查看: 2285|回复: 8
求USER2128 大师或路过的高手修改下,标注好的坐标输出txt文件
发表于 2012-11-21 00:59:34 | 显示全部楼层 |阅读模式
1明经币
原贴位置:
http://bbs.mjtd.com/thread-99227-1-1.html
原程序已经很好用,但是加上如下两个就非常完美了~~~
1、修改内容,在引线端头位置,在图上标上编号
2、输出样式修改如下:
                   X                    Y
          1,2887794317,452867597
          2,2887800389,452875288
这个前面的序号与图上标注的编号是一样的。。。。麻烦了谢谢
发表于 2012-11-21 00:59:35 | 显示全部楼层
  1. ;;; 标注好的坐标输出TXT格式:
  2. ;;; 输出样式:
  3. ;;;    X值         Y值
  4. ;;; 1, 87753.815, 52860.248
  5. ;;; 2, 2887765.655, 452850.981
  6. (defun c:tt ( / ss n info ent txt pt t_h tmp tmp1 tmp2 f_n f_op)
  7.   (setq ss (ssget '((0 . "TEXT") (1 . "X=*,x=*"))))
  8.   (setq n 0)
  9.   (setq info '())
  10.   (repeat (if ss (sslength ss) 0)
  11.     (setq ent (entget (ssname ss n))
  12.           txt (cdr (assoc 1 ent))
  13.           pt  (cdr (assoc 10 ent))
  14.           t_h (cdr (assoc 40 ent))
  15.           )
  16.     (setq info (append info (list (list pt txt t_h))))
  17.     (setq n (1+ n))
  18.     )
  19. ;  (command "_.zoom" "_e")
  20.   (setq info (mapcar '(lambda(x)
  21.     (progn (setq tmp (car x))
  22.       (setq tmp1 (mapcar '(lambda(y) (- y (caddr x))) tmp)
  23.             tmp2 (mapcar '(lambda(y) (+ y (caddr x))) tmp))
  24.       (and (setq ss_tmp (ssget "c" tmp1 tmp2 '((0 . "TEXT") (1 . "Y=*,y=*"))))
  25.            (setq tmp (cdr (assoc 1 (entget (ssname ss_tmp 0)))))
  26.            (setq x (list (car x) (cadr x) tmp))
  27.            )
  28.       x)) info))
  29.   (setq info (vl-sort info '(lambda (x y) (< (caar  x) (caar  y)))))
  30.   (setq info (vl-sort info '(lambda (x y) (< (cadar x) (cadar y)))))
  31.   (setq f_n  (getvar "DWGname")
  32.         f_n  (strcat (substr f_n 1 (- (strlen f_n) 4)) ".txt")
  33.         f_n  (strcat (getvar "DWGPREFIX") f_n)
  34.         )
  35.   (setq n 0)
  36.   (setq f_op (open f_n "w"))
  37.   (princ "     X 值       Y 值\n" f_op)
  38.   (mapcar '(lambda(x)
  39.              (princ (strcat (itoa (setq n (1+ n))) ", ") f_op)
  40.              (princ (substr (cadr  x) 3) f_op)
  41.              (princ ", " f_op)
  42.              (princ (substr (caddr x) 3) f_op)
  43.              (princ "\n" f_op)
  44.              ) info)
  45.   (close f_op)
  46.   (princ)
  47.   )
麻烦大师更改成原来的坐标排序,发现原来的排序好~  发表于 2012-11-21 11:20
 楼主| 发表于 2012-11-21 11:19:04 | 显示全部楼层
大师麻烦帮我更改成原来的排序。。不好意思。。原来的排序更好~~~
 楼主| 发表于 2012-11-21 11:42:39 来自手机 | 显示全部楼层
大师编号能不能标在图纸上啊麻烦了
发表于 2012-11-21 11:55:20 | 显示全部楼层
原程序是无序的,还是有些不妥。标至图中,等我下班后帮弄
 楼主| 发表于 2012-11-21 15:17:38 来自手机 | 显示全部楼层
谢谢兄弟了
发表于 2012-11-21 16:03:21 | 显示全部楼层
;;; 标注好的坐标输出到: 与DWG文件同目录、同名的TXT文件中;
;;; 输出样式:
;;;    X值         Y值
;;; 将编号1、2、... 写到图中.
为表示点辛苦费,附件要收1个明经币(抱歉)
真的无敌强大。。高手中的高手。。谢谢。。  发表于 2012-11-21 17:50
 楼主| 发表于 2012-11-21 17:50:47 | 显示全部楼层
谢谢 USER2128 老大。。这程序真的太强大了谢谢~
发表于 2013-8-25 07:47:35 | 显示全部楼层
;;; 输出样式:
;;;    X值         Y值
下载了,在04版运行
错误 : 参数类型错误: lentityp nil
为什么?
估计是标注的格式不一致,你可以参考楼主提供的DWG文件中的格式,适当修改一下程序,以便能检测到你的图中“标注文字(如X=***,Y=***)”  发表于 2013-8-25 13:52
GMT+8, 2025-5-19 15:42 , Processed in 0.242545 second(s), 32 queries , Gzip On.
