查看: 1489|回复: 1
求帮忙偏移在2007正常使用到2010偏移的线有时不见了
发表于 2012-12-7 23:21:08 | 显示全部楼层 |阅读模式
(DEFUN C:Y (/ DD DISP PT SS)
(SETVAR "CMDECHO" 0)
(SETQ DISP (IF (< (GETVAR "OFFSETDIST") 0)
"通过"
(RTOS (GETVAR "OFFSETDIST") 2 3)
(INITGET "Through")
(SETQ DD (GETDIST (STRCAT "\n指定偏移距离或[通过(T)]<" DISP ">")))
(SETVAR "OFFSETDIST"
(IF (= DD "Through")
-1
(IF DD
DD
(while (SETQ SS (ENTSEL "\n选择要偏移的对象或 <退出>:"))
(PROGN
(SETQ PT (GETPOINT (IF (< (GETVAR "OFFSETDIST") 0)
"\n指定通过点:"
"\n指定偏移方向:"
(COMMAND "OFFSET" "" (CADR SS) PT "" "ERASE" (CAR SS) "")
(PRINC)
 楼主| 发表于 2012-12-8 07:08:50 | 显示全部楼层
自己先顶一下 求高手出招了
GMT+8, 2025-6-4 02:20 , Processed in 0.252285 second(s), 34 queries , Gzip On.
