查看: 1705|回复: 8
那位高手把smartstar兄的 弯头程序给改一下
发表于 2012-11-22 12:35:12 | 显示全部楼层 |阅读模式
那位高手把smartstar兄的 弯头程序给改一下,弯头的内弯默认应该是管的三分之一大小,而他的程序内弯默认是管的是二分之一大小.不太理想,以下是smartstar兄的程序
(defun c:ddd (/   ip1 ip2 ip3 la  a   co  e   a1  d1  d2  d3  dn  p
       li  l1  l2  l3  l4  l5  l6  lt  i   m1  n1  m2  n2  m3
       n3  r   f   a   b   c   x   y   z
  (setvar "cmdecho" 0)
  (setq a (ssget))
  (setq n (sslength a))
  (cond ((= n 6)
  (setq i 1)
  (setq pt0 (getpoint "请选择倒角方向点:"))
  (setq p (trans pt0 1 0))
  (setq d1 (dis (ssname a 0)))
  (setq a1 (ang (ssname a 0)))
  (setq m1 0
        n1 100
        m2 100
        n2 100
        m3 100
        n3 100
  (repeat 5
    (sort i)
    (setq i (1+ i))
  (setq l1 (ssname a m1))
  (setq l2 (ssname a n1))
  (setq l3 (ssname a m2))
  (setq l4 (ssname a n2))
  (setq l5 (ssname a m3))
  (setq l6 (ssname a n3))
  (setq la (cdr (assoc 8 (entget l1))))
  (setq co (cdr (assoc 62 (entget l1))))
  (setq lt (cdr (assoc 6 (entget l1))))
  (setq a (cdr (assoc 10 (entget l1))))
  (setq b (cdr (assoc 11 (entget l1))))
  (setq c (cdr (assoc 10 (entget l5))))
  (setq x (cdr (assoc 10 (entget l2))))
  (setq y (cdr (assoc 11 (entget l2))))
  (setq z (cdr (assoc 10 (entget l6))))
  (setq ip1 (pinter l1 l2))
  (setq ip2 (pinter l3 l4))
  (setq ip3 (pinter l5 l6))
  (setq
    d1 (abs (* (sin (- (angle a b) (angle a c))) (distance a c)))
  (setq
    d2 (abs (* (sin (- (angle x y) (angle x z))) (distance x z)))
  (if (<= d1 d2)
    (setq r1 (/ d1 2))
    (setq r1 (/ d2 2))
  (setq
    r
     (getdist (strcat "\n请输入倒角半径【增大一倍输入"(rtos (* r1 2) 2)"】<"  (rtos r1 2)">:")
  (if (= r nil)
    (setq r r1)
  (lu l1 ip1)
  (lu l2 ip1)
  (lu l3 ip2)
  (lu l4 ip2)
  (lu l5 ip3)
  (lu l6 ip3)
  (if (<= d1 d2)
      (setq d3 (+ (/ d1 2) r))
      (setq f (+ d1 r))
      (setq d3 (+ (/ d2 2) r))
      (setq f (+ d2 r))
  (setvar "filletrad" r)
  (command "fillet" l1 l2)
  (setq j (entget (entlast)))
  (setvar "filletrad" d3)
  (command "fillet" l3 l4)
  (setvar "filletrad" f)
  (command "fillet" l5 l6)
  (setq k (entget (entlast)))
  (command "line"
    (trans (polar (cdr (assoc 10 j))
    (cdr (assoc 50 j))
    (cdr (assoc 40 j))
    0
    1
    (trans (polar (cdr (assoc 10 k))
    (cdr (assoc 50 k))
    (cdr (assoc 40 k))
    0
    1
  (setq li (ssadd))
  (setq li (ssadd (entlast) li))
  (command "line"
    (cdr (assoc 51 j))
    (cdr (assoc 40 j))
    0
    1
    (cdr (assoc 51 k))
    (cdr (assoc 40 k))
    0
    1
  (COMMAND "chprop" li "" "la" la "")
  (if (= co nil)
    (command "chprop" li "" "c" "bylayer" "")
    (command "chprop" li "" "c" co "")
  (if (= lt nil)
    (command "chprop" li "" "lt" "bylayer" "")
    (command "chprop" li "" "lt" lt "")
((= n 4)
  (setq i 1)
  (setq m1 0
        n1 100
        m2 100
        n2 100
  (repeat 3
    (sort i)
    (setq i (1+ i))
  (setq c (cdr (assoc 10 (entget l3))))
  (setq z (cdr (assoc 10 (entget l4))))
  (setq
  (setq
  (if (<= d1 d2)
    (setq r1 (/ d1 2))
    (setq r1 (/ d2 2))
