查看: 2289|回复: 2
如何在一条线上生成文字
发表于 2012-9-18 20:01:46 | 显示全部楼层 |阅读模式
1明经币
如何在一条线上生成文字
最佳答案
查看完整内容
;我自己编写的直线上写文字qx命令 (defun c:qx (/ oos oor old_lay old_sty pt ang0 tmq3 fyf s1 e1 tmq1 pt00 pt01 pt1x pt2x pt1y pt2y ang1 k pt1 tst pt0 ang2) (defun ffg-getdxf (en dxf) (cdr (assoc dxf (entget en))) ) (defun ffg-entsel (msg filter / ss sss) (setq ss (entsel msg)) (if (/= ss nil) (progn (command "_.select" (car ss) "") (if (not (setq sss (ssget "P" fi ...
你应该先学会怎么提问题  发表于 2012-9-18 20:19
发表于 2012-9-18 20:01:47 | 显示全部楼层
;我自己编写的直线上写文字qx命令
    (if (/= ss nil)
(if (not (setq sss (ssget "P" filter)))
   (setq ss nil)
   (list (ssname sss 0) (cadr ss))
  (setvar "cmdecho" 0)
  (setq oor (getvar "orthomode"))
  (setvar "orthomode" 0)
  (setq oos (getvar "osmode"))
  (setvar "osmode" 0)
  (setq old_lay (getvar "clayer"))
  (setq old_sty (getvar "textstyle"))
  (setq fyf (getvar "useri2"))
  (setq tmq3 (getvar "users4"))
  (if (< fyf 0)
    (setq fyf (abs fyf))
  (if (= fyf 0)
      (setq fyf 300)
      (setvar "useri2" fyf)
  (if (= (tblobjname "LAYER" "Text") nil)
      (entmake (list (quote (0 . "LAYER")) (quote (100 . "AcDbSymbolTableRecord")) (quote (100 . "AcDbLayerTableRecord"))
       (quote (6 . "CONTINUOUS")) (quote (62 . 7)) (quote (70 . 0)) (cons 2 "Text")
  (if (not (tblsearch "style" "TSSD_REIN"))
      (command "-style" "TSSD_REIN" "txt.shx,hztxt.shx" "0" "0.7" "0" "N" "N" "N")
  (initget "R C")
  (setq yesno (getkword "\n文字与直线对齐方式[边对齐(R)/中间对齐(C)] <C>:"))
  (cond
    ((= yesno "C")
      (setq tst 1)
    ((= yesno "c")
      (setq tst 1)
    ((= yesno "R")
      (setq tst 2)
    ((= yesno "r")
      (setq tst 2)
    (t
      (setq tst 1)
  (setq fyf (getint (strcat "\n请输入文字高度< " (itoa fyf) " >:"))
fyf (if fyf
       fyf
       (getvar "useri2")
  (while (setq s1 (ffg-entsel "\n请选择一根直线(line或lwpolyline)<退出>: " (quote ((0 . "LINE,LWPOLYLINE")))))
    (setq e1 (car s1)
   tmq1 (ffg-getdxf e1 0)
   pt0 (cadr s1)
    (if (= "LINE" tmq1)
(setq pt00 (ffg-getdxf e1 10)
       pt01 (ffg-getdxf e1 11)
       ang0 (angle pt00 pt01)
       ang0 (/ (* ang0 180) pi)
       ang2 ang0
       pt1x (car pt00)
       pt1y (cadr pt00)
       pt2x (car pt01)
       pt2y (cadr pt01)
    (if (and
   (= "LWPOLYLINE" tmq1)
   (= (ffg-getdxf e1 90) 2)
       pt01 (cdr (assoc 10 (reverse (entget e1))))
       ang2 ang0
       pt1x (car pt00)
       pt1y (cadr pt00)
       pt2x (car pt01)
       pt2y (cadr pt01)
    (if (and
   (< (distance pt0 pt00) (distance pt0 pt01))
   (= tst 2)
      (setq k 0)
    (if (and
   (> (distance pt0 pt00) (distance pt0 pt01))
   (= tst 2)
      (setq k 1)
    (if (= tst 1)
      (setq k 0.5)
    (setq ptx (+ pt1x (* (- pt2x pt1x) k))
   pty (+ pt1y (* (- pt2y pt1y) k))
   pt1 (list ptx pty)
    (if (and
   (> ang0 90)
   (<= ang0 270)
(setq ang0 (angle pt01 pt00)
       ang1 (+ ang0 90)
       ang1 (rem ang1 360)
       pt (polar pt1 (* (/ ang1 180) pi) 150)
(setq ang1 (+ ang0 90)
       ang1 (rem ang1 360)
    (setq tmq3 (getstring t (strcat "\n请输入标注文本< " tmq3 " >:"))
   tmq3 (if tmq3
   tmq3
   (getvar "users4")
    (if (= tmq3 "")
    (setvar "users4" tmq3)
    (if (/= old_sty "TSSD_REIN")
(command "text" "style" "TSSD_REIN")
(command)
    (setvar "clayer" "Text")
    (if (= tst 1)
      (command "text" "j" "bc" pt fyf ang0 tmq3)
    (if (and
   (= tst 2)
      (if (and
     (> ang2 90)
     (<= ang2 270)
(command "text" "j" "bR" pt fyf ang0 tmq3)
(command "text" "j" "bl" pt fyf ang0 tmq3)
    (if (and
   (= tst 2)
      (if (and
     (> ang2 90)
     (<= ang2 270)
(command "text" "j" "br" pt fyf ang0 tmq3)
    (command "_clayer" old_lay)
    (command "_textstyle" old_sty)
  (setvar "osmode" oos)
  (setvar "orthomode" oor)
  (setvar "cmdecho" 1)
太好了,非常实用  发表于 2012-9-18 23:07
发表于 2012-9-18 22:46:51 | 显示全部楼层
不知道符合你的要求否.
GMT+8, 2025-8-28 00:23 , Processed in 0.200547 second(s), 33 queries , Gzip On.
