查看: 1601|回复: 1
[提问] 请教关于vlax-put-property的使用
发表于 2013-11-7 08:39:43 来自手机 | 显示全部楼层 |阅读模式
用(vlax-get-property obj 'text 1 1)可以得到索引1,1的属性值,如果要设置属性值的话应该怎么写?
试了下(vlax-put-property obj 'text 1 1 "xxx")提示类型不匹配
发表于 2013-11-7 12:53:46 | 显示全部楼层
;; Get Attribute Value  -  Lee Mac
;; Returns the value held by the specified tag within the supplied block, if present.
;; blk - [vla] VLA Block Reference Object
;; tag - [str] Attribute TagString
;; Returns: [str] Attribute value, else nil if tag is not found.
(defun LM:vl-getattributevalue ( blk tag )
    (setq tag (strcase tag))
    (vl-some '(lambda ( att ) (if (= tag (strcase (vla-get-tagstring att))) (vla-get-textstring att)))
        (vlax-invoke blk 'getattributes)
;; Set Attribute Value  -  Lee Mac
;; Sets the value of the first attribute with the given tag found within the block, if present.
;; val - [str] Attribute Value
;; Returns: [str] Attribute value if successful, else nil.
(defun LM:vl-setattributevalue ( blk tag val )
    (vl-some
       '(lambda ( att )
                (progn (vla-put-textstring att val) val)
GMT+8, 2026-1-7 22:10 , Processed in 0.147864 second(s), 25 queries , Gzip On.
