查看: 6644|回复: 34
大旱盼甘霖,程序盼完善!
发表于 2012-8-31 11:42:37 | 显示全部楼层 |阅读模式
1明经币
社区的朋友“tjuzkj”分享了下面的程序,非常漂亮,最近我在苦想这个程序的作用,结论如下:
布置自动喷淋(管道专业常用)
程序需改进:①增加动态间距显示(截图中的“主要间距”、“边缘间距”),主要间距默认值为3300,可设置并可记忆上一次输入的主要间距,还可以通过“9” “0”调节,调节的步长值设为50;
                     ②两个边缘间距相同,但是边缘间距跟主要间距不能相同且需要根据主要间距自动调节;
                     ③增加确定第二个点时的捕捉;
                     ④画完水平线能接着画竖线,或者相反
我重点描述一下“拟作用2”,这个管道专业的应该都清楚,布置喷淋时需要叠加梁图,查看喷淋支管与梁、墙、柱子等构配件的间距是否合适,有些建筑的布局较复杂,因此支管间距的反复调整显得非常繁琐,我相信下面的程序经过论坛里大师们恰当的改编,一定能很好的满足上述的功能,这个功能内心早有想法,但苦于没有编程功底,总算是找到个类似的了,仿佛极度口渴时看见一片汪洋大海,是水,但是不能喝!!!小弟在此恭候大师出手相助了!
;;; ★hvlines 动态垂直水平线
;;;  By  tjuzkj  明经社区分享  http://bbs.mjtd.com/thread-91313-1-1.html
(defun c:hvlines ( / *error* g1 g2 gr h l ms p p1 p2 v )
  ;; Lee Mac 2011
  (defun *error* ( m ) (redraw) (princ))
  (or *n (setq *n 3))
  (if (setq p1 (getpoint "\nSpecify First Corner: "))
      (setq ms (princ "\nSpecify Opposite Corner [TAB/+/-]: "))
      (while
        (progn (setq gr (grread t 15 0) g1 (car gr) g2 (cadr gr))
          (cond
            ( (= 5 g1)(redraw)
              (if *v
                  (setq h (/ (- (car g2) (car p1)) (1+ *n))
                        v (- (cadr g2) (cadr p1))
                        p p1
                  (repeat *n
                    (setq p (list (+ h (car p)) (cadr p) (caddr p)))
                    (grdraw p (list (car p) (+ v (cadr p)) (caddr p)) -1)
                  (setq l
                    (list
                      p1 (list (car p1) (+ v (cadr p1)) (caddr p1))
                      g2 (list (+ h (car p)) (cadr p) (caddr p))
                  (setq h (- (car g2) (car p1))
                        v (/ (- (cadr g2) (cadr p1)) (1+ *n))
                        p p1
                  (repeat *n
                    (setq p (list (car p) (+ v (cadr p)) (caddr p)))
                    (grdraw p (list (+ (car p) h) (cadr p) (caddr p)) -1)
                  (setq l
                    (list
                      p1 (list (+ (car p1) h) (cadr p1) (caddr p1))
                      g2 (list (car p) (+ v (cadr p)) (caddr p))
              (mapcar '(lambda ( a b ) (grdraw a b 1 -1)) l (append (cdr l) (list (car l))))
            ( (= 2 g1)
              (cond
                ( (member g2 '(45 95))
                  (if (= 1 *n)
                    (princ (strcat "\n--> Minimum Number of Lines Reached." ms))
                    (setq *n (1- *n))
                ( (member g2 '(43 61))
                  (setq *n (1+ *n))
                ( (= 9 g2)
                  (setq *v (not *v)) t
            ( (= 3 g1)
              (if *v
                  (repeat *n (setq p1 (list (+ h (car p1)) (cadr p1) (caddr p1)))
                    (entmakex
                      (list
                        (cons 0 "LINE")
                        (cons 10 (trans p1 1 0))
                        (cons 11 (trans (list (car p1) (+ v (cadr p1)) (caddr p1)) 1 0))
                  (repeat *n (setq p1 (list (car p1) (+ v (cadr p1)) (caddr p1)))
                    (entmakex
                      (list
                        (cons 0 "LINE")
                        (cons 11 (trans (list (+ (car p1) h) (cadr p1) (caddr p1)) 1 0))
              nil
  (redraw) (princ)
帖子已经更新,悬赏也提高了,望大师出手相助!(突然发现贴的第二张gif效果出不来,能一并实现更好!)
附件: 您需要 登录 才可以下载或查看,没有账号?注册
最佳答案
查看完整内容
20楼程序的源码放给大家了。
发表于 2012-8-31 11:42:38 | 显示全部楼层
20楼程序的源码放给大家了。
非常好用!谢谢孤帆大侠!  发表于 2012-12-10 12:49
发表于 2012-8-31 12:35:23 | 显示全部楼层
缺少捕捉第二点!~~
 楼主| 发表于 2012-8-31 12:47:50 | 显示全部楼层
daidong013 发表于 2012-8-31 12:35
缺少捕捉第二点!~~
正如我发帖描述
发表于 2012-8-31 14:31:12 | 显示全部楼层
高手
发表于 2012-8-31 23:44:55 | 显示全部楼层
缺少捕捉第二点!~~
纯顶帖?  发表于 2012-9-1 08:53
发表于 2012-9-1 10:33:44 | 显示全部楼层
路过,帮顶
发表于 2012-9-1 21:32:13 | 显示全部楼层
帮顶 楼主的建议画立杆也不错
什么立杆?  发表于 2012-9-2 11:48
发表于 2012-9-3 14:56:18 | 显示全部楼层
yaokui25 发表于 2012-8-31 23:44
缺少捕捉第二点!~~
这个我下载试用过
发表于 2012-9-4 12:39:58 | 显示全部楼层
帮顶下!!!!!!!!
GMT+8, 2025-5-1 09:03 , Processed in 0.190240 second(s), 35 queries , Gzip On.
