查看: 3148|回复: 19
数字后缀的字符串. 只按X排序
发表于 2012-10-5 00:08:58 | 显示全部楼层 |阅读模式
     搜到大师的帖子,如下:
   ;;;(strsort strlst) = 含数字后缀的字符串排序-无痕.2004.6 ok!
(defun strsort (strlst)
  (defun strbrk (str / i st1 n)
    (setq i 0)
    (while (not (or (= "" (setq st1 (substr str (setq i (1+ i)))))
      (setq n (distof st1))
    (list (substr str 1 (1- i))
   (if n n 0)
   str
  (defun x-sort (lst do n)
    (vl-sort lst
      '(lambda (x y) ((eval do) (nth n x) (nth n y)))
  (mapcar 'last
   (x-sort (mapcar 'strbrk strlst) '< 1) ;;针对你的情况调整
但请请问大师,带数字后缀的字符串.   只按X的大小排序怎么写啊?
    如("A-12" (图元名: qqaaa)) ("A-2" (图元名: qqaaa))  这样的
 楼主| 发表于 2012-10-5 00:10:52 | 显示全部楼层
  因要用到此类函数按编号来提取物体的数据
发表于 2012-10-5 16:34:36 | 显示全部楼层
;;专用字符排序,效果比vl-sort好用
(defun TBC:Sort        (lst func / Split CompFunc tmp)
   (defun Split (str / tmp i n p x len lst1 lst)
     (setq tmp  (vl-string->list str)
          lst1 (mapcar '(lambda (x) (and (<= 48 x) (<= x 57))) tmp)
          n    (length lst1)
          i    0
     (while (< i n)
       (setq x (nth i lst1)
            i (1+ i)
       (if (= i 1)
        (setq p        1
              len 1
        )                                ;else
        (if (= x (nth (- i 2) lst1))
          (setq len (1+ len))                ;else
          (setq        tmp (substr str p len)
                tmp (if        x
                      tmp
                      (atoi tmp)
                lst (append lst (list tmp))
                p   i
                len 1
        )                                ;if
       )                                        ;if
     )                                        ;while
     (if        (> n 0)
            tmp        (if x
                  (atoi tmp)
                  tmp
     lst
   (defun CompFunc (lst1 lst2 / tmp do flag i n el1 el2 typ1 typ2)
     (setq i  0
          n  (min (length lst1) (length lst2))
          do T
     (while (and do (<= i n))
       (setq el1         (nth i lst1)
            typ1 (type el1)
            el2         (nth i lst2)
            typ2 (type el2)
            i         (1+ i)
       (if (= typ1 typ2)
        (setq do   (= el1 el2)
              flag (eval (list func el1 el2))
        )                                ;else
        (setq do   nil
              flag (or (= typ1 'nil) (= typ2 'STR))
       )                                        ;if
     )                                        ;while
     flag
   (setq        tmp (mapcar 'Split lst)
        tmp (vl-sort-i tmp 'CompFunc)
        tmp (mapcar '(lambda (x) (nth x lst)) tmp)
   tmp
;;(TBC:SORT '("A-12" "B-25" "A-20" "C-3" "A-0") '>)
;; ("C-3" "B-25" "A-20" "A-12" "A-0")
 楼主| 发表于 2012-10-6 00:24:41 | 显示全部楼层
  大侠,我现在要只排点对中的X序,,请赐教
    如("D-12" (图元名: qqaaa)) ("A-2" (图元名: qqaaa)("F-2" (图元名: qqaaa))    这样的
最终效果要是这样:
      ("A-2" (图元名: qqaaa)) ("D-12" (图元名: qqaaa)("F-2" (图元名: qqaaa))
 楼主| 发表于 2012-10-6 00:33:32 | 显示全部楼层
   就是X,Y坐标点对按X排序的升级版
发表于 2012-10-6 10:29:22 | 显示全部楼层
方法都给你了,
 楼主| 发表于 2012-10-6 23:39:15 | 显示全部楼层
  前辈能否帮改一个,谢谢你了
对lambda 和
  mapcar这两个 函数总是理解不透
 楼主| 发表于 2012-10-7 16:47:26 | 显示全部楼层
  做了一个:  好像不行的
lix= (("PU-3" (-1 . <图元名: -3d60d8>)) ("PU-20" (-1 . <图元名: -3d6148>)) ("DIE-9" (-1 . <图元名: -38b4d0>)) ("PU-25" (-1 . <图元名: -3d5fb8>)))
(setq LST_POX '())
(foreach x lix
    (setq LST_POX (cons (list(car x)(cadr x)) LST_POX))
  (setq LST_X(TBC:SORT LST_POX
             (function (lambda (e1 e2)
                         ( (car e1) (car e2)) ) ) <)
  (reverse LST_POX)
发表于 2012-10-9 10:20:21 | 显示全部楼层
首先说明一下,以下代码并不能完成,因为TBC:sort我用的不熟,而VL-sort对字符串的排序不问题
(setq lst1 (list "PU-3" "PU-20" "DIE-9" "PU-25"))
(setq ss (ssget))
(setq i        0
       sslst '()
(repeat        (sslength ss)
   (setq endata (entget (ssname ss i)))
   (setq zhi (assoc -1 endata))
   (setq sslst (cons zhi sslst))
   (setq i (1+ i))
(setq endlst (mapcar '(lambda (x y)
                        (list x y)
                     lst1
                     sslst
;;;(setq endlst '(("PU-3" (-1 . <图元名: 7ef7e810>))
;;;               ("PU-20" (-1 . <图元名: 7ef7e818>))
;;;               ("DIE-9" (-1 . <图元名: 7ef7e820>))
;;;               ("PU-25" (-1 . <图元名: 7ef7e828>))
;;;(vl-sort '((3 5) (2 2) (4 3))
;;;         (function (lambda (e1 e2)
;;;                     (< (cadr e1) (cadr e2))
;;;((2 2) (4 3) (3 5))
(setq endlst (vl-sort endlst
                       (function (lambda
                                   (e1 e2)
                                    (< (car e1) (car e2))
发表于 2012-10-9 10:21:36 | 显示全部楼层
我知道我的算法不好,如果继续往下写的话我会将同一组的进行排序,比如说单独对PU系列的排序,我觉得这个算法不好,帮你顶一下吧
GMT+8, 2025-9-26 02:22 , Processed in 0.193590 second(s), 31 queries , Gzip On.
