楼主: 革天明
[讨论] 如何提升此程序运行的速度?
 楼主| 发表于 2013-3-11 13:02:53 | 显示全部楼层
每生成一个solid需要0.015秒,21*21个,还是6秒多,看来是快不起来了啊
 楼主| 发表于 2013-3-11 14:14:01 | 显示全部楼层
下面是老外的程序,需要联网,运行速度比较快,但我不知道如何才有将我的程序改成也生成块,而且速度会提升。
; QRCODE for Autocad
; © 2010 swisscad / Ian Vogel
; V 0.91 released 2010.08.22
(defun c:QRcode ( / str)
(cond
((not (validstr (setq str (getstring "\nEnter Text to encode :" T))))
(princ "\nNo text entered")
((QRcode str (setq name "QRCode") 0)
(command "_REGENALL")
(command "_INSERT" name)
(defun QRcode (string ; string to encode
blockname ; name of the block to create
options ; options
; 1 = perform only if block already exists
/ QR x y startx row)
(vl-load-com)
(cond
((not (validstr blockname)))
((or (zerop (logand 1 options))
(tblsearch "BLOCK" blockname)
(setq baseurl "www.xcad.ch/tests/getqrcode.php")
(setq QR (valstr (gethttp (strcat baseurl"%3Fstring=" (urlencode (urlencode string))) 0)))
(cond
((eq (substr QR 1 6) "111111");response OK
(setq QR (split QR "-")
y 0)
;create Qrcode block
(entmake (list '(0 . "BLOCK")
(cons 2 blockname)
'(8 . "0")
'(70 . 0)
'(10 0.0 0.0 0.0)
(foreach row QR
(setq x 0)
(while (< x (strlen row))
(cond
((eq (substr row (1+ x) 1) "1")
;memorize start of filled zone
(if (not startx)(setq startx x))
(if (not (eq (substr row (+ x 2) 1) "1"))
;draw filled zone
(entmake (list (cons 0 "SOLID")
(cons 8 "0")
(cons 10 (list startx y))
(cons 11 (list (1+ x) y))
(cons 12 (list startx (1- y)))
(cons 13 (list (1+ x)(1- y)))
(cons 62 0)
(setq startx nil)
(setq x (1+ x))
(setq y (1- y))
;end of block
(setq bl_a (entmake '((0 . "ENDBLK"))))
T
; Get an URL
(defun gethttp (lien
opt
/ fi line tmp util content)
(setq        util (vla-get-Utility
(vla-get-ActiveDocument (vlax-get-acad-object))
(if (eq (vla-isurl util lien) :vlax-true)
(if        (vl-catch-all-error-p
(vl-catch-all-apply
'vla-GetRemoteFile
(list util lien 'tmp :vlax-true)
(princ "\nError getting http file.")
(setq fi (open tmp "r")
content "")
(while (setq line (read-line fi))
(setq content (strcat content line))
(close fi)
content
; Turn any var to a string
(defun valstr (val)
(cond
((eq (type val) 'STR) val)
((eq (type val) 'REAL) (rtos val))
((eq (type val) 'INT) (itoa val))
(T "")
; Check that a string is not empty
(defun validstr (str / tmp)
(if (> (strlen (setq tmp (trim (valstr str)))) 0) tmp nil)
; Remove blanks from a string
(defun trim ( str / )
(setq str (valstr str))
(while (eq (substr str 1 1) " ")
(setq str (substr str 2))
(while (and (> (strlen str) 1)
(eq (substr str (strlen str) 1) " ")
(setq str (substr str 1 (- (strlen str) 1)))
str
; Split a string
(defun split (str ; string to split
cara ; separator
/ n portion xstring seqstart chrcode portion)
(cond
((and (= (type str)(type cara) 'STR)(eq (strlen cara) 1))
(setq n -1 seqstart 1 chrcode (ascii cara))
(while (setq n (vl-string-position chrcode str (+ n 1) nil))
(setq xstring (append xstring (list (substr str seqstart (- n seqstart -1)))) seqstart (+ n 2) )
(setq xstring (append xstring (list (substr str seqstart))))
(if xstring xstring (list str))
((= (type str)(type cara) 'STR)
(setq portion "" n 1)
(if (<= (strlen cara) (strlen str))
(while (<= n (strlen str))
(if (eq (substr str n (strlen cara)) cara)
(setq xstring (append xstring (list portion))
portion ""
n (+ n (strlen cara))
(setq portion (strcat portion (substr str n 1))
n (+ 1 n)
(if (or (> (strlen portion) 0)
(eq (substr str (abs (- (strlen str)(strlen cara) -1))) cara)
(setq xstring (append xstring (list portion)))
(setq xstring (list str))
(if xstring xstring (list ""))
(T (list nil))
; See PHP function
