- 积分
- 1855
- 明经币
- 个
- 注册时间
- 2012-7-30
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
大家帮忙看看下面的程序,执行后,边界不能合并,返回的是:“错误: no function definition: VLAX-ENAME->VLA-OBJECT”,我是新手,请大家帮忙,谢谢!
;;;选择直线 园弧 园自动生成边界,程序作者:Gu_xl 时间:2010年2月
(defun c:bj (/ NewSel sel n mn en entype pt1 pt2 pL sel k p1 p2 enlast ensel)
;;;选择集合并,返回合并后选择集,参数 选择集 图元都可以
(defun SS_SSjoin (ss1 ss2 / ename ss cnt)
(if ss1
(if (= (type ss1) 'ENAME)
(setq
ename ss1
ss1 (ssadd)
(ssadd ename ss1)
(if ss2
(if (= (type ss2) 'ENAME)
(setq
ename ss2
ss2 (ssadd)
(ssadd ename ss2)
(setq ss (ssadd))
(if (and ss1 ss2)
(setq ss ss2
cnt 0
(repeat (sslength ss1)
(ssadd (ssname ss1 cnt) ss)
(setq cnt (1+ cnt))
(if (and ss1 (not ss2))
(setq ss ss1)
(if (and ss2 (not ss1))
(setq ss ss2)
(if (> (sslength ss) 0)
(eval ss)
nil
;;选择集求交点子程序
(defun interss
(ss / i ssl aobj1 aobj2 n2 ipts pts pts1 pt el objL objL1)
(setq ssl (sslength ss)
i -1
objL '()
;;;OBJL 对象表 '((obj1) (obj2)...)
(repeat ssl
(setq
objL
(cons (list (vlax-ename->vla-object (ssname ss (setq i (1+ i)))))
objL
) ;repeat
(setq i -1)
(repeat ssl
(setq obj1 (nth (setq i (1+ i)) objL))
(setq objL1 (cdr (member obj1 objL))
aobj1 (car obj1)
(setq mm (- ssl i 1)
m -1
pts '()
(repeat mm
(setq obj2 (nth (setq m (1+ m)) objL1))
(setq aobj2 (car obj2)
pts1 '()
(setq ipts (vla-intersectwith
aobj1
aobj2
0
ipts (vlax-variant-value ipts)
(if (> (vlax-safearray-get-u-bound ipts 1) 0) ;是否有交点
(setq ipts
(vlax-safearray->list ipts)
(while (> (length ipts) 0)
(setq pt (list (car ipts)
(cadr ipts)
(caddr ipts)
(cond
((or (= (vla-get-objectname aobj2) "AcDbLine")
(= (vla-get-objectname aobj2) "AcDbArc")
(if (not (or (equal (vlax-curve-getstartpoint aobj2)
pt
0.0001
(equal (vlax-curve-getendpoint aobj2)
pt
0.0001
(setq pts1 (cons pt pts1))
;(setq objL (subst (append obj2 (list pt)) obj2 objL))
) ;if
((= (vla-get-objectname aobj2) "AcDbCircle")
) ;cond
(cond
((or (= (vla-get-objectname aobj1) "AcDbLine")
(= (vla-get-objectname aobj1) "AcDbArc")
(if (not (or (equal (vlax-curve-getstartpoint aobj1)
pt
0.0001
(equal (vlax-curve-getendpoint aobj1)
pt
0.0001
(setq pts (cons pt pts))
) ;if
((= (vla-get-objectname aobj1) "AcDbCircle")
) ;cond
(setq ipts (cdddr ipts))
) ;while
) ;progn
) ;if
(if pts1
(setq objL (subst (append obj2 pts1) obj2 objL))
) ;repeat
(if pts
(setq objL (subst (append obj1 pts) obj1 objL))
) ;if
) ;repeat
;在这里单独去除重合点和点沿曲线排序
(mapcar '(lambda (a)
(if (cdr a)
(list (car a)
(gxl-SortPointOnCurve
(gxl-ListDumpPoint (cdr a) 0.00001)
(car a)
a
objL
) ;defun interss1
;;;Line/Arc/Circle实体打断程序 Break_ss
(defun Break_ss (ss / ObjptL obj pts
thisdrawing modelspace ssl
pstart pend LayerName Linetype Color
objLine
(if ss
(setq objptL (interss ss)
thisdrawing (vla-get-activedocument
(vlax-get-acad-object)
modelspace (vla-get-ModelSpace thisdrawing)
ssL (length objptL)
i -1
) ;progn
) ;if
(vla-startundomark thisdrawing)
(setq LastEntity (entlast))
(repeat ssl
(setq objPts (nth (setq i (1+ i)) objptL)
obj (car objPts)
pts (cadr objPts)
(cond ((= (vla-get-objectname obj) "AcDbLine")
(setq LayerName (vla-get-layer obj)
Linetype (vla-get-linetype obj)
Color (vla-get-color obj)
