查看: 1603|回复: 6
求助:把下面面积标注精确到2位小数及0.00m2
发表于 2012-12-31 12:11:10 | 显示全部楼层 |阅读模式
(defun c:ttt(/ ACADDOC ACADSPC OBJAREA OBJLLPOINT OBJRUPOINT SELECTIONSET TEXTBASEPOINT TEXTHEIGHT TEXTINDEX TEXTOBJ)
   (vl-load-com)
   (setq AcadDoc (vla-get-activedocument (vlax-get-acad-object)))
   (if (= (getvar "TILEMODE") 1)(setq AcadSpc (vla-get-modelspace AcadDoc))(setq AcadSpc (vla-get-paperspace AcadDoc)))
   (setq TextHeight (getdist "\n输入标注文字高度:")
TextIndex (getint "\n输入起始编号:")
   (ssget '((0 . "LWPOLYLINE")))
   (setq Selectionset (vla-get-activeselectionset AcadDoc))
   (if (and TextHeight Selectionset TextIndex)
     (vlax-for Obj Selectionset
       (setq ObjArea (vla-get-area obj)
      ObjLlPoint nil
      ObjRuPoint nil
       (vla-GetBoundingBox Obj 'ObjLlPoint 'ObjRuPoint)
       (setq TextBasePoint (mapcar '(lambda(x y) (/ (+ x y) 2)) (vlax-safearray->list ObjLlPoint)(vlax-safearray->list ObjRuPoint))
      TextObj (vla-addtext AcadSpc (strcat (itoa TextIndex) "号面积=" (rtos (/ ObjArea 100000)) "m2") (vlax-3d-point TextBasePoint) TextHeight)
       (vla-put-alignment TextObj acAlignmentCenter)
       (vla-put-TextAlignmentPoint TextObj (vlax-3d-point TextBasePoint))
       (setq TextIndex (1+ TextIndex))
发表于 2012-12-31 12:21:37 | 显示全部楼层
(strcat (itoa TextIndex) "号面积=" (rtos (/ ObjArea 100000) 2 2) "m2")
发表于 2012-12-31 12:25:07 | 显示全部楼层
(rtos (/ ObjArea 100000))改为(rtos (/ ObjArea 100000)2 2)
 楼主| 发表于 2012-12-31 12:48:24 | 显示全部楼层
太感谢了
 楼主| 发表于 2012-12-31 12:48:56 | 显示全部楼层
多谢!!!!!!!
发表于 2012-12-31 13:34:44 | 显示全部楼层
支持一下,,,支持源码,
发表于 2019-12-16 13:28:15 | 显示全部楼层
支持一下很好的程序!
GMT+8, 2025-5-18 11:22 , Processed in 0.173475 second(s), 25 queries , Gzip On.
