查看: 2128|回复: 2
[基础] 为对象增加扩展数据
发表于 2013-8-3 08:15:44 | 显示全部楼层 |阅读模式
从网上找的,提供给大家
  1. (defun XD-M()
  2.        (while (not(setq en (entsel "选择一个实体:")))
  3.               (alert "没选中任何实体...")
  4.         )
  5.        (princ "\n(现有")(princ(XDRoom(car en)))
  6.        (princ "\n字节的扩展实体数据空间.)\n")
  7.        (setq en (car en)
  8.              un (getstring "\n应用名:")
  9.        )
  10.        (if  (XD-C en un)
  11.             (progn (textscr)
  12.                    (princ "\n这个应用名已经存在了,要覆盖它吗?")
  13.                    (initget 7 "Yes No")
  14.                    (if (= "Yes" (getkword "Yes/<No>:"))
  15.                        ()
  16.                        (abcdefg)
  17.                    )
  18.             )
  19.         )
  20.        (setq ll (list (cons 1002 "}")))
  21.        (initget 7 "Real Integer String")
  22.        (setq tp (getkword "Real(实数)/Integer(整数)/String(字串):"))
  23.        (while (not(or (= tp "End")(= tp "")))
  24.               (cond ((= tp "Real")
  25.               (setq v (getreal "\n实型数:") l (cons 1040 v))
  26.               )
  27.               ((= tp "String")
  28.               (setq v (getstring "\n字符串:") l (cons 1000 v))
  29.               )
  30.               ((= tp "Integer")
  31.               (setq v (getint "\n整型数:") l (cons 1071 v))
  32.               )
  33.         )
  34.         (setq ll (cons l ll))
  35.         (initget 7 "Real Integer String End")
  36.         (setq tp (getkword "Real(实数)/Integer(整数)/String(字串)/<End>:"))
  37.        )
  38.        (setq ll (cons (cons 1002 "{") ll)
  39.              ll (list -3 (cons un ll))
  40.              el (entget en)
  41.              nel (cons ll el)
  42.        )
  43.        (regapp un)(entmod nel)
  44.   )
发表于 2013-8-26 11:57:04 | 显示全部楼层
XD-C函数缺失
还有怎样读取扩展数据呢?
发表于 2013-10-18 08:22:07 | 显示全部楼层
楼主补下函数,XD-c  , (abcdefg)?
GMT+8, 2025-7-19 03:43 , Processed in 0.169132 second(s), 26 queries , Gzip On.
