- 积分
- 66525
- 明经币
- 个
- 注册时间
- 2010-5-9
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
;;有时候,我们并不希望别人修改我们的图纸,说起原因,那就是一段伤心的往事了。
;;今在网上下载了一个程序,试了一下,还行。其原理我不知道。但操作起来很麻烦,得不断
;;回答Yes/No,于是我去掉了许多选项,一键搞定,大家看看这样的修改行不行?
;;原程序
 - ;;;Lockup.lsp - Locks all selected entities (except proxy objects) within a drawing.
- ;;;By: John D. Chapman
- ;;;With help from: Stig Madsen, Celie Dailey, Pat Starkey.
- ;;;Based on and expanded from AB.lsp by Brian Debelius (Make/Insert an Anonymous Block)
- ;;;and AB-Minsert.lsp by Rick McElvain (Make/MINSERT an Anonymous Block).
- ;;;Inspiration from Adam Conrath (MINSERT).
- ;;;Special mention to Jim Fisher.
- ;;;Last Revisions:
- ;;;March 5, 2002: - Separate block made of solids before main routine runs.
- ;;;March 7, 2002: - Separate Block made of background colours (8,9,251-255).
- ;;;March 22, 2002: - Improved error trapping.
- ;;;This routine turns on, thaws, and unlocks all layers before it starts the lock.
- ;;;The state of your layers prior to running LOCKUP will be restored
- ;;;in AutoCAD 2000i only.
- ;;;_______________________________________________________________________________________
- (alert
- "\nDO NOT RUN LOCKUP ON AN ORIGINAL DRAWING.
- \n RUN ONLY ON A COPY OF THE ORIGINAL."
- (alert
- "\nLockup2.lsp - By John D. Chapman - Ainley and Associates Ltd.
- \n with thanks to Brian Debelius, Adam Conrath, Rick McElvain,
- \n Stig Madsen, Celie Dailey, Pat Starkey, Jim Fisher
- \n and the Autodesk User Group International."
- (defun lockerror (msg)
- (if (/= msg "Function cancelled")
- (princ
- (strcat "\nError: " msg " [" (itoa (getvar "ERRNO")) "]")
- (princ)
- (command "UNDO" "End")
- (Abort "\nLockup was interrupted. Function Aborted!")
- (setq *error* olderr)
- (princ)
- (defun Abort (msg)
- (setvar "filedia" fdia)
- (setvar "cmddia" cdia)
- (setvar "cmdecho" cmd)
- (alert msg)
- ;;Exit
- (defun getlayers ()
- (setq lyr (tblnext "layer" t))
- (setq laylist "")
- (while lyr
- (if (or (and (= (cdr (assoc 62 lyr)) 8)
- (not (wcmatch (cdr (assoc 2 lyr)) "*|*"))
- (and (= (cdr (assoc 62 lyr)) 9)
- (and (= (cdr (assoc 62 lyr)) 251)
- (and (= (cdr (assoc 62 lyr)) 252)
- (and (= (cdr (assoc 62 lyr)) 253)
- (and (= (cdr (assoc 62 lyr)) 254)
- (and (= (cdr (assoc 62 lyr)) 255)
- (if (equal laylist "")
- (setq laylist (strcat laylist (cdr (assoc 2 lyr))))
- (setq laylist (strcat laylist "," (cdr (assoc 2 lyr))))
- (setq lyr (tblnext "layer"))
- laylist
- (defun backblk (layoutName Mins)
- (if layoutName
- (cond
- ((= layoutName "14MS")
- (setq blist (list '(-4 . "<NOT")
- '(-4 . "<OR")
- '(67 . 1)
- '(0 . "SOLID")
- '(2 . "SOLID")
- '(-4 . "OR>")
- '(-4 . "NOT>")
- '(-4 . "<OR")
- (cons 8 (getlayers))
- '(62 . 8)
- '(62 . 9)
- '(62 . 251)
- '(62 . 252)
- '(62 . 253)
- '(62 . 254)
- '(62 . 255)
- '(-4 . "OR>")
- ((= layoutName "14PS")
- (setq blist (list '(67 . 1)
- '(-4 . "<NOT")
- '(-4 . "<OR")
- '(0 . "SOLID")
- '(2 . "SOLID")
- '(0 . "VIEWPORT")
- '(-4 . "OR>")
- '(-4 . "NOT>")
- '(-4 . "<OR")
- '(62 . 8)
- '(62 . 9)
- '(62 . 251)
- '(62 . 252)
- '(62 . 253)
- '(62 . 254)
- '(62 . 255)
- '(-4 . "OR>")
- (T
- (setq blist (list (cons 410 layoutName)
- '(-4 . "<NOT")
- '(-4 . "<OR")
- '(0 . "SOLID")
