查看: 1090|回复: 0
[讨论] 椭圆中心标记
发表于 2013-11-19 09:13:19 | 显示全部楼层 |阅读模式
  1. ;;椭圆中心标记
  2. ;;用highflybir的程序改造一下
  3. (defun HH:ELLIPSEMark (ent / DXF MAJ P1 P10 P2 P3 P4 PTB PTD SS)
  4.   (setq dxf (entget ent))
  5.   (setq p10 (cdr (assoc 10 dxf)))
  6.   (if (and (setq ss (ssget "_C"
  7.                            p10
  8.                            p10
  9.                            (list '(-4 . "<or")          '(0 . "LINE")           '(-4 . "<and")
  10.                                  '(0 . "LWPOLYLINE")                   '(90 . 2)
  11.                                  '(-4 . "and>")          '(-4 . "or>")
  12.                                 )
  13.                     )
  14.            )
  15.            (> (sslength ss) 1)
  16.       )
  17.     nil
  18.     (progn
  19.       (setq maj (cdr (assoc 11 dxf)))
  20.       (setq ptb (vlax-curve-getPointAtParam ent (* pi 0.5)))
  21.       (setq ptd (vlax-curve-getPointAtParam ent (* pi 1.5)))
  22.       (setq p1 (mapcar '- ptd maj))
  23.       (setq p2 (mapcar '+ ptd maj))
  24.       (setq p3 (mapcar '+ ptb maj))
  25.       (setq p4 (mapcar '- ptb maj))
  26.       (entmake (list (cons 0 "LINE") (cons 10 p1) (cons 11 p3)))
  27.       (entmake (list (cons 0 "LINE") (cons 10 p2) (cons 11 p4)))
  28.     )
  29.   )
  30. )
  31. (defun C:W5 (/ EN)
  32.   (setq ent (car (entsel)))
  33.   (HH:ELLIPSEMark ent)
  34.   (princ)
  35. )
GMT+8, 2026-1-5 09:32 , Processed in 0.165694 second(s), 26 queries , Gzip On.
