查看: 1515|回复: 3
求一简单的命令,文字A和B互换,请大家帮忙
发表于 2012-11-7 10:05:56 | 显示全部楼层 |阅读模式
选择文字里面 B改成A  A改成B
发表于 2012-11-7 10:23:04 | 显示全部楼层
思路差不多,拿着改改吧
  1. (DEFUN C:NN (/ ENT txt)
  2.   (while (SETQ ENT (ENTGET (CAR (ENTSEL)))
  3.                txt (CDR (ASSOC 1 ENT))
  4.          )
  5.     (if        (wcmatch txt "[AB]*")
  6.       (if (vl-string-search "G" txt)
  7.         (ENTMOD        (SUBST (CONS 1 (vl-string-subst "A" "B" txt))
  8.                        (ASSOC 1 ENT)
  9.                        ENT
  10.                 )
  11.         )
  12.         (ENTMOD        (SUBST (CONS 1 (vl-string-subst "B" "A" txt))
  13.                        (ASSOC 1 ENT)
  14.                        ENT
  15.                 )
  16.         )
  17.       )
  18.       (princ "\n头字符非AB,请重新选择")
  19.     )
  20.   )
  21.   (prin1)
  22. )
复制代码
发表于 2012-11-7 10:35:43 | 显示全部楼层
 楼主| 发表于 2012-11-7 10:51:09 | 显示全部楼层
谢谢 夏生生,已经可以用了
GMT+8, 2025-9-26 03:51 , Processed in 0.176223 second(s), 26 queries , Gzip On.