- '(2 . "SOLID")
- '(0 . "VIEWPORT")
- '(-4 . "OR>")
- '(-4 . "NOT>")
- '(-4 . "<OR")
- '(62 . 8)
- '(62 . 9)
- '(62 . 251)
- '(62 . 252)
- '(62 . 253)
- '(62 . 254)
- '(62 . 255)
- '(-4 . "OR>")
- '(-4 . "<OR")
- '(0 . "SOLID")
- '(2 . "SOLID")
- '(0 . "VIEWPORT")
- '(-4 . "OR>")
- '(-4 . "NOT>")
- '(-4 . "<OR")
- '(62 . 8)
- '(62 . 9)
- '(62 . 251)
- '(62 . 252)
- '(62 . 253)
- '(62 . 254)
- '(62 . 255)
- '(-4 . "OR>")
- (setq ssetb (ssget "X" blist))
- (setq viewsset (ssget "X" '((0 . "VIEWPORT"))))
- (if viewsset
- (progn
- (setq n 0)
- (repeat (sslength viewsset)
- (if (setq clipent (assoc 340 (entget (ssname viewsset n))))
- (ssdel (cdr clipent) ssetb)
- (setq n (1+ n))
- (if ssetb
- (progn
- (setq pt (list 0.0 0.0))
- (entmake ;;write block header
- (list '(0 . "BLOCK")
- '(2 . "*anon")
- '(70 . 1)
- (cons '10 pt)
- ;;add entities in selection set to block
- ;;repeat for every entity in the selection set
- (setq a 0)
- (repeat (sslength ssetb)
- (setq ent2 (entmake (entget (setq ent (ssname ssetb a)))))
- (if (null ent2)
- (princ (entget (setq ent (ssname ssetb a))))
- ;;if polyline or block reference with attributes,
- ;;walk down sub-entities until seqend is found
- (if (assoc 66 (entget ent))
- (progn
- ;;add sub-entities until seqend is found
- (setq subent (entnext ent))
- (while (/= (cdr (assoc 0 (entget subent))) "SEQEND")
- (entmake (entget subent))
- (setq subent (entnext subent))
- ;;add seqend sub-entity
- (setq ent3 (entmake (entget subent)))
- (if (null ent3)
- (princ (entget subent))
- ;;delete original entity
- (entdel ent)
- (setq a (1+ a))
- (c:spin "Making Block of background colours..")
- (setq nameb (entmake '((0 . "endblk"))))
- ;;write block end sub-entity
- (princ "\n Inserting...\n")
- ;; Insert block reference at insertion point
- ;; Note: Check the argument Mins for the method to insert the block
- ;; Note: Mins=T means minsert the block, and Mins=nil means insert it.
- (if Mins
- ;;Minsert block reference at insertion point
- (entmake
- (list '(0 . "INSERT")
- (CONS '100 "AcDbMInsertBlock")
- (CONS '70 2)
- (CONS '71 2)
- (cons '2 nameb)
- (cons '10 pt)
- (entmake
- (cons '2 nameb)
- (cons '10 pt)
- ;;Insert block reference at insertion point
- (setq bc (entlast))
- (setq bac "back")
- (command "_.draworder" bc "" (strcat "_" bac))
- (setq ssetb nil)
- (setq viewsset nil)
- (princ)
- (defun solidblk (layoutName Mins)
- (if layoutName
- (cond
- (setq slist (list '(-4 . "<NOT") '(67 . 1)
- '(-4 . "NOT>") '(-4 . "<OR")
- '(0 . "SOLID") '(2 . "SOLID")
- '(-4 . "OR>")
- (setq slist (list '(67 . 1) '(-4 . "<OR") '(0 . "SOLID") '(2 . "SOLID")
- '(-4 . "OR>"))
- (T
- (setq slist (list (cons 410 layoutName)
- '(-4 . "<OR")
- '(0 . "SOLID")
- '(2 . "SOLID")
- '(-4 . "OR>")
- (setq slist (list '(-4 . "<OR")
- '(0 . "SOLID")
- '(2 . "SOLID")
- '(-4 . "OR>")
- (setq ssets (ssget "X" slist))
- (if ssets
- (progn
- '(2 . "*anon")
- '(70 . 1)
- (cons '10 pt)
- (setq a 0)
- (repeat (sslength ssets)
- (setq ent2 (entmake (entget (setq ent (ssname ssets a)))))
- (if (null ent2)
- (princ (entget (setq ent (ssname ssets a))))
- (progn
- (if (null ent3)
- (entdel ent)
- (setq a (1+ a))
- (c:spin "Making Block of solids..")