; http://ch2.php.net/manual/fr/function.htmlentities.php
(defun urlencode (str / result n len )
(setq result ""
n 1
len (strlen str))
(while (<= n len)
(setq result (strcat result (urlenc (substr str n 1)))
n (+ 1 n))
result
(defun urlenc (ch)
(cond
((eq ch " ") " ");+
((eq ch "!") "%21")
((eq ch "\"") "%22")
((eq ch "#") "%23")
((eq ch "$") "%24")
((eq ch "%") "%25")
((eq ch "&") "%26")
((eq ch "'") "%27")
((eq ch "(") "%28")
((eq ch ")") "%29")
((eq ch "*") "%2A")
((eq ch "+") "%2B")
((eq ch ",") "%2C")
((eq ch "/") "%2F")
((eq ch ":") "%3A")
((eq ch ";") "%3B")
((eq ch "<") "%3C")
((eq ch "=") "%3D")
((eq ch ">") "%3E")
((eq ch "?") "%3F")
((eq ch "@") "%40")
((eq ch "[") "%5B")
((eq ch "\\") "%5C")
((eq ch "]") "%5D")
((eq ch "^") "%5E")
((eq ch "`") "%60")
((eq ch "{") "%7B")
((eq ch "|") "%7C")
((eq ch "}") "%7D")
((eq ch "~") "%7E")
((eq ch "‘") "%91")
((eq ch "’") "%92")
((eq ch "&#161;") "%A1")
((eq ch "¢") "%A2")
((eq ch "£") "%A3")
((eq ch "¤") "%A4")
((eq ch "¥") "%A5")
((eq ch "|") "%A6")
((eq ch "§") "%A7")
((eq ch "¨") "%A8")
((eq ch "&#169;") "%A9")
((eq ch "a") "%AA")
((eq ch "&#171;") "%AB")
((eq ch "&#172;") "%AC")
((eq ch "-") "%AD")
((eq ch "&#174;") "%AE")
((eq ch "ˉ") "%AF")
((eq ch "°") "%B0")
((eq ch "±") "%B1")
((eq ch "2") "%B2")
((eq ch "3") "%B3")
((eq ch "′") "%B4")
((eq ch "μ") "%B5")
((eq ch "&#182;") "%B6")
((eq ch "·") "%B7")
((eq ch "&#184;") "%B8")
((eq ch "1") "%B9")
((eq ch "o") "%BA")
((eq ch "&#187;") "%BB")
((eq ch "&#188;") "%BC")
((eq ch "&#189;") "%BD")
((eq ch "&#190;") "%BE")
((eq ch "&#191;") "%BF")
((eq ch "à") "%C0")
((eq ch "á") "%C1")
((eq ch "&#194;") "%C2")
((eq ch "&#195;") "%C3")
((eq ch "&#196;") "%C4")
((eq ch "&#197;") "%C5")
((eq ch "&#198;") "%C6")
((eq ch "&#199;") "%C7")
((eq ch "è") "%C8")
((eq ch "é") "%C9")
((eq ch "ê") "%CA")
((eq ch "&#203;") "%CB")
((eq ch "ì") "%CC")
((eq ch "í") "%CD")
((eq ch "&#206;") "%CE")
((eq ch "&#207;") "%CF")
((eq ch "D") "%D0")
((eq ch "&#209;") "%D1")
((eq ch "ò") "%D2")
((eq ch "ó") "%D3")
((eq ch "&#212;") "%D4")
((eq ch "&#213;") "%D5")
((eq ch "&#214;") "%D6")
((eq ch "×") "%D7")
((eq ch "&#216;") "%D8")
((eq ch "ù") "%D9")
((eq ch "ú") "%DA")
((eq ch "&#219;") "%DB")
((eq ch "ü") "%DC")
((eq ch "Y") "%DD")
((eq ch "T") "%DE")
((eq ch "&#223;") "%DF")
((eq ch "à") "%E0")
((eq ch "á") "%E1")
((eq ch "a") "%E2")
((eq ch "&#227;") "%E3")
((eq ch "&#228;") "%E4")
((eq ch "&#229;") "%E5")
((eq ch "&#230;") "%E6")
((eq ch "&#231;") "%E7")
((eq ch "è") "%E8")
((eq ch "é") "%E9")
((eq ch "ê") "%EA")
((eq ch "&#235;") "%EB")
((eq ch "ì") "%EC")
((eq ch "í") "%ED")
((eq ch "&#238;") "%EE")
((eq ch "&#239;") "%EF")
((eq ch "e") "%F0")
((eq ch "&#241;") "%F1")
((eq ch "ò") "%F2")
((eq ch "ó") "%F3")
((eq ch "&#244;") "%F4")
((eq ch "&#245;") "%F5")
((eq ch "&#246;") "%F6")
((eq ch "÷") "%F7")
((eq ch "&#248;") "%F8")
((eq ch "ù") "%F9")
((eq ch "ú") "%FA")
((eq ch "&#251;") "%FB")
((eq ch "ü") "%FC")
((eq ch "y") "%FD")
((eq ch "t") "%FE")
((eq ch "&#255;") "%FF")
(T ch)
(princ "\nType QRCODE")
发表于 2013-3-11 15:40:12 | 显示全部楼层
不懂二维码,也就不太想研究程序,粗看一下,生成solid的部分无疑是很费时的,对此有两点建议,一是把生成solid改成生成PL试试,而是把这种重复循环的内容改成子函数。
重复的内容改成子函数,对我们而言,似乎只是写法上的不同,但程序处理实际上完全不一样。另外,不是必须的,不必都使用函数,如(cons 8 "0")应该直接写成'(8 . "0"),这其实是一样的道理,就是让程序少调用几遍函数。
个人意见,不对请海涵。
发表于 2013-3-11 16:10:26 | 显示全部楼层
老外的程序是使用php脚本实现核心功能的,除非你能用别的语言重写这部分代码以供lisp调用并得到返回值。。。还是换到.net/objectarx平台吧
言之有理,还不如直接用ARX NET等,更快  发表于 2013-3-11 18:06
发表于 2013-3-14 15:12:23 | 显示全部楼层
厉害啊,学习一下~
 楼主| 发表于 2013-3-14 15:29:48 | 显示全部楼层
ll_j 发表于 2013-3-11 15:40
不懂二维码,也就不太想研究程序,粗看一下,生成solid的部分无疑是很费时的,对此有两点建议,一是把生成s ...
