查看: 2327|回复: 2
哪位大虾给个读取EXCEL数据的模块
发表于 2003-8-17 09:22:00 | 显示全部楼层 |阅读模式
发表于 2004-8-6 17:06:00 | 显示全部楼层
我也需要这个,可是他们给的下面的这个没用 Private readexcel()
Dim ExcelApp As New Excel.Application
ExcelApp.Workbooks.Open "e:\lhs\cad\zksj.xls", , ReadOnly
Dim pt1(0 To 2) As Double, pt2(0 To 2) As Double
Dim Rad As Double
Dim i As Integer
i = 2
With ExcelApp.ActiveWorkbook.Worksheets("sheet1")
Do
Select Case .Range("c" & i)
Case "直线":
pt1(0) = .Range("c" & i)
pt1(1) = .Range("d" & i)
pt1(2) = 0
pt2(0) = .Range("e" & i)
pt2(1) = .Range("f" & i)
pt2(0) = 0
ThisDrawing.ModelSpace.AddLine pt1, pt2
Case "圆":
pt1(2) = 0
Rad = .Range("c" & i)
ThisDrawing.ModelSpace.AddCircle pt1, Rad
Case Else:
Exit Do
End Select
i = i + 1
Loop
End With
ExcelApp.Workbooks.Close
ExcelApp.Quit
ThisDrawing.Application.Update
End Sub
发表于 2004-8-6 23:24:00 | 显示全部楼层
www.ikozmos.com for vlxls
GMT+8, 2025-7-29 04:33 , Processed in 0.187707 second(s), 24 queries , Gzip On.