- (setq names (entmake '((0 . "endblk"))))
- (if Mins
- (entmake
- (CONS '70 2)
- (CONS '71 2)
- (cons '2 names)
- (cons '10 pt)
- (entmake
- (cons '2 names)
- (cons '10 pt)
- (setq so (entlast))
- (setq ba "back")
- (command "_.draworder" so "" (strcat "_" ba))
- (setq ssets nil)
- (princ)
- (defun anonBlock (layoutName Mins)
- (if layoutName
- (cond
- (setq alist (list '(-4 . "<NOT")
- '(-4 . "<OR")
- '(67 . 1)
- '(0 . "ACAD_PROXY_ENTITY")
- '(0 . "AEC_*")
- '(0 . "AECS_*")
- '(0 . "RTEXT")
- '(0 . "WIPEOUT")
- ;;'(8 . "LAYCFG")
- (0 . "SOLID")
- '(2 . "SOLID")
- '(62 . 8)
- '(62 . 9)
- '(62 . 251)
- '(62 . 252)
- '(62 . 253)
- '(62 . 254)
- '(62 . 255)
- '(-4 . "OR>")
- '(-4 . "NOT>")
- (setq alist (list '(67 . 1)
- '(-4 . "<NOT")
- '(-4 . "<OR")
- '(0 . "VIEWPORT")
- '(0 . "AEC_*")
- '(0 . "AECS_*")
- '(0 . "RTEXT")
- '(0 . "WIPEOUT")
- ;;'(8 . "LAYCFG")
- (0 . "SOLID")
- '(2 . "SOLID")
- '(62 . 8)
- '(62 . 9)
- '(62 . 251)
- '(62 . 252)
- '(62 . 253)
- '(62 . 254)
- '(62 . 255)
- '(-4 . "OR>")
- '(-4 . "NOT>")
- (T
- (setq alist (list (cons 410 layoutName)
- '(-4 . "<NOT")
- '(-4 . "<OR")
- ;;'(8 . "LAYCFG")
- (0 . "VIEWPORT")
- '(0 . "AECC_*")
- '(0 . "AEC_*")
- '(0 . "AECS_*")
- '(0 . "RTEXT")
- '(0 . "WIPEOUT")
- '(0 . "SOLID")
- '(2 . "SOLID")
- '(62 . 8)
- '(62 . 9)
- '(62 . 251)
- '(62 . 252)
- '(62 . 253)
- '(62 . 254)
- '(62 . 255)
- '(-4 . "OR>")
- '(-4 . "NOT>")
- '(-4 . "<OR")
- ;;'(8 . "LAYCFG")
- (0 . "VIEWPORT")
- '(0 . "AECC_*")
- '(0 . "AEC_*")
- '(0 . "AECS_*")
- '(0 . "RTEXT")
- '(0 . "WIPEOUT")
- '(0 . "SOLID")
- '(2 . "SOLID")
- '(62 . 8)
- '(62 . 9)
- '(62 . 251)
- '(62 . 252)
- '(62 . 253)
- '(62 . 254)
- '(62 . 255)
- '(-4 . "OR>")
- '(-4 . "NOT>")
- (setq sset (ssget "X" alist))
- (if viewsset
- (progn
- (setq n 0)
- (ssdel (cdr clipent) sset)
- (setq n (1+ n))
- (if sset
- (progn
- '(2 . "*anon")
- '(70 . 1)
- (cons '10 pt)
- (setq a 0)
- (repeat (sslength sset)
- (setq ent2 (entmake (entget (setq ent (ssname sset a)))))
- (if (null ent2)
- (princ (entget (setq ent (ssname sset a))))
- (progn
- (if (null ent3)
- (entdel ent)
- (setq a (1+ a))
- (c:spin "Making Block..")
- (setq name (entmake '((0 . "endblk"))))
- (princ "\n Inserting Block..\n")
- (if Mins
- (entmake
- (CONS '70 2)
- (CONS '71 2)
- (cons '2 name)
- (cons '10 pt)
- (entmake
- (cons '2 name)
- (cons '10 pt)
- (setq sset nil)
- ;; Note: This statement is just a debug string and can be deleted
- (if layoutName
- (princ (strcat "\nNo entities to lock in " layoutName))
- (princ)
- (defun Finish (vers)
- (setvar "clayer" cla)
- (setvar "tilemode" space)
- (if (= vers 2)
- (command "-layer" "state" "restore" "lockup" "" "")
- (command "-layer" "lock" "*" "")
- (setvar "proxyshow" 1)
- (command "regen")
- (cond
- ((= cont "Yes")
- (alert
- "\nPaper space only has been locked.
