查看: 1030|回复: 3
求助:关于默认输出的问题 钢框架小程序
发表于 2013-1-4 13:38:57 | 显示全部楼层 |阅读模式
(prompt  "\nthe two points is GJ GG JG or JJ.Enter gj gg jg or jj : ")
(setq cc(getstring))
(setq ans(substr cc 1 1    )
      ane(substr cc 2 1    )
如果从键盘输入的话就按gj gg jg or jj 之一程序可以正常运行,如果键盘不输入,程序默认指定jj
,可以用什么函数指定呢?
请大家帮忙解答啊
发表于 2013-1-4 13:46:36 | 显示全部楼层
鍵盤不輸入,程序默認指定jj
(if (= cc "") (setq cc jj))
改用 ustr
more info:
http://www.google.com/search?as_ ... A%2F%2Fbbs.mjtd.com
 楼主| 发表于 2013-1-4 14:24:38 | 显示全部楼层
(defun C:zz( )
(setq v1 (getvar "cmdecho")   )
(setq v2 (getvar "osmode")    )
(if (= cc " " )       (setq cc "jj")
      ane(substr cc 2 1    )
(setq mm (getpoint "\n选择第一个点:"))
(setq nn (getpoint "\n选择第二个点:"))
(setq angle1 (angle mm nn)   )
(setvar "cmdecho" 0)
(setvar "osmode" 0)
(if(= ans "g")
      (setq p1(polar mm angle1 100))
      (setq p2(polar p1 angle1 300))
      (setq p3(polar p1 (+ (/ pi 2)  angle1 )  150))
      (setq p4(polar p1 (+  (/ (* 3 pi) 2)  angle1 )   150))
      (command "pline" p2 "w" 0 0  p3 p4 "c" " ")
      (command "chprop" (entlast) "" "c" 4 ""  )
      (command "hatch" "solid" (entlast) "")
(if(= ans "j")
     (setq p5(polar mm  angle1 100))
     (setq p6(polar p5  angle1 300))
     (setq p7(polar p6 (+ (/ pi 2) angle1 ) 150))
     (setq p8(polar p6 (+ (/ (* 3 pi) 2)  angle1) 150))
     (command "pline" p5 "w" 0 0  p7 p8 "C" " ")
;第一点的约束情况已经完成
(if(= ane "g")
    (setq pp1(polar nn (+ pi  angle1) 100))
    (setq pp2(polar pp1 (+ pi   angle1) 300))
    (setq pp3(polar pp1 (+ (/ pi 2)  angle1 ) 150))
    (setq pp4(polar pp1 (+ (/ (* 3 pi) 2) angle1)  150))
    (command "pline" pp2 "w" 0 0  pp3 pp4 "C"  " ")
(if(= ane "j")
     (setq pp5(polar nn  ( + pi  angle1)  100))
     (setq pp6(polar pp5  (+  pi angle1)  300))
     (setq pp7(polar pp6 (+ angle1  (/ pi 2) )  150))
     (setq pp8(polar pp6 (+ angle1  (/ (* 3 pi) 2) ) 150))
     (command "pline" pp5 "w" 0 0  pp7 pp8 "C"  " ")
;第二点的约束情况已经完成
(if (and (= ans "j") (= ane "g")  )
      (command "pline" p6   "W" 100 100  pp1 "c"" ")
;一端铰接,一端刚接情况
(if (and (= ans  "j") (= ane  "j")  )
          (command "pline"  p6  "W" 100 100  pp6"c" " ")
;两端铰接情况
(if (and (= ans "g") (= ane "j")  )
         (command "pline" p1    "W" 100 100  pp6 "c"" ")
;一端刚接,一端铰接情况
(if (and (= ans "g") (= ane "g")  )
         (command "pline" p1   "W" 100  100   pp1 "c"" ")
;两端刚接情况
(setvar "cmdecho" v1)
(setvar "osmode" v2)
(princ   )
(prompt "****精工<<C:zz>>*****")
(princ )
为什么按照默认的运行不了,求解释
 楼主| 发表于 2013-1-4 14:42:46 | 显示全部楼层
解决了,原来是小冒号的问题。多谢版主Andyhon 啦
GMT+8, 2025-6-2 11:01 , Processed in 0.151350 second(s), 25 queries , Gzip On.
