查看: 1745|回复: 1
请看如下程序,如何实现这些功能?
发表于 2003-8-29 09:46:00 | 显示全部楼层 |阅读模式
Private Sub CommandButton1_Click()
Dim a As AcadText
Dim P1(2) As Double
Dim I As Integer,j as integer
I = 1
P1(0) = 0
P1(1) = 0
P1(2) = 0
Do While I < 21
  P1(1) = P1(1) + 13
  j=3
  do while j>0
     Set a = ThisDrawing.ModelSpace.AddText("F" & I & "-A" & j & "/4.2dBm" , P1, 3.5)
    ThisDrawing.Application.Update
    j=j-1
  loop
  I = I + 1
Loop
End Sub
1。如何在每次CAD运行时就加载本程序。
2。如何利用鼠标在屏幕上拾取获得文字间距。
3。是否可以在复制的同时实现文字F1-F21的系列
发表于 2003-8-29 10:26:00 | 显示全部楼层
给你个回车继续填写,取消则退出的程序:
  1. '判断某一键盘键自上次调用该函数以来是否被按过的API函数
  2. Declare Function GetAsyncKeyState Lib "user32" (ByVal vKey As Long) As Integer
  3. Private Const VK_ESCAPE = &H1B
  4. Sub DimNum()
  5.     On Error Resume Next
  6.     Dim ESC As Long
  7.     GetAsyncKeyState VK_ESCAPE
  8.     Dim kk As String
  9.     Dim a As AcadText
  10.     Dim P1 As Variant
  11.     Dim I As Integer
  12.     P1 = ThisDrawing.Utility.GetPoint(, vbCrLf & " 请选择标注点:")
  13.     Dim Dist As Double
  14.     Dist = ThisDrawing.Utility.GetDistance(P1, vbCrLf & " 请输入距离:")
  15.     I = ThisDrawing.Utility.GetInteger(vbCrLf & " 请输入起始的楼层号:")
  16.     Do
  17.         kk = ThisDrawing.Utility.GetKeyword(vbCrLf & " 按回车标注第" & I & "层,按取消键退出标注")
  18.         ESC = GetAsyncKeyState(VK_ESCAPE)
  19.         If ESC <> 0 Then
  20.             Exit Do
  21.         Else
  22.             Set a = ThisDrawing.ModelSpace.AddText("F" & I & "层", P1, 3.5)
  23.             ThisDrawing.Application.Update
  24.             I = I + 1
  25.             P1(1) = P1(1) + Dist
  26.         End If
  27.     Loop
  28. End Sub
GMT+8, 2025-5-24 11:26 , Processed in 0.154386 second(s), 24 queries , Gzip On.
