strcat $str (substr string %id 1)))
  13.         )
  14.       )
  15.     (setq %id (1+ %id))
  16.     );_end repeat
  17.   (if (/= $str "") (append  #rev (list $str)) #rev)
  18.   )
执行效果如下:
_$ (setq b (hj:Str2List  "#1a@2ab#3abc@4abcd#5a@6a#"  "#"))
("1a@2ab" "3abc@4abcd" "5a@6a")
发表于 2012-7-27 14:20:10 | 显示全部楼层
;;按指定分割符将字符串分割成表=======================================================
  ;;  parser by CAB
  ;;Http://discussion.autodesk.com/f ... dID=759125&tstart=0
  ;;http://bbs.mjtd.com/forum.php?mo ... 24&page=1#pid422330
  (defun sparser (str delim / ptr lst)
    (while (setq ptr (vl-string-search delim str))
      (setq lst (cons (substr str 1 ptr) lst))
      (setq str (substr str (+ ptr 2)))
    (reverse (cons str lst))
发表于 2012-7-27 14:22:30 | 显示全部楼层
(sparser  "#1a@2ab#3abc@4abcd#5a@6a#"  "#")
("" "1a@2ab" "3abc@4abcd" "5a@6a" "")表里面有空字符串
GMT+8, 2025-5-10 17:18 , Processed in 0.201043 second(s), 30 queries , Gzip On.
