查看: 1958|回复: 1
typename(object)返回什么STRING?
发表于 2003-8-27 16:49:00 | 显示全部楼层 |阅读模式
Sub GetEntity2()
    Dim retEnt As Object
    Dim pnt As Variant
    On Error Resume Next
    ' The following example waits for a input from user and returns the Line in retEnt
    ThisDrawing.Utility.GetEntity retEnt, pnt, "Select an object"
    If Err <> 0 Then
        Err.Clear
        MsgBox "You need to select an existing object"
    Else
        Select Case LCase(TypeName(retEnt))       //该怎么写?
        Case "acdbcircle"                                     //返回什么串才对?
               MsgBox "Circle"
         Case "acdbline"                                       //返回什么串才对?
               MsgBox "Line"
        Case Else
               MsgBox "others"
        End Select
      end if
end sub
发表于 2003-8-27 17:25:00 | 显示全部楼层
LCase(TypeName(retEnt))改为:
retEnt.EntityName
acdbcircle改为AcDbCircle,余同。
GMT+8, 2025-5-24 12:05 , Processed in 0.162114 second(s), 24 queries , Gzip On.