  (setq
    r
  (if (= r nil)
    (setq r r1)
  (lu l1 ip1)
  (lu l2 ip1)
  (lu l3 ip2)
  (lu l4 ip2)
  (if (<= d1 d2)
    (setq f (+ d1 r))
    (setq f (+ d2 r))
  (command "line"
    (cdr (assoc 50 j))
    (cdr (assoc 40 j))
    0
    1
    (cdr (assoc 50 k))
    (cdr (assoc 40 k))
    0
    1
  (setq li (ssadd))
  (command "line"
    (cdr (assoc 51 j))
    (cdr (assoc 40 j))
    0
    1
    (cdr (assoc 51 k))
    (cdr (assoc 40 k))
    0
    1
  (if (= co nil)
  (if (= lt nil)
(t (princ "\n选择的线数目不对"))
(defun sort(i / ai e de)
  (setq e (ssname a i))
  (setq ai (ang e))
  (setq de (dis e))
  (if (or (equal ai a1 0.1) (equal ai (- pi a1) 0.1))
      (if (< d1 de)
          (if (< m2 100)
              (if (< (dis (ssname a m2)) de)
                  (setq m3 i)
                  (progn (setq m3 m2)
                         (setq m2 i)
              (setq m2 i)
          (progn (setq d1 de)
                 (setq m3 m2)
                 (setq m2 m1)
                 (setq m1 i)
      (if (< n1 100)
          (if (< dn de)
              (if (< n2 100)
                  (if (< (dis (ssname a n2)) de)
                      (setq n3 i)
                      (progn (setq n3 n2)
                             (setq n2 i)
                  (setq n2 i)
              (progn (setq dn de)
                     (setq n3 n2)
                     (setq n2 n1)
                     (setq n1 i)
          (progn (setq n1 i)
                 (setq dn de)
(defun dis(a / pa pb)
  (setq pa (cdr (assoc 10 (entget a))))
  (setq pb (cdr (assoc 11 (entget a))))
  (abs (* (sin (- (angle pa pb) (angle pa p))) (distance pa p)))
(defun pinter(l1 l2 / ip)
  (setq ip (inters (cdr (assoc 10 (entget l1))) (cdr (assoc 11 (entget l1))) (cdr (assoc 10 (entget l2))) (cdr (assoc 11 (entget l2))) nil))
(defun lu(l ip / j k pa pb ang ang1 ang2)
  (setq j (entget l))
  (setq pa (cdr (assoc 10 j)))
  (setq pb (cdr (assoc 11 j)))
  (setq ang1 (angle pa pb))
  (setq ang2 (angle p ip))
  (setq ang (abs (- ang1 ang2)))
  (if (or (< ang (/ pi 2)) (> ang (* pi 1.5)))
      (setq k (subst (cons 11 ip) (assoc 11 j) j))
      (setq k (subst (cons 10 ip) (assoc 10 j) j))
  (entmod k)
(defun ang (a / pa pb)
  (rem (angle pa pb) pi)
 楼主| 发表于 2012-11-23 00:29:15 | 显示全部楼层
可能由于代码太长,唯恐只有smartstar兄方可改之呀
发表于 2012-11-23 15:08:44 | 显示全部楼层
把这里 (if (<= d1 d2)     (setq r1 (/ d1 2))     (setq r1 (/ d2 2))   )改成 (if (<= d1 d2)     (setq r1 (/ d1 3))     (setq r1 (/ d2 3))   )就得了
 楼主| 发表于 2012-11-24 15:30:12 | 显示全部楼层
唉,还真是哦,高人,可不可以不用  "请选择倒角方向点"这一项直接默认为内弯弯就行了,在何处改,不吝赐教,
 楼主| 发表于 2012-11-26 12:27:38 | 显示全部楼层
惜惜惜惜惜惜惜
   waterchen smartstar还有其它高手都不在线,
故无人赐教
 楼主| 发表于 2012-11-27 12:25:26 | 显示全部楼层
那位高手路过稍带看能不能改一下哦,
发表于 2012-12-5 17:45:11 | 显示全部楼层
本图程序精度更高:
 楼主| 发表于 2012-12-6 12:24:51 | 显示全部楼层
唉,真是高呀高不可及呀,是高
发表于 2013-5-17 13:29:45 | 显示全部楼层
求助: 拿楼主提供的smartstar的程序改了一下,1/3弯头大小及提示.
发现新的问题,点选方向不能随便点. 见上图所示,在中间直线区域任意点都能生成弯头
在点1处不能. 求解决的办法
GMT+8, 2025-5-30 01:14 , Processed in 0.211403 second(s), 31 queries , Gzip On.
