楼主: 明经快报
[LISP群(1)] 2013-09-20 明经 AutoLISP 编程(102918348) 群聊记录:(ssget "x" (list (cons xx xx
 关闭 [复制链接]
 楼主| 发表于 2013-9-20 22:42:19 | 显示全部楼层
[dcl1214]昌立 22:42:19
哪位高僧看看这个如何解决啊
[dcl1214]昌立 22:47:24
多级的
[dcl1214]昌立 22:48:31
[qqimg]201309/{AA389976-FF74-3A7C-60D3-4E6B98F1FBED}.jpg[/qqimg]
[qqimg]201309/{187C543B-6198-7197-85CC-9EB796545F40}.jpg[/qqimg]
[dcl1214]昌立 22:49:25
想动态添加右键菜单
[dcl1214]昌立 22:52:50
(vlax-for item (vla-get-menugroups (vlax-get-acad-object))
  (if (= (strcase (vl-filename-base (getvar "menuname")))
         (vla-get-name item)
    (vlax-for menu (vla-get-menus item)
      (if (= :vlax-true (vla-get-shortcutmenu menu))
          (setq        new-macro
                 "$M=$(if,$(!=,$(getvar,cmdactive),0),$P0=*,line )"
          (setq        new-macro1
                 "$M=$(if,$(!=,$(getvar,cmdactive),0),$P0=*,copy )"
          (vla-addmenuitem menu 0 "画线(&L)" new-macro)
          (vla-addmenuitem menu 1 "复制(&C)" new-macro1)
;;;          (setq exist-shortcut t)
目前添加同级可以,下级就不知道如何操作了
要的就是lisp
GMT+8, 2026-1-10 10:42 , Processed in 0.130134 second(s), 17 queries , Gzip On.
