查看: 1818|回复: 4
lisp程序中的调用"复制"命令怎么就是复制不出来图形?
发表于 2012-10-26 16:53:41 | 显示全部楼层 |阅读模式
(defun c:lsp_02 ()
  (setvar "cmdecho" 0)
  (setq os (getvar "osmode"))
  (setvar "osmode" 0)
  (setq pt1 (getpoint "\n第一角点:"))
  (setq pt3 (getcorner pt1 "\n另一角点:"))
  (setq pt2 (list (car pt3) (cdr pt1)))
  (setq pt4 (list (car pt1) (cdr pt3)))
  (setq rr (getdist pt1 "\n圆的半径<5.0>:"))
  (if (null rr) (setq rr 5.0))
  (command "circle" pt1 rr)
  (setq en1 (entlast))
  (command "line" (polar pt1 pi (+ rr 3)) (polar pt1 0 (+ rr 3)) "")
  (setq en2 (entlast))
  (command "line" (polar pt1 (* pi 1.5) (+ rr 3)) (polar pt1 (/ pi 2) (+ rr 3)) "")
  (setq en3 (entlast))
  (command "copy" en1 en2 en3 "" pt1 pt2 pt3 pt4 "")
  (setvar "osmode" os)(prin1)
这是程序源码,不知哪里出错了,望高手解答,多谢!!!
发表于 2012-10-26 17:33:33 | 显示全部楼层
(setq pt2 (list (car pt3) (cadr pt1)))
  (setq pt4 (list (car pt1) (cadr pt3)))
 楼主| 发表于 2012-10-27 13:03:48 | 显示全部楼层
我看了好几遍都没看出来,谢谢。
发表于 2012-10-27 13:10:16 | 显示全部楼层
(command "copy" en1 en2 en3 "" "m" pt1 pt2 pt3 pt4 "")
 楼主| 发表于 2012-10-27 16:26:15 | 显示全部楼层
多谢提醒,这一点我知道原因 当时写错了,后来改过来了,谢谢!!
GMT+8, 2025-9-26 03:18 , Processed in 0.206005 second(s), 29 queries , Gzip On.