(setq pstart (vlax-curve-getstartpoint obj)
pend (vlax-curve-getendpoint obj)
pts (append (list pstart) pts)
pts (append pts (list pend))
(while
(> (length pts) 1)
(setq objLine (vla-addline
modelspace
(vlax-3d-point (car pts))
(vlax-3d-point (cadr pts))
;;;加入选择集
(ssadd (entlast) NewSel)
(vla-put-layer objLine LayerName)
(vla-put-linetype objLine Linetype)
(vla-put-color objLine Color)
(setq pts (cdr pts))
(ssdel (vlax-vla-object->ename obj) Sel)
(vla-Delete obj)
((= (vla-get-objectname obj) "AcDbArc")
(BreakArcByPoint (vlax-vla-object->ename obj) pts)
((= (vla-get-objectname obj) "AcDbCircle")
(Cir2ArcByPoint (vlax-vla-object->ename obj) pts)
) ;cond
) ;repeat
(vla-endundomark thisdrawing)
) ;defun Break_ss1
;;;将圆、圆弧打断变为arc 实体表转换 (cir2arc cir strang endang)
;;;测试: (cir2arc (car(entsel "\n选择要转为半圆弧的圆实体:")) 0 Pi T)
(defun cir2arc (cir strang endang / el x)
(setq el (entget cir)
el (vl-remove-if
'(lambda (x) (or (= -1 (car x)) (= 0 (car x))))
el
el (append
(list '(0 . "ARC"))
el
(list '(100 . "AcDbArc") (cons 50 strang) (cons 51 endang))
(entmake el)
;;;加入选择集
;;;沿园上分割点将园打断为圆弧 Cir2ArcByPoint cir ptLst
(defun Cir2ArcByPoint (cir ptLst / cpt r x k kk ang0 ang1 angL)
(setq cpt (dxf cir 10)
r (dxf cir 40)
(setq angL (vl-sort (mapcar '(lambda (x) (angle cpt x)) ptLst) '<))
(setq k -1
kk (length angL)
ang0 (last angL)
(repeat kk
(setq ang1 (nth (setq k (1+ k)) angL)
(cir2arc cir ang0 ang1)
(setq ang0 ang1)
) ;repeat
(ssdel cir Sel)
(entdel cir)
) ;defun
;;;沿园弧上分割点将园打断为圆弧 BreakArcByPoint cir ptLst
(defun BreakArcByPoint
(cir ptLst / cpt r x k kk angstart angEnd ang1 angL)
(setq angstart (dxf cir 50)
angEnd (dxf cir 51)
cpt (dxf cir 10)
(setq angL (mapcar '(lambda (x) (angle cpt x)) ptLst))
(setq k -1
kk (length angL)
(repeat kk
(cir2arc cir angstart ang1)
(setq angstart ang1)
) ;repeat
(cir2arc cir angstart angEnd)
(ssdel cir Sel)
(entdel cir)
) ;defun
;;;gxl-ListDumpPoint 从给定点列表中移去重复出现的点。
;;pts:表 fuzz:精度
;;By Aeo
(defun gxl-ListDumpPoint (ptLst fuzz / pt1 x)
(cond ((= (length ptLst) 1) ptLst)
(t
(setq pt1 (car ptLst))
(cons pt1
(vl-remove-if
'(lambda (x) (equal pt1 x fuzz))
(gxl-ListDumpPoint (cdr ptLst) fuzz)
;;;(gxl-SortPointOnCurve points curve) 参数 点集 points 曲线图元 curve 点集沿曲线排序
(defun gxl-SortPointOnCurve (points curve / pl1 xx nn)
(if (= (type curve) 'ENAME)
(setq curve (vlax-ename->vla-object curve))
(setq pl1 (mapcar '(lambda (xx /)
(vlax-curve-getparamatpoint
curve
(vlax-curve-getclosestpointto curve xx)
points
(mapcar '(lambda (nn) (nth nn points))
(vl-sort-i pl1 '<)
;;;表操作函数
;;;判断点 p1 是否在点集PL中,是返回T ,不是返回nil,a为精度
;;;例 (IsInPointList '(1.0001 1.001 0) '((1 1 0) (2 1 0)) 0.001),返回T
(defun IsInPointList (p1 PL a)
(if (member t (mapcar '(lambda (b) (equal p1 b a)) PL))
t
nil
;;;取出图元索引i对应的值
(defun dxf (ent i)
(cdr (assoc i (entget ent)))
;;;MidPoint 表操作函数,计算两点的中点
;;;计算两点的中点
(defun MidPoint (p1 p2)
(if (> 2 (length p1))
(list (* 0.5 (+ (car p1) (car p2)))
(* 0.5 (+ (cadr p1) (cadr p2)))
(* 0.5 (+ (caddr p1) (caddr p2)))
;;;取圆弧的起点、终点。中点
(defun arc_3point (a / cenp radius STP ENPmp arcmidpoint)
(setq cenp (cdr (assoc 10 (entget a))))
