查看: 1718|回复: 1
程序求完善
发表于 2012-8-4 18:24:31 | 显示全部楼层 |阅读模式
下面这个程序跟快速标注差不多,但是存在同样的毛病:出现值为0的标注,标注对象肯定没有重复实体,这个问题跟CAD自带快速标注一样,到底是怎么回事?可以解决吗?
;象qdim一样画辅助线
(defun c:fzx (/ old_cmd ob dim1 sel_ob p1 p2 p3 p4)
  (mai_start nil)
  (princ "\n 选择画辅助线的实体:")
  (if (not (setq sel_ob (ssget))) (exit))
  (setq ob (entlast))
  (princ "\n 输入辅助线结束点:")
  (command "_.qdim" sel_ob "")
  (while (not (zerop (getvar "cmdactive"))) (command pause))
  (setq sel_ob (mai_newset ob))
  (if (or (not sel_ob) (= 0 (sslength sel_ob))) (exit))
  (while (setq dima (ssname sel_ob 0))
     (ssdel dima sel_ob)
  (mapcar 'set '(p1 p1 p2 p3 p4) (mai_dim_data dima))
  (mai_entmake "line" (list (trans p1 0 1) (trans p3 0 1)))
  (mai_entmake "line" (list (trans p2 0 1) (trans p4 0 1)))
  (entdel dima)
  (mai_merge_line (mai_newset ob) 0.01 nil T nil T)
  (mai_end)
你的程序中本身就用了QDIM命令,肯定有相同的bug  发表于 2012-8-4 19:08
发表于 2012-8-4 20:20:13 | 显示全部楼层
顶一下~~
GMT+8, 2025-5-24 21:27 , Processed in 0.202084 second(s), 30 queries , Gzip On.
