楼主: vlisp2012
[函数] Lisp程序设计错误处理程序
发表于 2022-4-30 09:01:13 | 显示全部楼层
(defun ini-0 (/ myerror n);;;程序初始化及自定义错误处理函数
  (setvar "CMDECHO" 0)
  (command-s "undo" "be")
  (setq olderror *error*)
  (setq *error* myerror)
  (setq
    e_lst (mapcar (function (lambda (n) (list 'setvar n (getvar n))))
                  '("autosnap"          "osmode"        "aperture"
                    "hpspace"          "hpassoc"        "mirrtext"
                    "auprec"          "luprec"        "dimzin"
                    "cecolor"          "clayer"
  (defun *error* (msg)
    (mapcar 'eval e_lst)
    (if        (not (member
               msg
               '(nil "函数被取消" ";错误:quit / exit abort")
      (princ (strcat ";错误:" msg))
(defun ini-1 (e_lst);;;恢复系统变量
  (setq *error* olderror)
  (command-s "undo" "e")
发表于 2022-4-30 09:03:00 | 显示全部楼层
cad890 发表于 2019-5-24 12:46
在开始更改之前,结束更改之后
老哥,这样吗
  (setq
                    "cecolor"          "clayer"
    (if        (not (member
               msg
GMT+8, 2026-1-16 14:10 , Processed in 0.136507 second(s), 18 queries , Gzip On.
