查看: 2592|回复: 4
求助,copy命令与*error*出错处理的用法
发表于 2012-9-14 10:18:02 | 显示全部楼层 |阅读模式
(defun c:c (/ s)
  (command "undo" "be")
  (defun *error*(msg)
    (command "undo" "e")
    (setq *error* nil)
  (setq s (ssget))
  (if s
    (command "copy" s "" "m")     ; (command "copy" s "" "m" pause)
  (*error* "")
程序中,必须要有"undo" "be"与"e",上面的命令运行后
选择对象: 指定对角点: 找到 1516 个
选择对象:
需要点或选项关键字。
需要点或选项关键字。
; 错误: *error* 函数中出错函数被取消
(command "copy" s "" "m" pause) 这样也会会显示出错
选择对象:
点无效。
点无效。
如果copy命令里加上坐标点pt1与pt2可以解决,但是这样不能动态显示物体移动效果
请大侠帮忙找到出错问题的解决方法!
发表于 2012-9-14 11:15:27 | 显示全部楼层
参考旧帖:
http://www.google.com/search?as_ ... A%2F%2Fbbs.mjtd.com
*error* 的用法讨论也是一搜即有
 楼主| 发表于 2012-9-14 11:31:59 | 显示全部楼层
查看了楼上提供的搜索,将*error*加进去,运行是ok的
(defun c:cc ()
  (defun *error*(msg)
    (setq *error* nil)
  (command "pline")
  (while (= (logand (getvar "CmdActive") 1) 1) (command pause))
  (*error* "")
将 (= (logand (getvar "CmdActive") 1) 1) (command pause) 加到copy里面,运行问题依据,不知道怎么弄了,晕!
(defun c:c (/ s)
  (defun *error*(msg)
    (setq *error* nil)
  (setq s (ssget))
  (if s
    (command "copy" s "" "m" (= (logand (getvar "CmdActive") 1) 1) (command pause))
  (*error* "")
发表于 2012-9-14 11:53:11 | 显示全部楼层
 楼主| 发表于 2012-9-14 12:15:02 | 显示全部楼层
Andyhon 发表于 2012-9-14 11:53
Another one:
http://www.google.com/search?as_qdr=all&biw=1015&bih=583&q=Copy+%22%28getvar+%22CmdAct ...
这样搞定了
(command "copy" s "" "m" (while (> (getvar "CMDACTIVE") 0) (command PAUSE)))
懂了,谢谢Another 大侠!
GMT+8, 2025-5-9 19:55 , Processed in 0.384286 second(s), 30 queries , Gzip On.
