楼主: 明经快报
[LISP群(1)] 2013-11-14 明经 AutoLISP 编程(102918348) 群聊记录:大家好
 关闭 [复制链接]
 楼主| 发表于 2013-11-14 22:34:28 | 显示全部楼层
[偏爱云~小吴]偏 22:34:28
defun C:tt (/ EN ENT LST LST1 OLDAUN OLDOSM T SS STR TXT ZG)
  (setq oldaun (getvar "aunits")
oldosm (getvar "osmode"))
  (setvar "aunits" 3)   ;设为弧度
  (setvar "osmode" 0 )                   ;设为无捕捉方式
  (setq ss (ssget '((0 . "TEXT"))))
   (if (not ss)                     ;图中没有插入各种符号
    (progn (alert " 没有选中文本")
           (exit))
      (while (> (sslength ss) 0)
(setq ent (entget(setq en (ssname ss 0))));取出第一个数据
(setq pt (cdr(assoc 10 ent))
      txt (cdr(assoc 1 ent))
      zg (cdr(assoc 40 ent))
      lst (cons (list pt txt zg) lst);;获取表
      ss (ssdel en ss))
(entdel  en));删除图元
      (setq lst1 (vl-sort lst
         (function (lambda (e1 e2)
                (< (cadr(car e1)) (cadr(car e2))) ) ) ));根据y坐标排序
      (setq str "")
      (foreach e lst1
(setq str (strcat (cadr e) "\n" str))
(setq pt (car e);插入点
    zg (caddr e)));字高
      (setq pt (polar pt (* pi 0.5) zg))
      (vl-cmdf "MTEXT" pt "H" zg "W" 0 (substr str 1 (1- (strlen str))) "")))
  (setvar "aunits" oldaun)   ;设为弧度
  (setvar "osmode" oldosm )
如何将以上代码改为矩形框内批量选择自动转换
 楼主| 发表于 2013-11-14 22:58:30 | 显示全部楼层
[ZZXXQQ] 22:58:30
(defun C:tt (/ EN ENT LST LST1 OLDAUN OLDOSM T SS i ptlst ss1 STR TXT ZG)
 ;选择封闭方框
 (if (setq ss (ssget '((0 . "LWPOLYLINE") (70 . 1) (90 . 4)))) (progn
  (setq i -1)
  (repeat (sslength ss)
   (setq ent (entget(ssname ss (setq i (1+ i)))))
   (setq ptlst (list))
   (foreach x ent (if (= (car x) 10) (setq ptlst (cons (cdr x) ptlst))))
   (if (setq ss1 (ssget "WP" ptlst '((0 . "TEXT")))) (progn
    (while (> (sslength ss1) 0)
     (setq ent (entget(setq en (ssname ss1 0))));取出第一个数据
           ss (ssdel en ss1))
     (entdel en);删除图元
    (setq lst1 (vl-sort lst '(lambda (e1 e2) (< (cadar e1) (cadar e2)))));根据y坐标排序
    (setq str "")
    (foreach e lst1 (setq str (strcat (cadr e) "\n" str)))
    (setq pt (car (last lst1));插入点
          zg (last (last lst1)));字高
GMT+8, 2026-1-5 09:41 , Processed in 0.215534 second(s), 16 queries , Gzip On.
