查看: 1177|回复: 1
框选 图层对调 求助 --------------
发表于 2012-9-17 14:30:35 | 显示全部楼层 |阅读模式
(defun c:as ()
  (vl-load-com)
  (setvar "cmdecho" 0)
  (graphscr)
  (if (setq sss (ssget '((0 . "line") (8 . "colu,ct"))))
    (progn (setq sss1 (ssget "p" '((8 . "ct"))))
    (command "_.select" sss "remove" sss1 "")
    (setq sss2 (ssget "p"))
     (对调函数)
发表于 2012-9-17 18:39:57 | 显示全部楼层
发错地方啦,应该发到lisp板块。
GMT+8, 2025-5-25 03:43 , Processed in 0.171599 second(s), 25 queries , Gzip On.
