查看: 2103|回复: 3
cad数据导入excel中遇到的问题
发表于 2012-10-14 16:17:14 | 显示全部楼层 |阅读模式
Sub a()
    '连接EXCEL——标准代码****************************
       Dim xlApp As Excel.Application
       Dim xlbook As Excel.Workbook
       Dim xlSheet As Excel.Worksheet
       On Error Resume Next
       Set xlApp = GetObject(, "excel.application")
       If Err <> 0 Then
         Err.Clear
         Set xlApp = CreateObject("excel.application")
         If Err <> 0 Then
           MsgBox "无法启动excel"
           Exit Sub
         End If
       End If
       If ActiveWorkbook.Sheets.Count = 0 Then xlbook = xlApp.Workbooks.Add
       Set xlbook = xlApp.ActiveWorkbook
       Set xlSheet = xlbook.ActiveSheet
        xlApp.Visible = True
        If Err <> 0 Then Err.Clear
    '标准代码结束*****************************************
Dim retCoord() As Double
Dim a As AcadLWPolyline
Dim i As Integer
Dim j As Integer
Dim l As Integer
i = 0
ThisDrawing.Utility.GetEntity a, "Select an object"
    retCoord() = a.Coordinates
On Error GoTo e
Do While CBool(retCoord(i)) <> False
j = ActiveCell.Row  '这个无法返回激活单元格地址
l = ActiveCell.Column
xlSheet.Cells(j + i / 2, l).Value = retCoord(i)
xlSheet.Cells(j + i / 2, l + 1).Value = retCoord(i + 1)
i = i + 2
Loop
e: Exit Sub
j = 0
l = 0
End Sub
以上是一个将cad中多段线点坐标导入excel中去的代码,在cad中运行该宏,电脑提示“用户定义类型未定义”(红色部分),这是怎么回事??哪位大侠能告诉我??
发表于 2012-10-14 20:57:42 | 显示全部楼层
找开vbe编辑器,工具---引用----microsoft excel 11.0 libiray
 楼主| 发表于 2012-10-15 21:08:45 | 显示全部楼层
好的,谢谢!
发表于 2012-10-21 13:08:20 | 显示全部楼层
好眼熟,呵呵
GMT+8, 2025-8-16 08:23 , Processed in 0.162401 second(s), 23 queries , Gzip On.
