- 积分
- 173
- 明经币
- 个
- 注册时间
- 2012-12-31
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
楼主 |
发表于 2013-1-1 15:51:55
显示全部楼层
;;; BURST.LSP
;;; Copyright (C) 1997 by Autodesk, Inc.
;;; Permission to use, copy, modify, and distribute this software
;;; for any purpose and without fee is hereby granted, provided
;;; that the above copyright notice appears in all copies and
;;; that both that copyright notice and the limited warranty and
;;; restricted rights notice below appear in all supporting
;;; documentation.
;;; AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
;;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
;;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC.
;;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
;;; UNINTERRUPTED OR ERROR FREE.
;;; Use, duplication, or disclosure by the U.S. Government is subject to
;;; restrictions set forth in FAR 52.227-19 (Commercial Computer
;;; Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
;;; (Rights in Technical Data and Computer Software), as applicable.
;;; Last Revision 3/10/97 7:29 AM
;;; Credits: Phil Kreiker
(Defun C:BURST (/ item bitset bump att-text lastent burst-one burst
BCNT BLAYER BCOLOR ELAST BLTYPE ETYPE PSFLAG ENAME )
; Item from association list
(Defun ITEM (N E) (CDR (Assoc N E)))
; Error Handler
(setvar "cmdecho" 0)
;;临时禁止以下代码
(init_bonus_error
(list
(list "cmdecho" 0
"highlight" 1
T ;flag. True means use undo for error clean up.
);list
);init_bonus_error
; BIT SET
(Defun BITSET (A B) (= (Boole 1 A B) B))
; BUMP
(Setq bcnt 0)
(Defun bump (prmpt)
(Princ
(Nth bcnt '("\r-" "\r\\" "\r|" "\r/"))
(Setq bcnt (Rem (1+ bcnt) 4))
; Convert Attribute Entity to Text Entity
(Defun ATT-TEXT (AENT / TENT ILIST INUM)
(Setq TENT '((0 . "TEXT")))
(ForEach INUM '(8
6
38
39
62
67
210
10
40
1
50
41
51
7
71
72
73
11
(If (Setq ILIST (Assoc INUM AENT))
(Setq TENT (Cons ILIST TENT))
(Setq
tent (Subst
(Cons 73 (item 74 aent))
(Assoc 72 tent)
tent
(EntMake (Reverse TENT))
; Find True last entity
(Defun LASTENT (/ E0 EN)
(Setq E0 (EntLast))
(While (Setq EN (EntNext E0))
(Setq E0 EN)
E0
; Burst one entity
(Defun BURST-ONE (BNAME / BENT ANAME ENT ATYPE AENT AGAIN ENAME
ENT SS-COLOR SS-LAYER SS-LTYPE mirror ss-mirror
mlast)
(Setq
BENT (EntGet BNAME)
BLAYER (ITEM 8 BENT)
BCOLOR (ITEM 62 BENT)
BCOLOR (Cond
((> BCOLOR 0) BCOLOR)
((= BCOLOR 0) "BYBLOCK")
("BYLAYER")
BLTYPE (Cond ((ITEM 6 BENT)) ("BYLAYER"))
(Setq ELAST (LASTENT))
(If (= 1 (ITEM 66 BENT))
(Progn
(Setq ANAME BNAME)
(While (Setq
ANAME (EntNext ANAME)
AENT (EntGet ANAME)
ATYPE (ITEM 0 AENT)
AGAIN (= "ATTRIB" ATYPE)
(bump "Converting attributes")
(ATT-TEXT AENT)
(Progn
(bump "Exploding block")
(Command "_.explode" BNAME)
(Setq
SS-LAYER (SsAdd)
SS-COLOR (SsAdd)
SS-LTYPE (SsAdd)
ENAME ELAST
(While (Setq ENAME (EntNext ENAME))
(bump "Gathering pieces")
(Setq
ENT (EntGet ENAME)
ETYPE (ITEM 0 ENT)
(If (= "ATTDEF" ETYPE)
(Progn
(If (BITSET (ITEM 70 ENT) 2)
(ATT-TEXT ENT)
(EntDel ENAME)
(Progn
(If (= "0" (ITEM 8 ENT))
(SsAdd ENAME SS-LAYER)
(If (= 0 (ITEM 62 ENT))
(SsAdd ENAME SS-COLOR)
(If (= "BYBLOCK" (ITEM 6 ENT))
(SsAdd ENAME SS-LTYPE)
(If (> (SsLength SS-LAYER) 0)
(Progn
(bump "Fixing layers")
(Command
"_.chprop" SS-LAYER "" "_LA" BLAYER ""
(If (> (SsLength SS-COLOR) 0)
(Progn
(bump "Fixing colors")
(Command
"_.chprop" SS-COLOR "" "_C" BCOLOR ""
(If (> (SsLength SS-LTYPE) 0)
(Progn
(bump "Fixing linetypes")
(Command
"_.chprop" SS-LTYPE "" "_LT" BLTYPE ""
; BURST MAIN ROUTINE
(Defun BURST (/ SS1)
(setq PSFLAG (if (= 1 (caar (vports)))
1 0
(Setq SS1 (SsGet (list (cons 0 "INSERT")(cons 67 PSFLAG))))
(If SS1
(Progn
(Setvar "highlight" 0)
(terpri)
(Repeat
(SsLength SS1)
(Setq ENAME (SsName SS1 0))
(SsDel ENAME SS1)
(BURST-ONE ENAME)
(princ "\n")
; BURST COMMAND
(BURST)
;;临时禁止以下代码
;; (restore_old_error)
);end defun
(Princ "\nBURST loaded, 用于属性块的分解.\n原程序有BUG--文字分解后,夹点方式均为<左>,基本不影响使用.")
(Princ)
附件传不上去 附上原始版的BURST |
