查看: 1753|回复: 3
列表对话框
发表于 2012-12-21 19:33:51 | 显示全部楼层 |阅读模式
参考书上的列表对话框,为什么出来的列表是空白,而没有内容?
(defun c:wr()
   (setq wordlist '("1层" "2层"))
(dcl_contents)
(defun dcl_contents()
   (setq dcl_id (load_dialog "contents"))
   (new_dialog "contents" dcl_id)
   (setq dd (start_dialog))
   (start_list "klist")
   (mapcar 'add_list wordlist)
   (end_list)
   (action_tile "klist" "(sub_klist $value)")
   (action_tile "accept" "(ok_dia7a)(done_dialog 1)")
   (if (= dd 1)
   (setvar "cmdecho" 1)
   (command "text" pause pause 0 str)
   (setvar "cmdecho" 0)
(defun sub_klist(vvs)
(set_tile "str" (nth (atoi vvs) wordlist))
(defun ok_dia7a()
(setq str (get_tile "str"))
contents:dialog{
            label="常用";
            :list_box{
            label="常用";
            key="klist";
            width=30;
            height=10;
:edit_box{
          label="词库";
            key="str";
spacer_1;
ok_cancel;
发表于 2012-12-21 19:53:52 | 显示全部楼层
多了一行start_dialog
  1. (defun dcl_contents()
  2. (if (> (setq dcl_id (load_dialog "contents")) 0) (progn
  3.   (if (new_dialog "contents" dcl_id) (progn
  4.    (start_list "klist")
  5.    (mapcar 'add_list wordlist)
  6.    (end_list)
  7.    (action_tile "klist" "(sub_klist $value)")
  8.    (action_tile "accept" "(ok_dia7a)(done_dialog 1)")
  9.    (setq dd (start_dialog))
  10.   )
  11.    (princ "\n无法显示对话框!")
  12.   )
  13.   (unload_dialog dcl_id)
  14. )
  15.   (princ "\n无法加载对话框!")
  16. )
  17. (if (= dd 1) (progn
  18.   (setvar "cmdecho" 1)
  19.   (command "text" pause pause 0 str)
  20.   (setvar "cmdecho" 0)
  21. ))
  22. (princ)
  23. )
  24. (defun sub_klist(vvs)
  25. (set_tile "str" (nth (atoi vvs) wordlist))
  26. )
  27. (defun ok_dia7a()
  28. (setq str (get_tile "str"))
  29. )
发表于 2012-12-23 14:37:19 | 显示全部楼层
谢谢分享[em0]
发表于 2013-8-31 11:13:04 | 显示全部楼层
怎么实现双击运行呢?
GMT+8, 2025-5-26 11:18 , Processed in 0.195187 second(s), 31 queries , Gzip On.