- \nTo lock model space, run Lockup
- \nagain and do NOT skip to paper space."
- ((= answer2 "Model")
- (alert "\nAll selected entities have been locked.")
- ((= answer2 nil)
- (setq cont nil
- answer2 nil
- (princ "\nLockup has completed. ")
- (princ)
- ;;; Note:
- ;;; Separate routine still for r14, because paper space is a whole different
- ;;; ballgame in later versions. It supplies the keyword "14PS" to be recognized
- ;;; by anonBlock in order to select all entities that have group code 67 = 1
- (defun goLock14PS ()
- (setvar "tilemode" 0)
- (proxy)
- (anonBlock "14PS" nil) ; make anon insert - on paper space
- (backblk "14PS" nil) ; make anon insert - on paper space
- (solidBlk "14PS" nil) ; make anon insert - on paper space
- (anonBlock "14PS" T) ; make anon minsert - on paper space
- (command "zoom" "extents")
- (prompt "\n Paper Space has been locked.")
- (Finish 0)
- (defun goLockPS (vers)
- (if (= vers 0)
- (goLock14PS)
- (progn
- (princ "\nType in Layout Name to make current: ")
- (command "layout" "set" pause) ;type in whatever layout to set current
- (while (> (getvar "cmdactive") 0) (command pause))
- (proxy)
- (anonBlock (getvar "CTAB") nil) ; make anon insert in named layout
- (backblk (getvar "CTAB") nil) ; make anon insert in named layout
- (solidblk (getvar "CTAB") nil) ; make anon insert in named layout
- (anonBlock (getvar "CTAB") T) ; make anon minsert in named layout
- (initget "Yes No")
- (prompt
- (strcat "\n Layout " (getvar "ctab") " has been locked.")
- (setq answer
- (getkword "\nAre there more layouts to lock? Y/<N>: ")
- (cond
- ((or (null answer) (= answer "No"))
- (Finish vers)
- ((= answer "Yes")
- (goLockPS vers)
- (T nil)
- (defun goLock (vers)
- (setvar "tilemode" 1)
- (if (= vers 2)
- (command "-layer" "state" "save" "lockup" "" "" "")
- (command "-layer" "thaw" "*" "on" "*" "unlock" "*" "")
- (proxy)
- (if (/= vers 0)
- (progn
- (anonBlock "Model" nil) ; make anon insert in model space
- (backblk "Model" nil) ; make anon insert in model space
- (solidblk "Model" nil) ; make anon insert in model space
- (anonBlock "Model" T) ; make anon minsert in model space
- (progn
- (anonBlock "14MS" nil)
- (backblk "14MS" nil)
- (solidblk "14MS" nil)
- (anonBlock "14MS" T)
- (prompt "\n Model Space has been locked.")
- (setq answer
- (getkword "\nDo you want to lock Paper Space? Y/<N>: ")
- (cond
- ((or (null answer) (= answer "No")) (Finish vers))
- ((= answer "Yes") (goLockPS vers))
- (T nil)
- (defun states ()
- (if (= vers 2)
- (command "graphscr")
- (goLockps vers)
- (defun continue ()
- (setq cont (getkword
- "\nModel Space will not be locked! Continue? Y/<N>: "
- (cond ((= cont "Yes") (states))
- ((= cont "No") (skip))
- ((= cont nil) (skip))
- (defun skip ()
- (initget "Skip Model")
- (setq answer2
- (getkword
- "\nStart in Model Space or Skip to Paper Space? Skip/<Model>:"
- (cond ((= answer2 "Skip") (continue))
- ((= answer2 "Model") (goLock vers))
- ((= answer2 nil) (goLock vers))
- (defun 14or2k (/ answer)
- (initget "14 2000 2000i")
- (setq answer
- (getkword
- "\nWhat version of AutoCAD are you in? 14/2000<2000i>: "
- (cond
- ((= answer "14") (setq vers 0))
- ((= answer "2000") (setq vers 1))
- ((= answer "2000i") (setq vers 2))
- ((= answer nil) (setq vers 2))
- (skip)
- (defun goexp ()
- (progn
- (command "_explode" (ssname sset CNT))
- (setq CNT (1+ CNT))
- (c:spin "Exploding..")
- (alert (strcat "\n " (itoa CNT) " Entities Exploded."))
- (setq sset nil)
- (princ)
- (defun xpproxy (/ xpl)
- (alert
- "\n Proxy Entities have been found.
