查看: 1656|回复: 2
请教如何做有角度的阵列
发表于 2012-8-4 08:36:58 | 显示全部楼层 |阅读模式
(setq a (getpoint "取得左下角点"))
(setq b (getpoint  "请确定右下角点:"))
(setq ang1 (getint "请确定角度:"))
(setq ang (angle a b))
(setq c (polar a (+ (/ pi 3) ang) (distance a b)))
(command "line" a b "")
(setq en1 (entlast))
(command "line" b c "")
(setq en2 (entlast))
(command "line" a c "")
(setq en3 (entlast))
(command "snap" 60)
(command "array" en1 en2 en3 "" "r" 1 3 (distance a b) "")
该贴已经同步到 YAOSHIWEI的微博
 楼主| 发表于 2012-8-4 08:39:54 | 显示全部楼层
 楼主| 发表于 2012-8-4 08:43:37 | 显示全部楼层
(command "snap" 60)
这个改一下啊(command "snap" ang1)
GMT+8, 2025-7-21 23:33 , Processed in 0.191698 second(s), 28 queries , Gzip On.
