楼主: 香田里浪人
[已解答] 多义线边长标注
发表于 2014-3-22 20:38:57 | 显示全部楼层
如果此程序能在多线的质心处标上面积就好了
 楼主| 发表于 2014-3-25 07:06:02 | 显示全部楼层
试试这个
(defun c:mjbc(/ ACADDOC ACADSPC OBJAREA OBJLLPOINT OBJRUPOINT SELECTIONSET TEXTBASEPOINT TEXTHEIGHT TEXTINDEX TEXTOBJ)
(setvar"dimzin"0);;保留小数位数时如果位数不足可以补零
   (vl-load-com)
   (setq AcadDoc (vla-get-activedocument (vlax-get-acad-object)))
   (if (= (getvar "TILEMODE") 1)(setq AcadSpc (vla-get-modelspace AcadDoc))(setq AcadSpc (vla-get-paperspace AcadDoc)))
   (setq TextHeight (getdist "\n输入标注面积文字高度:")
TextIndex (getint "\n输入起始编号:")
   (ssget '((0 . "CIRCLE,LWPOLYLINE")))
(command "layer" "M" "面积边长" "C" "4" "" "LT" "CONTINUOUS" "" "");设置一个标注图层
(command "style" "tukou" "黑体" "0" "" "0" "" "")
(defun maketext (txt pt)             ; 生成文字子函数
    (entmake (list '(0 . "TEXT") (cons 10 pt) (cons 40 TextHeight) (cons 1 txt) '(41 . 0.8)'(7 . "BG_ST")))
   (setq Selectionset (vla-get-activeselectionset AcadDoc))
   (if (and TextHeight Selectionset TextIndex)
     (vlax-for Obj Selectionset
       (setq ObjArea (vla-get-area obj)
      ObjLlPoint nil
      ObjRuPoint nil
       (vla-GetBoundingBox Obj 'ObjLlPoint 'ObjRuPoint)
       (setq TextBasePoint (mapcar '(lambda(x y) (/ (+ x y) 2)) (vlax-safearray->list ObjLlPoint)(vlax-safearray->list ObjRuPoint))
      TextObj (vla-addtext AcadSpc (strcat "S"(itoa TextIndex) "=" (rtos (/ ObjArea 1)2 2) "㎡") (vlax-3d-point TextBasePoint) TextHeight)
       (vla-put-alignment TextObj acAlignmentCenter)
       (vla-put-TextAlignmentPoint TextObj (vlax-3d-point TextBasePoint))
       (setq TextIndex (1+ TextIndex))
(defun AddText (obj TextString  InsertionPoint  Height xz kb qx Alignment style / obj1 err)
  (setq obj1 (vla-addtext obj TextString  (vlax-3d-point InsertionPoint)  Height))
  (vla-put-Rotation obj1 xz)
  (vla-put-ScaleFactor obj1 kb)
  (vla-put-ObliqueAngle obj1 qx)
  (vla-put-alignment obj1 Alignment)
  (if (/= Alignment acAlignmentLeft)
    (vla-put-TextAlignmentPoint obj1 (vlax-3d-point InsertionPoint))
    (vla-put-InsertionPoint obj1 (vlax-3d-point InsertionPoint))
   (VL-CATCH-ALL-APPLY 'vla-put-StyleName (list obj1 style))
  obj1
(setq pi2 (/ pi 2))
  (setq ms (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-acad-object))))
(setq  TextHeight (getdist "\n输入标注边长文字高度:")
        kgb         0.60 ; 宽高比
      DimScale 1 ; 边长尺度,若单位为mm,该值为1000
        flag        T;nil标注在多段线走向的右侧,T 左侧
) ;_ setq
(setq pen-n 0)
(if (setq pen-all (ssget '((0 . "*polyline"))))
    (repeat (sslength pen-all)
            (setq pianju (* TextHeight 0.7)) ;边长离线距离
            (setq pen-en (ssname pen-all pen-n))
            (setq obj (vlax-ename->vla-object pen-en)
                  n 0)
              (while (and (setq pt (vlax-curve-getPointAtParam obj n))
              (setq np (vlax-curve-getPointAtParam obj (1+ n)))
         ) ;_ 结束and
    (if        (/= 0.0 (setq bugle (vla-GetBulge obj n)))
        (setq midpt (vlax-curve-getPointAtParam obj (+ 0.5 n))
             bj (* (atan (abs bugle)) 4)
            xc (* 0.5 (distance Pt np))
            gg (abs (* bugle xc))
            rr (/ (+ (* xc xc) (* gg gg)) (* 2 gg))
            ang1 (angle pt np)
            cp (polar Pt ang1 xc)
            cp (polar midpt (angle midpt cp) rr)
            bc (rtos (/ (- (vlax-curve-getDistAtParam obj (1+ n)) (vlax-curve-getDistAtParam obj n)) DimScale) 2 2)
       (if flag
            (setq zjp (polar midpt (cond ((> bugle 0)(angle midpt cp))(t (angle  cp midpt))) pianju))
            (setq zjp  (polar midpt (cond ((> bugle 0)(angle  cp midpt))(t (angle midpt cp))) pianju))
        (if (not (or (and (>= ang1 0) (< ang1 (* 0.666666 pi))) (and (> ang1 (* 1.666666 pi)) (< ang1 (* 2.0 pi)))))
         (setq ang1 (- ang1 pi))
        (AddText ms bc  zjp  TextHeight ang1 kgb 0 acAlignmentMiddle Style)
     );progn
              ang1 (angle pt np)
        (if flag
            (setq zjp (polar midpt (+ pi2 ang1) pianju))
          (setq zjp (polar midpt (- ang1 pi2) pianju))
        (if (not (or (and (>= ang1 0) (< ang1 (* 0.666666 pi))) (and (> ang1 (* 1.666666 pi)) (<= ang1 (* 2.0 pi)))))
      );progn
    ) ;结束if
    (setq n (1+ n))
  ) ; 结束while
  (setq pen-n (1+ pen-n)))
发表于 2014-6-28 22:40:20 | 显示全部楼层
zyhandw 发表于 2014-1-18 09:09
也看过一些楼主发的帖子,我想这应该不能难倒楼主啊,如下是帮你改了以后的程序,试试看看是否是你想要的结 ...
膜拜下大师
发表于 2014-9-6 16:38:33 | 显示全部楼层
论坛是个好地方啊!!!
GMT+8, 2025-12-16 11:21 , Processed in 0.153111 second(s), 19 queries , Gzip On.
