查看: 2310|回复: 0
求此注册码算法解释
发表于 2012-11-14 20:13:06 | 显示全部楼层 |阅读模式
REGLSKEY FIRST 9 [KEY [LAMBDA [X [/[NUM 9 [SETQ [NUM [FIX  [*2 [ATOF [X 9 9 9 9 [SUBST R [PASSWORD [1 + [NUM 9 2 9 [PASSWORD U *AF2QE5G9HL96 EMPEQIEO820ZXQQW IOPYKF208FO02I [K EYLLST MAPCAR [LAMBDA [X [/[TMPSTR 9 [SETQ [TMPSTR [RTOS [X 2 2 9 9 [TO SUMLST VL-STRING -> LIST KEYNUM FIVE FOUR THREE TWO ONE – LEN STRL EN SETVAR U cmdecho [REGEDIT MACHNUMB CPUID U ret [[EVAL vl ax –invoke EXECUT ESTATEMENT vlax- put U vbs[LA NGUAGE vlax-crea te-object U ScriptControl [NOT *WSC STR U Set objSWbemObject = GetObject("winmgmts:Win32_ Processor.Device ID='cpu0'" )
ret = objSWbemObj ect.ProcessorId 'msgbox
这是一注册码算法,格式很乱,本人刚入门的,求高人指点此注册码的算法,由于财富不多,仅能悬赏3个明币求详细解答。
GMT+8, 2025-5-19 10:29 , Processed in 0.193587 second(s), 29 queries , Gzip On.
