查看: 3268|回复: 13
怎么得到用ssget选择的物体的最边界点
发表于 2003-8-28 15:59:00 | 显示全部楼层 |阅读模式
发表于 2003-8-28 16:07:00 | 显示全部楼层
看看这个帖子讨论,
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=8747
 楼主| 发表于 2003-8-28 20:12:00 | 显示全部楼层
谢谢!
 楼主| 发表于 2003-8-30 19:30:00 | 显示全部楼层
我发现那个程序对我上传的情况不适合,不知能否改进?
 楼主| 发表于 2003-8-30 19:32:00 | 显示全部楼层
发表于 2003-8-31 14:30:00 | 显示全部楼层
这样的规则图形应该很容易获得吧,
 楼主| 发表于 2003-8-31 19:21:00 | 显示全部楼层
哦,我是说上次看的那个"maxmin.lsp"对此图形抓取不到其边界点
发表于 2003-9-1 09:59:00 | 显示全部楼层
在哪儿?
发表于 2003-9-1 11:03:00 | 显示全部楼层
弧段的中心及半径信息也可以得到吧,那样也可以计算.
 楼主| 发表于 2003-9-1 12:00:00 | 显示全部楼层
;; trap run-time error.
(defun ai_error (errmsg)
   (if (not (member errmsg '("console break" "Function Cancelled"
        "bad argument type" "Function cancelled" "no function definition: DOS_GETPROGRESS"
          "bad argument" "函数被取消" "quit / exit abort"))
      ) ;_ end of not
      (princ (strcat "\nError: " errmsg))
);_defun
;; Get all nodes of the LWPolyline, Polyline.
(defun GetListOfPline (EntityName / SSE_Pline N newEntityName)
(setq SSE_Pline (entget EntityName))
(setq LastList nil)
(if (= (cdr (assoc 0 SSE_Pline)) "LWPOLYLINE")
      (setq LastList (LIST (LIST 0 0)))
      (setq N 0)
      (while (/= (nth N SSE_Pline) nil)
             (if (= (car (nth N SSE_Pline)) 10)
                 (setq LastList (append LastList (list (list (cadr (nth N SSE_Pline)) (caddr (nth N SSE_Pline)) )) ))
             (setq N (+ N 1))
      (setq LastList (cdr LastList))
(if (= (cdr (ASSOC 0 SSE_Pline)) "OLYLINE")
    (PROGN
      (setq LastList (list (list 0 0)))
      (setq newEntityName (entnext EntityName))
      (while (= (cdr (assoc 0 (entget newEntityName))) "VERTEX")
             (setq LastList (append LastList (list (list (cadr (assoc 10 (entget newEntityName))) (caddr (assoc 10 (entget newEntityName))) ))))
             (setq newEntityName (entnext newEntityName))
(setq LastList LastList)
);_defun
;; main function
(defun c:maxmin ( / old_cmd old_osm sel_set i pt_list rad cen x0 y0 pt_minx pt_miny pt_maxx pt_maxy cen_x cen_y ret_val)
  (setq old_cmd (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (setq old_osm (getvar "osmode"))
  (setvar "osmode" 0)
  (setq old_error  *error*                ; save current error function
        *error* ai_error                ; new error function
  (prompt "\nSelect entity:")
  (setq sel_set (ssget))
  (if sel_set
      (setq i 0)
      (repeat (sslength sel_set)
        (setq ent_name (ssname sel_set i))
        (setq ent_list (entget ent_name))
        (cond
          ((or (= (cdr (assoc 0 ent_list)) "LWPOLYLINE")(= (cdr (assoc 0 ent_list)) "OLYLINE"))
           (setq pt_list (append pt_list (GetListOfPline ent_name)))
          ((= (cdr (assoc 0 ent_list)) "CIRCLE")
           (setq rad (cdr (assoc 40 ent_list)))
           (setq cen (cdr (assoc 10 ent_list)))
           (setq x0 (car cen)
                 y0 (cadr cen)
           (setq pt_list (append pt_list (list (list (- x0 rad) (+ y0 rad))(list (+ x0 rad) (- y0 rad)))))
          (t)
        );_cond
        (setq i (+ i 1))
      );_repeat
      (if pt_list
          (setq pt_minx (apply 'min (mapcar 'car pt_list))
                pt_miny (apply 'min (mapcar 'cadr pt_list))
                pt_maxx (apply 'max (mapcar 'car pt_list))
                pt_maxy (apply 'max (mapcar 'cadr pt_list))
                cen_x (/ (+ pt_minx pt_maxx) 2)
                  cen_y (/ (+ pt_miny pt_maxy) 2)
          (setq ret_val (list (cons "10" (list pt_minx pt_miny))
                              (cons "11" (list pt_maxx pt_maxy))
                              (cons "cen" (list cen_x cen_y))
        (princ "\nNo 'Polyline' or 'Circle' entity!")
      );_if
    );_progn
    (alert "No entities selected!")
  );_if
  ; Draw a rectangle to mark the range of the selected entities( Pline or Circle).
  (if (and ret_val (/= (cdr (car ret_val)) (cdr (cadr ret_val))))
      (command "rectang" (cdr (car ret_val)) (cdr (cadr ret_val)) 3)
  );_if
  (setvar "cmdecho" old_cmd)
  (setvar "osmode" old_osm)
  (setq *error* old_error)
  ret_val        ;return list.
);_defun
以上是上次从“王咣生”那里下载的
GMT+8, 2025-4-26 13:50 , Processed in 0.181654 second(s), 28 queries , Gzip On.