我把老外的程序修改了一下,做成子函数,速度可以接受,感觉不到延迟
(defun YTM-QRcode-str (str                ; string to encode
  (vl-load-com)
  (cond
    (t
     (setq strlst '("1111111011101101001111111"
                    "1000001011100101001000001"
                    "1011101010110110001011101"
                    "1011101011010011001011101"
                    "1011101000000110101011101"
                    "1000001010011101101000001"
                    "1111111010101010101111111"
                    "0000000001001100000000000"
                    "1100111000010011000101111"
                    "0111110111101100101001110"
                    "1001101000011010010101011"
                    "0101010110110111001111001"
                    "1101111100101100110100111"
                    "1111010100000001001111110"
                    "0000011111000000101000101"
                    "0000000111001100111000001"
                    "1110101100010011111110001"
                    "0000000011101100100011101"
                    "1111111000111111101010101"
                    "1000001010010110100011001"
                    "1011101011101011111110111"
                    "1011101001100001110110111"
                    "1011101001100011010111110"
                    "1000001010101011001101010"
                    "1111111011111111110011111"
  (if (eq (substr (nth 0 strlst) 1 6) "111111") ;response OK
      (setq QR strlst
            y  0
      ;;create Qrcode block
                     (cons 2 blockname)
                     '(8 . "0")
                     '(70 . 0)
                     '(10 0.0 0.0 0.0)
      (foreach row QR
        (setq x 0)
          (cond
             ;;memorize start of filled zone
             (if (not startx)
               (setq startx x)
                 ;;draw filled zone
                                (cons 8 "0")
                                (cons 13 (list (1+ x) (1- y)))
                                (cons 62 0)
                 (setq startx nil)
          (setq x (1+ x))
        (setq y (1- y))
      ;;end of block
目前此函数就只能生成固定的二维码,可做为研究看一下,还是老外的速度快啊,至于生成相应的二维码状态描述表是其它程序的事,上面程序只负责将二维码生成出来。
 楼主| 发表于 2013-3-14 18:00:20 | 显示全部楼层
xiaxiang 发表于 2013-3-11 16:10
老外的程序是使用php脚本实现核心功能的,除非你能用别的语言重写这部分代码以供lisp调用并得到返回值。。。 ...
看下我最后更新的子函数,感觉不到速度上的延迟
发表于 2013-3-15 15:30:04 | 显示全部楼层
  1. (defun DBarCode (p0 str / p00 ll aa tx i s1)
  2.   (setq p00 p0
  3.         ll  0
  4.   )
  5.   (defun aaa (ll p0)
  6.     (if        (> ll 0)
  7.       (xyp-LwPlWide (list p0 (polar p0 0 ll)) nil 1)
  8.     )
  9.   )
  10.   (foreach aa (xyp-Get-Str2Lstspr str "-")
  11.     (setq i 0)
  12.     (while (/= (setq tx (substr aa (setq i (1+ i)) 1)) "")
  13.       (cond ((= tx "1") (setq ll (1+ ll)))
  14.             ((= tx "0")
  15.              (setq s1 (aaa ll p0)
  16.                    p0 (polar p0 0 (1+ ll))
  17.                    ll 0
  18.              )
  19.             )
  20.       )
  21.     )
  22.     (setq s1  (aaa ll p0)
  23.           p00 (polar p00 (* pi -0.5) 1)
  24.           p0  p00
  25.           ll  0
  26.     )
  27.   )
  28. )
发表于 2013-3-16 19:52:14 | 显示全部楼层
这个够复杂哦,,,,,
 楼主| 发表于 2013-3-17 08:41:55 | 显示全部楼层
xyp1964 发表于 2013-3-15 15:30
现在习惯了院长大人的高速度,还有伪源码,需要xcad.vlx支持,哈哈
GMT+8, 2025-12-17 12:11 , Processed in 0.169301 second(s), 23 queries , Gzip On.
