查看: 1975|回复: 1
(defun c:addatts
发表于 2003-8-18 09:38:00 | 显示全部楼层 |阅读模式
(defun c:addatts (/ oecho blkName tagName ss totVal index en val txtPt)
   ;;subroutine to extract attribute value from a block
     (defun attval (ins att / attnam val)
        (while (and
                 (/= attnam att)
                 (/= (cdr (assoc 0 (entget ins))) "SEQEND")
               (setq attnam (cdr (assoc 2 (entget ins))))
               (if (= attnam att)
                   (setq val (cdr (assoc 1 (entget ins))))
               (setq ins (entnext ins))
        (eval val)
     );end attval
   ;;start of main 'addatts' function
     (setq
       oecho (getvar "cmdecho")
       blkName (strcase (getstring "\nBlock name: "))
       tagName (strcase (getstring "\nTag name to total: "))
       ss (ssget "x" (list '(0 . "insert")(cons 2 blkName)))
       totVal 0
       index 0
     (setvar "cmdecho" 0)
     (cond
       ((not ss)
        (princ "\nInvalid block name.")
       ((not (attval (ssname ss index) tagName))
        (princ "\nInvalid attribute tag.")
       (T
        (repeat (sslength ss)
          (setq
            en (ssname ss index)
            val (distof (attval en tagName))
            index (1+ index)
          (if val (setq totVal (+ totVal val)))
        );end repeat
        (setq
          totVal (rtos totVal)
          txtPt (getpoint "\nInsertion point for total value: ")
        (command
          "._text"
          "middle"
           txtpt
        (if (= 0.0 (cdr (assoc 40 (tblsearch "style" (getvar "textstyle")))))
           (command "" "" totVal)
           (command "" totVal)
     );end cond
     (setvar "cmdecho" oecho)
   );end addatts
发表于 2003-8-18 13:33:00 | 显示全部楼层
此程序有何功能,能解释一下吗?
GMT+8, 2025-5-15 18:26 , Processed in 0.234774 second(s), 26 queries , Gzip On.
