楼主: adc
[提问] 填充的图层名
发表于 2013-11-19 13:45:30 | 显示全部楼层
adc 发表于 2013-11-19 13:31
还是要麻烦你帮忙,现在程序还是不能执行,我已经把完整的贴出来了麻烦帮忙看看
  1. (defun SETLAYER(LAY CLR / AcDocument layerObj)
  2.   (vl-load-com)
  3.   (setq layerObj(vla-add(vla-get-Layers(setq AcDocument(vla-get-ActiveDocument(vlax-get-acad-object))))LAY))
  4.   (vla-put-ActiveLayer AcDocument layerObj)
  5.   (vla-put-Color layerObj CLR)
  6. )
  7. (defun SETLAYER_LSP(LAY CLR)
  8.   (if (=(tblobjname "LAYER" LAY) nil)
  9.     (entmake (list'(0 . "LAYER")'(100 . "AcDbSymbolTableRecord")'(100 . "AcDbLayerTableRecord")
  10.        '(6 . "CONTINUOUS")(cons 62 CLR)'(70 . 0)(cons 2 LAY)))) (setvar "CLAYER" LAY)
  11.   )
用上边两个函数中的任何一个都可以,最好别用COMMAND,很多命令会因为版本有点差异
 楼主| 发表于 2013-11-20 10:44:56 | 显示全部楼层
我替换了还是不能执行,是不是这句有问题(and (setq E (ssname SS (setq I (1- I)))LA(strcat(cdr(assoc 8 e))"填充"))
发表于 2013-11-20 11:03:03 | 显示全部楼层
adc 发表于 2013-11-20 10:44
我替换了还是不能执行,是不是这句有问题(and (setq E (ssname SS (setq I (1- I)))LA(strcat(cdr(assoc  ...
你那个AND起什么作用的?
adc + 1 赞一个!
 楼主| 发表于 2013-11-24 13:11:55 | 显示全部楼层
llsheng_73 发表于 2013-11-20 11:03
你那个AND起什么作用的?
我也不清楚,这个程序不是我写的,删掉也还是不可以,麻烦帮忙看一下吧
发表于 2013-11-24 13:13:38 | 显示全部楼层
弄了半天你找了个别人的程序!!
首先它原来能运行不?
 楼主| 发表于 2013-11-24 13:28:53 | 显示全部楼层
llsheng_73 发表于 2013-11-24 13:13
弄了半天你找了个别人的程序!!
首先它原来能运行不?
以前可正常运行的
发表于 2013-11-24 13:54:53 | 显示全部楼层
(defun C:tt (/ old_clayer old-layer HPNAME SETLAYER_LSP)
    (setvar "CLAYER" LAY))
   (vl-load-com)
   (command "undo" "be")
   (setvar "CMDECHO" 0)
;  (setq old_clayer (getvar "clayer"))
;  (setq old-layer (tblsearch "layer" "PUB_HATCH"))
;  (if (null old-layer) (command "-layer" "m" "PUB_HATCH" "c" 252 "" ""))
; (command  "layer"  "t"  "PUB_HATCH"  "")
; (command  "layer"  "on"  "PUB_HATCH"  "")
;  (setvar "clayer" "PUB_HATCH")
   (vla-endundomark
     (vla-get-activedocument
   (vla-startundomark
   (setq HPNAME (getvar "HPNAME"))
   (setvar "HPNAME" "SOLID")
   (vl-catch-all-apply
     '(lambda (/ E I SS)
        (setq SS (ssget '((0 . "LWPOLYLINE"))))
             (repeat (setq I (sslength SS))
               (SETLAYER_LSP(setq E (ssname SS (setq I (1- I)))
                                  LA(strcat(cdr(assoc 8(entget E)))"填充"))7)
             ;  (command "LAYER" "M"LA "S"LA"")
               (command ".-BHATCH" "S" E "" "")
                    ;;(command "hatch" "solid" E "")
   (setvar "HPNAME" HPNAME)
   (vla-endundomark
   (setvar "clayer" old_clayer)
   (command "undo" "e")
adc + 1 赞一个!
发表于 2013-11-24 13:56:12 | 显示全部楼层
达到目的的思路就不好,应该随意填充,然后全图填充自动归并到相应层,因为图有可能是从别人那里接手的。不是要多一道处理吗?
发表于 2013-11-24 19:31:29 | 显示全部楼层
q3_2006 发表于 2013-11-24 13:56
达到目的的思路就不好,应该随意填充,然后全图填充自动归并到相应层,因为图有可能是从别人那里接手的。不 ...
正因为图可能从别人哪里接手,随意填充的话,最后归并更不好找依据了,按说楼主本来的想法是没什么问题的
发表于 2013-11-25 18:22:42 | 显示全部楼层
程序有时能运行,有时不行。无效果
GMT+8, 2026-1-18 04:36 , Processed in 0.165919 second(s), 20 queries , Gzip On.
