- 积分
- 5699
- 明经币
- 个
- 注册时间
- 2006-12-19
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
用"裁切"搜索论坛相关的源码仅有3篇,一片是 xgr 写的局部复制的,还有一篇是裁外的,是半成品,而最后一片是半成品的简化版.好惨啊,但事实就是这样.我写的这个仅实现了裁内,裁外两个功能,有时还会出错,请大侠指点,有能力了加强到仿MicroStation---fance的效果,那就完结了.
还有看到高手老说扩展的acet函数,但代码看着真晕,哪位大侠把学习这些源码的经历,分享下,要怎么学.
 - (defun c:tt (/ AA E EL ELONG EN EO EPTL FX I LEN LST OLDBLIP OLDCMD OLDGROUP OLDPDMODE OLDSNAP OLONG
- ONE PT PTL PTLST PXMAX SS SSTEXT TEXT
- ;;功能:选择范围和方向点,裁内或裁外
- ;;局限:1.仅支持轻多段线范围,2.范围线不能打折
- ;;日期:wkq004@qq.com修改 2012-12-20
- ;;原程序来自明经通道by xgr 2007-8-30
- (command ".undo" "e")
- (command ".undo" "begin")
- (setvar "LUPREC" 8)
- (setq oldgroup (getvar "pickstyle")) ;保存编组开关
- (setvar "pickstyle" 0) ;关闭编组
- (setq oldcmd (getvar "cmdecho")) ;保存控制 command 函数运行期间,AutoCAD 是否回显提示和输入
- (setvar "cmdecho" 0) ;关闭command 函数运行期间,AutoCAD 回显提示和输入
- (setq oldblip (getvar "blipmode")) ;保存控制点标记
- (setvar "blipmode" 0) ;关闭点标记
- (setq oldpdmode (getvar "pdmode")) ;关闭点样式
- (setq oldsnap (getvar "osmode")) ;保存对象捕捉方式
- (setvar "osmode" 0) ;关闭对象捕捉式
- (while (or (if (setq en (nentselp "\n选择作为剪切边界的闭合多段线:"))
- nil
- (setq ss "空选择!")
- (if (= (cdr (assoc 0 (setq el (entget (setq e (car en)))))) "LWPOLYLINE")
- nil
- (setq ss "类型错误!")
- (if (= (logand (cdr (assoc 70 el)) 1) 1)
- nil
- (setq ss "线段不闭合!")
- (if (setq fx (getpoint "\n请选择裁切方向:"))
- nil
- (setq ss "选择裁切方向!")
- (alert (strcat "选择错误-" ss ",重新选择!"))
- (setq elong 0)
- (setq eptl '())
- (setq one (cdr (assoc 10 el)))
- (foreach pt el
- (if (= 10 (car pt))
- (setq pt (cdr pt)
- elong (+ elong (distance one pt))
- one pt
- eptl (cons pt eptl)
- (print "\n正在剪切图形,请稍侯......")
- (command ".offset" 0.1 e fx "");_原多段线上有重点,偏移后的线上应该没有重点吧?
- (setq eo (entlast))
- (setq el (entget eo))
- (command ".erase" eo "")
- (setq olong 0)
- (setq ptl '())
- (foreach pt el
- (setq pt (cdr pt)
- olong (+ olong (distance one pt))
- one pt
- ptl (cons pt ptl)
- (setq pxmax (list (apply 'mapcar (cons 'min ptl)) (apply 'mapcar (cons 'max ptl))))
- (command ".zoom" "w" (car pxmax) (cadr pxmax))
- (setq ptl (append ptl (list (car ptl))))
- ;;炸开相交的块,面域,填充图案
- (setq i 0)
- (while (and (setq ss (ssget "F" ptl '((0 . "INSERT,HATCH,REGION")))) (> 10000 (setq i (1+ i))))
- (repeat (setq len (sslength ss)) (command ".EXPLODE" (ssname ss (setq len (1- len)))))
- (setvar "pdmode" 0) ;_关闭点样式
- (setq lst '())
- (if (setq ss (ssget "f" ptl '((0 . "text,mtext"))))
- (setq text (ssname ss (setq len (1- len))))
- (setq pt (assoc 10 (entget text)))
- (entmake (list '(0 . "point") pt))
- (setq lst (cons (list (entlast) text) lst))
- ;;偏移线的长度小于原线长度,裁内否则裁外
- (if (< olong elong)
- ;;裁内
- (if (setq ss (ssget "wp" eptl))
- (command ".erase" ss "")
- ;;裁外
- (if (setq ss (ssget "cp" eptl))
- (command ".erase" "all" "r" ss "")
- (foreach potx lst
- (if (entget (car potx))
- (entdel (car potx))
- (entdel (cadr potx))
- (repeat 3
- (setq one (car ptl))
- (foreach two (cdr ptl) (command ".trim" e "" "f" one two "" "") (setq one two))
- ;;删除向内裁切矩形的对角线,考虑文本
- ;;处理有宽度的多段线
- ptl
- '((-4 . "<NOT")
- (-4 . "<or")
- (0 . "text,mtext,INSERT,HATCH,REGION")
- (-4 . "<and")
- (0 . "lwpolyline,polyline")
- (-4 . "<or")
- (-4 . ">")
- (40 . 0.0)
- (-4 . ">")
- (41 . 0.0)
- (-4 . "or>")
- (-4 . "and>")
- (-4 . "or>")
- (-4 . "NOT>")
- ;;裁内
- ;;裁外
- (command "zoom" "p") ;_恢复视窗大小
- (setvar "pickstyle" oldgroup)
- (setvar "cmdecho" oldcmd)
- (setvar "blipmode" oldblip)
- (setvar "pdmode" oldpdmode)
- (setvar "osmode" oldsnap)
- (princ)
