查看: 58513|回复: 9
启动cad时,参数类型错误: stringp nil 怎么办啊
发表于 2003-9-8 09:03:00 | 显示全部楼层 |阅读模式
我在启动cad时,出现参数类型错误: stringp nil 该怎么办啊,急死了。
 楼主| 发表于 2003-9-8 21:08:00 | 显示全部楼层
cad2002,windows2000,出现错误后使用正常,我知道这个问题的解决方案在支持助手里有,将stringp nil 输入支持助手的搜索里,点击搜索出来的第1项就是专门针对这个问题的解决方案,有谁帮我看看。
    When you start a network version of AutoCAD, the following error message is displayed:
bad argument type stringp nil' error
AutoCAD then continues to load and runs normally.
Solution
This error occurs when the Start in folder for the shortcut that starts AutoCAD is a Universal Naming Convention location (UNC path) on the network. The following example shows UNC paths used in the shortcut properties:
Target = \\bilbo\apps\acad\acad.exe /c c:\acad2000
Start in = \\bilbo\apps\acad
One solution to this problem is to map a drive to the AutoCAD folder, and then change the Start in folder to the mapped drive.
To map a drive in Microsoft?/SUP> Windows?/SUP>
In Windows Explorer, click Network Neighborhood and browse to and select the AutoCAD folder on the network drive.
Right-click the AutoCAD folder and choose Map Network Drive from the shortcut menu.
Assign an unused drive letter (For example, T), and then choose OK.
To change the Start in folder for the shortcut that starts AutoCAD
On the Windows desktop, right-click the icon for the shortcut that starts AutoCAD and choose Properties from the shortcut menu.
On the Shortcut tab, change the Start in location to use the mapped network drive. In the following example, T is the drive that was mapped from the AutoCAD folder on the network:
Start in = T:\
Choose OK.
You should now be able to start AutoCAD without encountering the error.
谁有2002中文版的支持助手啊
发表于 2003-9-8 10:58:00 | 显示全部楼层
怎么提示的?在命令行还是对话框?
说说你的版本情况,看这个提示不象是CAD系统的错误,象加载了外部程序出现的一般性错误。
还有提示完后你的CAD能否使用?
 楼主| 发表于 2003-9-8 15:08:00 | 显示全部楼层
在命令行,显示错误,参数类型错误: stringp nil 这在支持助手里有这个问题的解决方案,是因为的我看不懂。谢谢meflying !
发表于 2003-9-8 15:50:00 | 显示全部楼层
一个变量出现了问题.
可能是CAD一打开自动加载的程序有问题.
如果是lsp程序的话.可以打开
acad.lsp
acad200doc.lsp
acad.mnl
等看看,自动加载了哪些不是AutoCAD自身的lsp,在分别加载运行一下,当然功力够的话,也可以直接查看lsp的原码来确定是哪个lsp程序有问题了
以上供参考!
发表于 2003-9-8 20:15:00 | 显示全部楼层
太同情你了,我也遇到了
版本是2002,系统是xp的,可以画图,但是不能使用任何三维绘图的命令,连面域 的命令也不可以,二维的倒没关系
发表于 2003-9-9 00:13:00 | 显示全部楼层
翻译一下,大意如下:
这个错误发生在你从一个网络共享路径(UNC路径名)而不是本地路径启动autocad时.
解决办法:利用windows的"映射网络驱动器"功能将网络共享路径映射成本地盘符.
发表于 2004-8-19 10:10:00 | 显示全部楼层
cefrykl发表于2003-9-9 0:13:00翻译一下,大意如下:这个错误发生在你从一个网络共享路径(UNC路径名)而不是本地路径启动autocad时.解决办法:利用windows的\"映射网络驱动器\"功能将网络共享路...
兄台,具体该怎么做?请指教,现在这个问题在我公司和家里的电脑上较普遍了,急啊 大部分命令没问题,只是“x”分解(炸开)命令无法使用,很不方便。可是完全关掉CAD后,再次打开-新建一个dwg文件,又可以使用“X”这个命令,但只要一开以前的图,这个问题就又出现了!
发表于 2007-8-24 20:08:00 | 显示全部楼层
alan9发表于2004-8-19 10:10:00大部分命令没问题,只是“x”分解(炸开)命令无法使用,很不方便。可是完全关掉CAD后,再次打开-新建一个dwg文件,又可以使用“X”这个命令,但只要一开以前的图,这个问题就又出现了!
我也出现一样的问题,不过“X”不可以使用,就用“_.X”就可以炸开了,虽然有点麻烦。希望知道解决方法的大侠指导一下。
发表于 2007-8-27 23:12:00 | 显示全部楼层
可能你感染CAD病毒了!用CAD专杀工具或6.0版的卡巴斯基杀毒软件可以查杀。
你可以看看acad.lsp的内容,正常情况下2002以上版本是没有这个文件的。
或者干脆把电脑里的所有acad.lsp文件删除即可(如果你没有安装R14的话)。
GMT+8, 2025-8-20 05:17 , Processed in 0.184608 second(s), 25 queries , Gzip On.