- If they are not exploded, they will
- be omitted from the lockup process."
- (setq xpl (getkword "\nExplode Proxy Entities? Y/<N>: "))
- (if (or (= xpl "No") (= xpl nil))
- (princ)
- (if (= xpl "Yes")
- (goexp)
- (princ)
- (defun goerase ()
- (progn
- (repeat (sslength wsset)
- (entdel (ssname wsset WCNT))
- (setq WCNT (1+ WCNT))
- (c:spin "Erasing..")
- (alert (strcat "\n " (itoa WCNT) " Wipeouts Erased."))
- (setq wsset nil)
- (princ)
- (defun goaskerase (/ del)
- (alert
- "\n Wipeouts have been found."
- (setq del (getkword "\nErase Wipeouts? Y/<N>: "))
- (if (or (= del "No") (= del nil))
- (princ)
- (if (= del "Yes")
- (goerase)
- (princ)
- (defun gowipeout (/ where wlist)
- (setq where (getvar "tilemode"))
- (setq cs 67)
- (if (= where 0)
- (setq sp 1)
- (if (= where 1)
- (setq sp 0)
- (setq wlist (list (cons cs sp)
- '(0 . "wipeout")
- (setq WCNT 0)
- (setq wsset (ssget "x" wlist))
- (if (= wsset nil)
- (princ)
- (if (not (= wsset nil))
- (goaskerase)
- (princ)
- (defun proxy (/ where plist)
- (if (= where 0)
- (setq plist '((-4 . "<NOT")
- (67 . 0)
- (-4 . "NOT>")
- (-4 . "<OR")
- (0 . "ACAD_PROXY_ENTITY")
- (0 . "AECC_*")
- (0 . "AEC_*")
- (0 . "AECS_*")
- (0 . "RTEXT")
- (-4 . "OR>")
- (if (= where 1)
- (67 . 1)
- (-4 . "NOT>")
- (-4 . "<OR")
- (0 . "AECC_*")
- (0 . "AEC_*")
- (0 . "AECS_*")
- (0 . "RTEXT")
- (-4 . "OR>")
- (setq CNT 0)
- (setq sset (ssget "x" plist))
- (if (= sset nil)
- (princ)
- (if (not (= sset nil))
- (xpproxy)
- (gowipeout)
- (princ)
- (defun c:undolock ()
- ;;Undo and Reset variables
- (setvar "cmdecho" 0)
- (princ "\nPlease wait while Lockup is undone.")
- (command "undo" "end")
- (command "undo" "back")
- (setvar "cmdecho" 1)
- (setvar "filedia" 1)
- (setvar "cmddia" 1)
- (princ "\nLockup has been undone.")
- (princ)
- (defun c:look (/ alist CNT sset)
- (setq alist '((-4 . "<OR")
- (0 . "AECC_*")
- (0 . "AEC_*")
- (0 . "AECS_*")
- (0 . "RTEXT")
- (0 . "WIPEOUT")
- (-4 . "OR>")
- (setq CNT 0)
- (if alist
- (progn
- (if sset
- (if (= CNT 1)
- (alert (strcat "\n " (itoa CNT) " Entity found."))
- (if (> CNT 1)
- (alert (strcat "\n " (itoa CNT) " Entities found."))
- (if (= sset nil)
- (alert "\nNo Entities were found.")
- (princ)
- (defun c:spin (wh)
- (prompt (strcat "\r "
- wh
- (cond ((= sp "|") (setq sp "/"))
- ((= sp "/") (setq sp "-"))
- ((= sp "-") (setq sp "\\"))
- (T (setq sp "|"))
- (princ)
- (defun C:Lockup (/ start answer)
- (setq fdia (getvar "filedia")
- cdia (getvar "cmddia")
- cmd (getvar "cmdecho")
- cla (getvar "clayer")
- space (getvar "tilemode")
- olderr *error*
- *error* lockerror
- cont nil
- answer2 nil
- (command "UNDO" "Begin")
- (setvar "filedia" 0)
- (setvar "cmddia" 0)
- (command "undo" "mark")
- (command "-layer" "make" "LOCKUP" "")
- (command "color" "bylayer")
- (setvar "proxyshow" 0)
- (command "regen")
- (setq answer
- (getkword
- "\nThis routine will lock the drawing! Do you really want to proceed? Y/<N>: "
- (cond
- ((or (= answer "No") (null answer))
- (Alert "LOCKUP aborted!")
- ((= answer "Yes") (14or2k))
- (princ)
- (princ "\nLOCKUP is loaded.")
- (princ "\nType LOCKUP to start.")
- (princ)
