查看: 1289|回复: 2
提取快捷命令怎么用
发表于 2013-1-7 19:10:19 | 显示全部楼层 |阅读模式
(defun get-nr ( file_name / OUT TMP)
  (if (setq file_name (findfile file_name))
      (setq out '())
      (setq file_name (open file_name "r"))
      (while (setq tmp (read-line file_name))
        (setq out (cons tmp out))
      (close file_name)
      (reverse out)
(defun wr-kj (file_name / BJ FILE_NAME NR PATH X)
  (vl-load-com)
      (setq path (VL-FILENAME-DIRECTORY file_name))
      (setq nr (get-nr file_name))
      (setq nr (vl-remove nil (mapcar '(lambda(x)
                          (if (setq bj (VL-STRING-SEARCH  "★" x))
                            (substr x (1+ bj)))
                       nr)
      (setq file_name (strcat path "快捷键.txt"))
      (setq file_name (open file_name "w"))
      (mapcar '(lambda(x)
                 (write-line x file_name)) nr)
      (close file_name)
      (princ "\n写入成功。")
 楼主| 发表于 2013-2-3 23:00:33 | 显示全部楼层
发表于 2013-2-4 11:11:16 | 显示全部楼层
摘个现成答案发帖并不注明来源?
GMT+8, 2025-4-19 05:44 , Processed in 0.169061 second(s), 30 queries , Gzip On.
