查看: 9437|回复: 22
直线变矩形源码
发表于 2012-12-21 08:54:30 | 显示全部楼层 |阅读模式
以下代码是将直线变为矩形,但只能点选和单选,那位高手能帮忙改为多选和框选。谢谢
;; 直线变矩形
(defun c:b1()
  (setvar "osmode" 0)
  (setq ww (getreal "\n请输入宽度: "))
  (prompt "\n框选欲变矩形的直线: ")
  (setq ss (ssget '((0 . "LINE")))
          d  (* ww 0.5)
           i  -1
  (while (setq s1 (ssname ss (setq i (1+ i))))
    (setq p1 (vlax-curve-getstartPoint s1)
          p2 (vlax-curve-getendPoint s1)
          r  (+ (angle p1 p2) (* pi 0.5))
    (command "pline" (polar p1 r (- d)) (polar p2 r (- d)) (polar p2 r d) (polar p1 r d) "c")
发表于 2019-11-2 00:25:25 | 显示全部楼层
ketxu 发表于 2019-11-1 11:30
Put (vl-load-com) at top or bottom of lisp ^^
我把他改成动态的了
  1. (vl-load-com)
  2. (defun c:rex ( /  ss i e pts ob del-e a aa mouse elast)
  3.   (setq pac (getvar 'peditaccept))
  4.   (setvar 'peditaccept 1)
  5.   ;(if (not width) (setq width 1.00))
  6.   ;(setq width (cond
  7.   ;              ((getdist(strcat "\nEnter Width <"(rtos width 2 2)">: ")))
  8.   ;              (width)
  9.   ;            )
  10.   ;)
  11.   (setq del-e nil)
  12.   (if (and
  13.         (setq ss (ssget ":E:S" '((0 . "LWPOLYLINE,LINE"))))
  14.         (setq pt0(getpoint "\n指定第一点:"))
  15.         ;(setq pt0 (cadr(car(cdddar(ssnamex ss 0)))))
  16.       )
  17.     (progn
  18.       (setq elast(entlast))
  19.       (setq loop T)
  20.       (while loop
  21.         (setq mouse (grread T 12 0))
  22.         (setq a (car mouse) aa (cadr mouse))
  23.         (cond
  24.           ((= a 5)
  25.             (redraw)
  26.             ;(if (= elast(entlast))(princ)(entdel (entlast)))
  27.             (if del-e(entdel del-e)(princ))
  28.             (grdraw pt0 aa 1);画向量
  29.             (setq width(distance pt0 aa))
  30.             (if (> width 0.001)
  31.               (progn
  32.                 (setq i 0)
  33.                 (repeat (setq i (sslength ss))
  34.                   (setq e (ssname ss (Setq i (1- i))) sss (ssadd))
  35.                   (setq pts (mapcar
  36.                               '(lambda (y)
  37.                                  (list (vlax-curve-getStartPoint y)
  38.                                    (vlax-curve-getEndPoint y)
  39.                                  )
  40.                                )
  41.                               (mapcar 'car
  42.                                 (mapcar
  43.                                   '(lambda (x)
  44.                                      (setq ob (vlax-invoke
  45.                                                 (vlax-ename->vla-object e)
  46.                                                 'Offset
  47.                                                 x
  48.                                               )
  49.                                      )
  50.                                      (ssadd (entlast) sss)
  51.                                      ob
  52.                                    )
  53.                                   (list (setq h (* 0.5 width))
  54.                                     (- h)
  55.                                   )
  56.                                 )
  57.                               )
  58.                             )
  59.                   )
  60.                   (mapcar '(lambda (k l)
  61.                              (entmakex (list (cons 0 "LINE") (cons 10 k) (cons 11 l)))
  62.                              (ssadd (entlast) sss)
  63.                            )
  64.                     (car pts)(cadr pts)
  65.                   )
  66.                   (command "_.pedit" "_m" sss ""  "_j" 0.0 "")
  67.                   (setq del-e (entlast))
  68.                   ;(entdel e)
  69.                 )
  70.               )
  71.             )
  72.           )            ;;; 鼠标移动
  73.           ( (or (= 25 a) (= 11 a) ;右键
  74.               (and (= a 2) (= aa 13));回车
  75.               (and (= a 2) (= aa 32));或空格
  76.               (= a 3);鼠标左键
  77.             )
  78.             (setq loop nil)
  79.           )
  80.         )
  81.       )
  82.     )
  83.   )
  84.   (redraw)
  85.   (setvar 'peditaccept pac)
  86.   (princ)
  87. )
发表于 2019-11-1 11:30:50 | 显示全部楼层
yubihai 发表于 2019-10-7 08:39
在2010及以上版本不可用,提示:错误: no function definition: VLAX-CURVE-GETSTARTPOINT
发表于 2019-10-7 08:39:16 | 显示全部楼层
发表于 2012-12-21 09:03:48 | 显示全部楼层
程序本身就能多选了啊!
发表于 2012-12-21 10:18:55 | 显示全部楼层
用起来不错,感谢分享
发表于 2012-12-21 11:59:07 | 显示全部楼层
太棒了.感谢楼主分享的程序拉.~!太实用拉.
发表于 2013-6-29 12:02:49 | 显示全部楼层
谢谢楼主分享,辛苦了!
发表于 2018-8-27 19:41:27 | 显示全部楼层
用了之后对象捕捉就要重新勾选????
发表于 2019-3-18 09:24:47 | 显示全部楼层
这是以现有直线为中线画矩形
谢谢你
还以为是对角线改矩形啊
发表于 2019-8-6 10:21:47 | 显示全部楼层
用起来不错,感谢分享
发表于 2019-8-13 20:01:28 来自手机 | 显示全部楼层
谢谢分享,支持
发表于 2019-9-11 23:41:07 | 显示全部楼层
如果直线不在中心位置就好了,以一边为准
GMT+8, 2025-5-24 11:19 , Processed in 0.172983 second(s), 26 queries , Gzip On.
