查看: 2382|回复: 9
求助:怎样点取直线然后自动在两侧生成偏移10的直线?
发表于 2012-8-23 13:35:47 | 显示全部楼层 |阅读模式
各位好,小弟在制图中,用最多的命令是offset,遇到如题所说有情况时,正常情况下要做10个动作才能完成,请问怎样用autolisp编写一个程序,更快地完成这个工作,衷心谢谢各位。
发表于 2012-8-23 15:58:36 | 显示全部楼层
  1. (vl-load-com)
  2. (defun c:of2(/ old_os ss m n en obj)
  3. (setq old_os (getvar "osmode"))
  4. (setvar "osmode" 0)
  5. (setvar "cmdecho" 0)
  6. (princ "\nSelect a line(LWPolyline/Line/Spline):")
  7. (setq ss (ssget) m (sslength ss) n 0)
  8. (command "_undo" "_be")
  9. (command "_.ucs" "")
  10. (while (< n m)
  11. (setq en (ssname ss n) endt (entget en))
  12. (setq ename (cdr (assoc 0 endt)))
  13. (if (member ename (list "XLINE" "RAY"))
  14. (progn
  15. (setq pt10 (cdr (assoc 10 endt)) pt11 (cdr (assoc 11 endt)) ang (atan (/ (cadr pt11) (car pt11))))
  16. (setq endt01 (subst (cons 10 (polar pt10 (+ ang (* 0.5 pi)) 10)) (assoc 10 endt) endt))
  17. (entmake endt01)
  18. (setq endt02 (subst (cons 10 (polar pt10 (- ang (* 0.5 pi)) 10)) (assoc 10 endt) endt))
  19. (entmake endt02)
  20. )
  21. (progn
  22. (setq obj (vlax-ename->vla-object en))
  23. (vl-catch-all-apply '(lambda(xx)
  24. (vla-offset xx 10)
  25. (vla-offset xx -10)
  26. )
  27. (list obj)
  28. )
  29. )
  30. )
  31. (setq n (1+ n))
  32. )
  33. (setvar "osmode" old_os)
  34. (command "_.ucs" "_p")
  35. (command "_.undo" "_e")
  36. (setvar "cmdecho" 1)
  37. (princ)
  38. )
发表于 2012-8-24 21:58:13 | 显示全部楼层
顶一下!!!!
发表于 2012-8-24 23:38:30 | 显示全部楼层
我试试,以下代码没有调试过
(defun c:so()
(vl-load-com)
(setq lineObj (vlax-ename->vla-object (car (entsel))))
(vla-offset lineObj 10)
(vla-offset lineObj -10)
 楼主| 发表于 2012-8-25 10:55:12 | 显示全部楼层
logoin 发表于 2012-8-24 23:38
我试试,以下代码没有调试过
(defun c:so()
(vl-load-com)
这个强,谢谢你。还有谢谢大家的帮忙。
发表于 2013-1-29 11:04:27 | 显示全部楼层
学习一下好代码~
发表于 2014-5-8 09:42:11 | 显示全部楼层
我试试,以下代码没有调试过
(defun c:so()
假如偏移后的线另指定图层呢,怎么改高手
发表于 2014-5-8 13:17:22 | 显示全部楼层
  1. (defun c:tt (/ lineObj)
  2.   (vl-load-com)
  3.   (setq lineObj (vlax-ename->vla-object (car (entsel))))
  4.   (vla-offset lineObj 10)
  5.   (Vlax-Put-Property (vlax-ename->vla-object (entlast)) 'Layer 0)
  6.   (vla-offset lineObj -10)
  7.   (Vlax-Put-Property (vlax-ename->vla-object(entlast)) 'Layer 0)
  8.   (princ)
  9. )
发表于 2014-5-10 09:27:47 | 显示全部楼层
染指红颜_笑 发表于 2014-5-8 13:17
0 层以外的层好像不能双偏移,只能单偏移,并且出错。。麻烦改改啊,并且能不能实现这样的功能呢:直线偏移后连成一个闭合的矩形呢?
发表于 2014-5-10 10:13:08 | 显示全部楼层
注:单向偏移出多个对象的暂时不能改属性
  1. ;;;;简单版双向偏移函数  2014-5-10
  2. ;;;(sk_myoffset 距离 图元名  图层 颜色 线型 线宽)
  3. ;;;(sk_myoffset2 偏移距离【数值】 图元名 图层【字符串】颜色【0-256 0=随块 256随层】线型【字符串,"bylayer"随层"byblock"随块】线宽【整数 -2~211 -2随块 -1 随层 211=2.11mm】)
  4. (defun sk_myoffset2(sk_dist en sk_lay sk_color sk_lt sk_lw / OBJ OBJ-OFFSET OBJ-OFFSET1 OBJ-OFFSET2 P1 P2)
  5.       (if (and sk_dist en)
  6.         (progn
  7.           (setq obj (vlax-ename->vla-object en))
  8.           (vla-Highlight obj :vlax-true)
  9.           (setq obj-offset1(vlax-invoke-method obj 'offset  sk_dist))
  10.           (setq obj-offset2(vlax-invoke-method obj 'offset  (* sk_dist -1)))
  11.           (setq obj-offset1(vlax-safearray-get-element(vlax-variant-value obj-offset1) 0))
  12.           (setq obj-offset2(vlax-safearray-get-element(vlax-variant-value obj-offset2) 0))
  13.           (if sk_lay (progn(vla-put-layer obj-offset1 sk_lay)(vla-put-layer obj-offset2 sk_lay)))
  14.           (if sk_color (progn (vla-put-color obj-offset1 sk_color)(vla-put-color obj-offset2 sk_color)))
  15.           (if sk_lt (progn (vla-put-linetype obj-offset1 sk_lt)(vla-put-linetype obj-offset2 sk_lt)))
  16.           (if sk_lw (progn (vla-put-lineweight obj-offset1 sk_lw)(vla-put-lineweight obj-offset2 sk_lw)))
  17.           )
  18.         )
  19.       (and obj (vla-Highlight obj :vlax-false))
  20.   )
  21. (defun c:o10()
  22.   ;;(sk_myoffset2 偏移距离【数值】 图元名 图层【字符串】颜色【0-256 0=随块 256随层】线型【字符串,"bylayer"随层"byblock"随块】线宽【整数 -2~211 -2随块 -1 随层 211=2.11mm】
  23.   (if(setq ss(ssget '((0 . "*line,arc,circle,ellipse"))))
  24.     (while(setq en(ssname ss 0))
  25.       (sk_myoffset2 10 en "0" 1 "bylayer" -1)
  26.       (setq ss(ssdel en ss))
  27.       )
  28.     )
  29.   (princ)
  30.   )
GMT+8, 2025-5-24 20:21 , Processed in 0.175699 second(s), 27 queries , Gzip On.
