查看: 1798|回复: 0
[讨论]请教程序为什么不能运行。
发表于 2003-8-28 15:47:00 | 显示全部楼层 |阅读模式
你好:
我想问一下程序的问题在哪里?
已经加载了VLIDE.ARX    在R  14 里面。
(vl-acad-defun 'gx)
(defun c:gx (/ a ent1 ent2 ent_tt)
  (setq b (ssget "x"))
  (command "_.explode" b "")
  (command "_.pedit" b "" "j" "" "")
(setq a (ssget "x"))
  (command "_.region" a "")
  (prompt "\n选择实体")
  (setq ent1 (ssname a 0))
  (setq ent2 (ssname a 1))
  ;(setq ent1 (car(entsel "\n选择从中减去的实体或选择外腔")))
  ;(setq ent2 (car(entsel "\n选择减去的实体或者选择内腔")))
  ;(while(or (not ent1)(not ent2))
   ; (prompt"\n 请重新选择实体计算差集")
     ;(;setq ent2 (car(entsel "\n选择减去的实体或选择内腔")))
    (if (< (vla-get-area (vlax-ename->vla-object ent1)) (vla-get-area (vlax-ename->vla-object ent2)))
      (setq ent_tt ent1)
       (setq ent1 ent2)
       (setq ent2 ent_tt)
  (command "subtract" ent1 "" ent2 "")
  (setq ent1 (entlast))
  (princ "\n")
  (setq ent2 (vla-get-momentofinertia (vlax-ename->vla-object ent1)))
  (setq lst (vlax-safearray->list (vlax-variant-value ent2)))
  (princ (strcat "惯性矩:  x值:" (rtos (car lst)1)  "\n"))
  (princ (strcat "         y值:" (rtos (cadr lst)1)  "\n"))
程序提示不能识别  (vlax-variant-value)
GMT+8, 2025-5-15 18:31 , Processed in 0.167149 second(s), 25 queries , Gzip On.
