楼主: 李青松
[已解答] 中间带交叉线的矩形的程序,若能修改1下就好了
发表于 2015-8-17 10:57:08 | 显示全部楼层
这是生成虚线的:
  1. (defun c:tt (/ p1 p2 p3 p4)
  2.   (setq p1 (getpoint "\rFirst point:"))
  3.   (setq p2 (getcorner p1 "\rSecond point:"))
  4.   (if (and (= (type p1) 'LIST) (= (type p2) 'LIST))
  5.     (progn
  6.       (setq p3 (list (car p1) (cadr p2))
  7.       p4 (list (car p2) (cadr p1))
  8.       )
  9.       (if (null (tblsearch "LTYPE" "HIDDEN"))
  10.           (vla-load (vla-get-Linetypes (vla-get-ActiveDocument (vlax-get-acad-object))) "HIDDEN" "acad.lin")
  11.   )
  12.       (entmake (list '(0 . "LINE")
  13.          '(100 . "AcDbEntity")
  14.          '(100 . "AcDbline")
  15.          '(6 . "HIDDEN")
  16.          '(8 . "TEST2")
  17.          (cons 10 p1)
  18.          (cons 11 p2)
  19.          )
  20.          )
  21.       (entmake (list '(0 . "LINE")
  22.          '(100 . "AcDbEntity")
  23.          '(100 . "AcDbline")
  24.          '(6 . "HIDDEN")
  25.          '(8 . "TEST2")
  26.          (cons 10 p3)
  27.          (cons 11 p4)
  28.          )
  29.          )
  30.       (entmake (list '(0 . "LWPOLYLINE")
  31.          '(100 . "AcDbEntity")
  32.          '(8 . "TEST2")
  33.          '(100 . "AcDbPolyline")
  34.          (cons 90 4)
  35.          (cons 10 p1)
  36.          (cons 10 p3)
  37.          (cons 10 p2)
  38.          (cons 10 p4)
  39.          (cons 70 1)
  40.          )
  41.          )
  42.       )
  43.     (princ "\Input Invalid point.")
  44.     )
  45.   (princ)
  46.   )
发表于 2016-10-15 17:05:58 | 显示全部楼层
正需要,谢谢
发表于 2019-4-12 10:11:08 | 显示全部楼层
mark下,正需要呢
GMT+8, 2026-1-19 11:46 , Processed in 0.902059 second(s), 24 queries , Gzip On.
