查看: 16039|回复: 37
求助-如何批量延伸到最近点
发表于 2012-10-28 22:11:06 | 显示全部楼层 |阅读模式
请教一下各位老师,我希望通过框选直线,让这些选中的直线自动延伸到最近点.能实现吗?
我在工作中经常要对大量的直线进行延伸,一个个选的话太慢了,希望哪位老师帮帮我.谢谢了!
发表于 2012-10-29 11:17:01 | 显示全部楼层
2012-10-29框选对象,延伸一次.LSP
;;;问题来源:http://bbs.mjtd.com/thread-98171-1-1.html              *
;;;功能:框选对象,自动延伸一次。                                   *
;;;日期:zml84 于 2012-10-29 11:12                                  *
(defun c:tt (/ ss i en ent pt10 pt11)
    (setvar "EDGEMODE" 1) ;_设置系统变量
    (setq i 0)
    (if	(setq ss (ssget))
	(repeat	(sslength ss)
	    (setq en   (ssname ss i)
		  ent  (entget en)
		  pt10 (cdr (assoc 10 ent))
		  pt11 (cdr (assoc 11 ent))
	    ;;调用命令
	    (command "_extend" ss "" (list en pt10) "")
	    (command "_extend" ss "" (list en pt11) "")
	    (setq i (1+ i))
谢谢!我也在找这样的功能!  发表于 2015-2-8 13:33
简单 明了  发表于 2014-4-1 17:32
发表于 2012-10-29 07:33:11 | 显示全部楼层
把代码贴上来,有新需求可与我联系,我的QQ:40184454
纯LISP写的,有点拿不出手哦。。。
(defun Dk:PtRelateLine (Pt1 Pt2 Pt3 / Dis12 Dis13 Dis23)
    (cond ((= (rtos (setq Dis12 (distance Pt1 Pt2)) 2 5) "0.00000") 1)
          ((= (rtos (setq Dis13 (distance Pt1 Pt3)) 2 5) "0.00000") 2)
          ((= (rtos (+ Dis12 Dis13) 2 5) (rtos (setq Dis23 (distance Pt2 Pt3)) 2 5)) 4)
          ((= (rtos (+ Dis13 Dis23) 2 5) (rtos Dis12 2 5)) 8)
          ((= (rtos (+ Dis12 Dis23) 2 5) (rtos Dis13 2 5)) 16)
          (t 32)))
(defun C:EXT (/ n s j dxf_a a10 a11 k data1 data2 dxf_b b10 b11 insect d1 d2 index)
  (setq n (sslength (setq s (ssget '((0 . "LINE"))))))
  (setq j -1)
  (while (< (setq j (1+ j)) n)
    (setq dxf_a (entget (ssname s j)))
    (setq a10 (cdr (assoc 10 dxf_a)))
    (setq a11 (cdr (assoc 11 dxf_a)))
    (setq k -1  data1 (list) data2 (list))
    (while (< (setq k (1+ k)) n)
      (setq dxf_b (entget (ssname s k)))
      (if (/= (cdr (assoc 5 dxf_a)) (cdr (assoc 5 dxf_b)))
          (setq b10 (cdr (assoc 10 dxf_b)) b11 (cdr (assoc 11 dxf_b)))
          (if (null (inters a10 a11 b10 b11))
              (if (setq insect (inters a10 a11 b10 b11 nil))
                  (if (/= 0 (logand 7 (Dk:PtRelateLine insect b10 b11)))
                      (cond ((> (setq d1 (distance insect a10))(setq d2 (distance insect a11)))
                             (setq data1 (append data1 (list (list d2 insect 11)))))
                            ((setq data2 (append data2 (list (list d1 insect 10))))))
                  )) ;end if (setq insect (inters a10 a11 b10 b11 nil))
              )) ;end if (null (inters a10 a11 b10 b11))
          )) ;end if (/= (cdr (assoc 5 dxf_a)) (cdr (assoc 5 dxf_b)))
      ) ;end while
    (if (> (length data1) 0)
        (setq data1 (vl-sort data1 '(lambda (X Y) (< (car X)(car Y)))))
        (setq index (last (car data1)))
        (entmod (setq dxf_a (subst (cons index (cadr (car data1)))(assoc index dxf_a) dxf_a)))
    (if (> (length data2) 0)
        (setq data2 (vl-sort data2 '(lambda (X Y) (< (car X)(car Y)))))
        (setq index (last (car data2)))
        (entmod (subst (cons index (cadr (car data2)))(assoc index dxf_a) dxf_a))
    ) ;end while
  (princ))
参与人数 3明经币 +3 收起 理由
999999 + 1 大神,这个很好用哟,请问大神,可否增加一.
zhangcan0515 + 1 谢谢你 很实用 学习了
crazylsp + 1 很给力!
发表于 2020-5-8 21:41:19 | 显示全部楼层
纯LISP写的,有点拿不出手哦。。。
非常感谢哥哥的分享    这么好用的程序   我现在才找到  各家论坛搜了好久  终于搜到了  太感谢了
发表于 2012-10-28 22:45:35 | 显示全部楼层
延伸到最近点,“最近点”做如何解???
弄个图示意一下,应该不难。。
写个LISP遍历处理一下即可。
 楼主| 发表于 2012-10-28 23:01:31 | 显示全部楼层
自己不会做图,论坛里找来的图片,类似于这个效果,我只需要中间这些线延伸到离它最近的线就可以了,四周的导角不需要
发表于 2012-10-29 00:01:20 来自手机 | 显示全部楼层
这个功能好伸至最近点最好…
发表于 2012-10-29 01:09:24 | 显示全部楼层
所选的对象只限直线是吧?数量会不会很大?
用嵌套遍历,不过算法比较复杂。。
迫切需要此功能?
发表于 2012-10-29 01:11:44 | 显示全部楼层
既然论坛能找来此图片,相关的代码应该早有了,你找此图的主子求助呗
发表于 2012-10-29 06:51:26 | 显示全部楼层
我用纯LISP写了一个,如果所选的对象只限直线,效果如下图,如果满意请联系我...
 楼主| 发表于 2012-10-29 07:08:44 | 显示全部楼层
真的非常感谢,一大早就给我回复,你做的这个效果很好,适合我需要,能分享一下你的程序吗
 楼主| 发表于 2012-10-29 08:30:33 | 显示全部楼层
纯LISP写的,有点拿不出手哦。。。
虽然看不懂代码内容,但是经过测试已经符合我的目的,再次谢谢你
GMT+8, 2025-7-4 04:34 , Processed in 0.208228 second(s), 33 queries , Gzip On.
