楼主: 669423907
[源码] 两个程序有冲突,该如何改?
 楼主| 发表于 2013-5-4 12:04:04 | 显示全部楼层
ll_j 发表于 2013-5-4 10:29
把(defun c:q3(/ *error* ent gr i msg n qf ss s1)改成(defun c:q3(/ ent gr i msg n qf s1)试试。
还是不行吖!!!
需要点或选项关键字。
; 错误: *error* 函数中出错AutoCAD 变量设置被拒绝: "qaflags" nil
指定修改点或 [特性(P)]:
 楼主| 发表于 2013-5-6 20:06:46 | 显示全部楼层
终于,这样可以了
(defun c:1()
(setq ss (ssget"i"))
(if (= ss nil)(1,)(1,,)))
(defun 1,()
(command "layer" "m" "0" "c" "253" "" "lw" "0.3" "" ""))
(defun 1,,()
(setq ss (ssget))
(setq la (getvar"clayer"))
(command "layer" "m" "0" "c" "253" "" "lw" "0.3" "" "" "clayer" la)
(command "change" ss "" "P" "la" "0" "c" "byl" "lw" "byl" "lt" "byl" ""))
发表于 2016-1-15 18:13:53 | 显示全部楼层
669423907 发表于 2013-5-6 20:06
终于,这样可以了
(defun c:1()
(defun c:1()
(setvar "cmdecho" 0)       ;增加这个试试看
(if (= ss nil)
(command "change" ss "" "p" "la" "0" "c" "byl" "lw" "byl" "lt" "byl" "")))
参见:http://bbs.mjtd.com/forum.php?mod=viewthread&tid=95050,xyz2009xyz的回答。
GMT+8, 2026-1-21 15:56 , Processed in 2.488526 second(s), 18 queries , Gzip On.