(setq radius (cdr (assoc 40 (entget a))))
(setq
STP (vlax-curve-getPointAtParam A (vlax-curve-getstartparam A))
(setq ENP (vlax-curve-getPointAtParam A (vlax-curve-getEndParam A)))
(setq arcmidpoint
(polar (polar stp
(angle stp enp)
(/ (distance STP ENP) 2.0)
(angle cenp
(polar stp
(angle stp enp)
(- radius
(distance (polar stp
(angle stp enp)
cenp
(list stp enp arcmidpoint)
;;;get_rec_pointlist 获得一组点列表中左下角坐标和右上角坐标范围,[<左下角点> <右上角点> ]
(defun get_rec_pointlist (Pt_List / n plx ply pmin pmax e1 e2)
(setq pt3 (LIST (apply 'max (mapcar '(lambda (x) (car X)) PT_LIST))
(apply 'max (mapcar '(lambda (x) (caDr X)) PT_LIST))
PT1 (LIST (apply 'mIN (mapcar '(lambda (x) (car X)) PT_LIST))
(apply 'mIN (mapcar '(lambda (x) (caDr X)) PT_LIST))
(list PT1
pt3
) ;defun get_rec_pointlist
;;;返回直线、弧、园中点左右两侧一定距离的点,(LAC-LR-Point en d) 返回点对表 (左侧点 . 右侧点)
(defun LAC-LR-Point (en d / a1 a2 a3 ang1 ang2)
(cond ((= (dxf en 0) "LINE")
(setq a1 (dxf en 10)
a2 (dxf en 11)
a3 (MidPoint a1 a2)
ang (angle a1 a2)
ang1 (+ ang (* pi 0.5))
ang2 (- ang (* pi 0.5))
a1 (polar a3 ang1 d)
a2 (polar a3 ang2 d)
(cons a1 a2)
((= (dxf en 0) "ARC")
(setq a3 (dxf en 10) ;圆心
r (dxf en 40) ;半径
ang (* (+ (dxf en 50) (dxf en 51)) 0.5)
a1 (polar a3 ang (- r d))
a2 (polar a3 ang (+ r d))
(cons a1 a2)
((= (dxf en 0) "CIRCLE")
a2 (polar a1 0 (+ d (dxf en 40)))
(cons a1 a2)
) ;cond
;;;根据选择集中的line、arc、circle,生成点集
(defun make_point_list (s / PL)
(setq n 0
PL '()
mn (sslength s)
(repeat mn
(setq en (ssname s n)
enType (dxf en 0)
(cond
((= enType "LINE")
(setq pt1 (dxf en 10)
pt2 (dxf en 11)
(if (not (IsInPointList pt1 pl 0.00001))
(setq pl (cons pt1 pl))
) ;if
(if (not (IsInPointList pt2 pl 0.00001))
(setq pl (cons pt2 pl))
) ;if
((= enType "ARC")
(setq pt1 (car (arc_3point en))
pt2 (cadr (arc_3point en))
) ;if
) ;if
) ;cond
(setq n (1+ n))
) ;repeat
(setq pl pl)
) ;make_point_list
;;;主程序开始
(princ "\n*******选择直线 园弧 园自动生成边界,程序作者:Gu_xl********")
(setq oldos (getvar "osmode"))
(setq oldfill (getvar "fillmode"))
(setvar "osmode" 0)
(setvar "fillmode" 1)
(setvar "cmdecho" 0)
(setq NewSel (ssadd))
(princ "\n选择直线 、园弧、 园:")
(setq sel (ssget (list '(0 . "line,arc,circle"))))
(princ "\n正在整理 数据...........")
;;;打断代码
(Break_ss Sel)
(setq Sel (SS_SSjoin Sel NewSel))
(if sel
(setq Plist (make_point_list sel))
(zoom_window (setq recList (get_rec_pointlist Plist)))
;;;计算点范围Y值的五百分之一
(setq VerticalLimit
(* 0.002 (- (cadadr recList) (cadar recList)))
(if (< VerticalLimit 0.2)
(setq VerticalLimit 0.2)
(setq enlast (entlast)
ensel (ssadd)
;;;如果enlast为块定义,得到最后子图元
(while (entnext enlast)
(setq enlast (entnext enlast))
(setq enlast1 enlast)
(command "_.boundary" "a" "i" "n" "+x" "b" "n" sel "" "")
(setq ki -1
k (sslength Sel)
(princ "\n共有 ")
(princ K)
(princ " 边,正在生成边界.........")
(princ K)
(repeat k
(setq en-line (ssname Sel (setq ki (1+ ki)))
LpLst (LAC-LR-Point en-line VerticalLimit) ;直线两边点
(command (car LpLst))
(command (cdr LpLst))
) ;repeat
(command "")
(while (setq en (entnext enlast))
(setq enlast en)
(ssadd en ensel)
) ;while
(command "erase" sel "")
(setq ensel ensel)
) ;progn
nil
) ;if
(setvar "osmode" oldos)
(setvar "fillmode" oldfill)
