查看: 2212|回复: 0
用lisp读取txt文件
发表于 2012-12-17 10:25:30 | 显示全部楼层 |阅读模式
闭合多段线的填充调用 能否把读取调用的两个文件合并成一个单一的文件 并读取 调用 成功
合并 调用
  1. (defun c:ttb()
  2.   (setvar "cmdecho" 0)
  3.   (setvar "osmode" 0)
  4.   (setq xb (getreal "\n输入线性比例<1>"))
  5.   (setq hlst '())
  6.   (setq cf (open "c:\\LSPTOOLS\\tba.txt" "r"))
  7.   (setq sele (read-line cf))
  8.     (while sele
  9.       (setq hlst (cons sele hlst))
  10.       (setq sele (read-line cf))
  11.     )
  12.     (close cf)
  13.     (setq data_list '())
  14.     (setq ff (open "c:\\LSPTOOLS\\ttch.txt" "r"))
  15.     (setq data (read (read-line ff)))
  16.     (while data
  17.       (setq data (* xb data))
  18.       (setq data_list (cons data data_list))
  19.       (setq data (read (read-line ff)))
  20.     )
  21.     (close ff)
  22.   (if (setq ss (ssget '((0 . "*POLYLINE"))))
  23.     (progn
  24.       (setq i -1)
  25.       (command "layer" "m" "填充" "c" "52" "" "")
  26.         (repeat (sslength ss)
  27.           (setq en (ssname ss (setq i (1+ i))))
  28.           (setq huame (nth (rem i 16) hlst))
  29.           (setq bl (nth (rem i 16) data_list))
  30.           (command "_bhatch" "p" huame bl "0" "s" en "" "")
  31.         )
  32.         (prin1)
  33.     )
  34.   )
  35. )
复制代码
GMT+8, 2025-6-3 10:32 , Processed in 0.151619 second(s), 26 queries , Gzip On.
