楼主: 混沌初开
[讨论] 快速串线
 楼主| 发表于 2013-11-30 17:41:29 | 显示全部楼层
混沌初开 发表于 2013-11-30 17:39
试了一下,用上楼的"五星"串线,有时一下能串好,有时候还让选择(如下图)
失灵时候的样子
发表于 2013-11-30 19:01:50 | 显示全部楼层
有请附上 如上 的调试用*.Dwg
 楼主| 发表于 2013-11-30 19:12:32 | 显示全部楼层
串线dwg档
发表于 2013-11-30 19:42:52 | 显示全部楼层
CAD2004 ok
Command: (defun c:TT(/ aa)
(_>   (setq aa (ssget))
(_>   (command "PEDIT" "M" aa "" "j" "" "")
(_> (princ)
(_>   )
C:TT
Command: tt
Select objects: Specify opposite corner: 16 found
Select objects:
PEDIT Select polyline or [Multiple]: M
Select objects:   16 found
Select objects:
Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype gen/Undo]: j
Join Type = Extend
Enter fuzz distance or [Jointype] <0.0000>:
15 segments added to polyline
Command:
另请参考:
Type: Integer
Saved in: Registry
Initial value: 0
Suppresses display of the Object Selected Is Not a Polyline prompt in PEDIT.
The prompt is followed by "Do you want it to turn into one?"
Entering y converts the selected object to a polyline.
When the prompt is suppressed,
the selected object is automatically converted to a polyline.
0 The prompt is displayed
1 The prompt is suppressed
 楼主| 发表于 2013-12-1 00:28:36 | 显示全部楼层
Andyhon 发表于 2013-11-30 19:42
CAD2004 ok
发的是什么意思?
在2004的执行的讯息,正常...  发表于 2013-12-1 08:07
发表于 2013-12-1 02:11:12 | 显示全部楼层
是有时会选到直线,弧等,所以会问你是否转换为多线段吧?
  1. (defun c:TT(/ a b c i n f)
  2.   (setq a(ssget)i 0)
  3.   (if a(progn(setq n(sslength a))
  4.    (while(< i (sslength a))
  5.      (setq b(cdr(assoc 0(entget(setq c(ssname a i)))))i(1+ i))
  6.      (if (not(member b'("POLYLINE""LWPOLYLINE""LINE""ARC")))(setq a(entdel c a))
  7.        (if(member b'("LINE""ACR"))(setq f t))))
  8.    (if f(command "PEDIT" "M" a """Y" "j" "" "")(command "PEDIT" "M" a "" "j" "" ""))))
  9.   (princ)
  10.    )
;;先看下选中的东东里边是否有不是多线段但能转换为多线段的?
;;好象还应该优化,因为PE的时候它会自动剔除一些实体类别?
 楼主| 发表于 2013-12-1 20:52:20 | 显示全部楼层
73大神,真厉害!
发表于 2013-12-6 08:11:22 | 显示全部楼层
论坛里面我早就发了一个,他会有一个提示,确认转换的
http://bbs.mjtd.com/thread-84513-1-1.html
发表于 2013-12-6 08:44:36 | 显示全部楼层
猜测LZ要如下代码
  1. ;;164.29 [功能] 连接线、弧成多段线
  2. ;;(HH:JionToPolyline)
  3. (defun HH:JionToPolyline (/ PET SS)
  4.   (setq pet (getvar "PEDITACCEPT"))
  5.   (setvar "PEDITACCEPT" 1)
  6.   (while (setq ss (ssget '((0 . "ARC,*LINE"))))
  7.     (command "_.pedit" (ssname ss 0) "j" ss "" "")
  8.   )
  9.   (setvar "PEDITACCEPT" pet)
  10.   (princ)
  11. )
GMT+8, 2025-12-23 14:20 , Processed in 0.173298 second(s), 24 queries , Gzip On.
