楼主: 312735894
[已解答] 二维多段线没有顶点表,怎么提取顶点坐标呢?(注意:不是多段线)还请各位大大解答!
发表于 2014-1-25 13:14:54 | 显示全部楼层
USER2128 发表于 2014-1-25 08:38
;;;来一个固版主的:
(setq ent (car(entsel "\n选取多段线: ")))
(mapcar 'cdr (vl-remove-if-not '(lam ...
G版的只能是多段线,二维用这个
  1. ;;支持2D\3D多段线点提取
  2. ;;edit by edata 2014-1-25
  3. (defun sk_vertex(ent / lst ety x)
  4.   (defun sk_dxf(en code)
  5.     (cdr (assoc code (entget en)))
  6.     )
  7.   (setq        lst '()
  8.         ety (sk_dxf ent 0)
  9.         )
  10.   (cond
  11.     ((= ety "POLYLINE")
  12.      (while (/= (sk_dxf ent 0) "SEQEND")
  13.        (setq ent(entnext ent))
  14.        (if (= (sk_dxf ent 0) "VERTEX")
  15.          (setq lst(cons (sk_dxf ent 10) lst))))
  16.      (if(/= lst '())(reverse lst) nil))
  17.     ((= ety "LWPOLYLINE")
  18.      (setq e1(entget ent))
  19.      (while (setq pt(car e1))
  20.        (if(= (car pt) 10)
  21.          (setq lst(cons (cdr pt) lst))
  22.          )
  23.        (setq e1(cdr e1)))
  24.
  25.      (if(/= lst '())(reverse lst) nil)
  26.      ;(mapcar 'cdr (vl-remove-if-not '(lambda(x)(= 10 (car x)))(entget ent)))
  27.      )
  28.     )
  29.   )
  30. (defun c:tt()
  31.   (sk_vertex (car (entsel)))
  32.   )
发表于 2014-1-25 13:41:31 | 显示全部楼层
  1. (defun Plinexy(e / p a b n ob q et d d1 en et)
  2.    (setq a(entget e)ob(vlax-ename->vla-object e)et(cdr(assoc 0 a))n 0 p nil d nil)
  3.    (cond((="LWPOLYLINE"et)
  4.          (repeat(length a)(setq b (nth n a) n (+ n 1))
  5.            (if (= 10 (car b))(progn
  6.                                (setq q(list (cadr b) (caddr b))d1(vlax-curve-getDistAtPoint ob q))
  7.                                (if p (if (not(member d1 d)) (setq p (append p (list q))d (append d (list d1))))
  8.                                  (setq p (list q))))
  9.              )))
  10.         ((="POLYLINE"et)
  11.          (SETQ EN (ENTGET (SETQ E (ENTNEXT E))))
  12.          (WHILE (/= (CDR (ASSOC 0 EN)) "SEQEND")
  13.            (SETQ q (CDR (ASSOC 10 EN))d1(vlax-curve-getDistAtPoint ob q)q(reverse(cdr(reverse q))))
  14.            (if p(if (not(member d1 d)) (setq p (append p (list q))d (append d (list d1))))
  15.              (setq p (list q)))
  16.            (SETQ EN (ENTGET (SETQ E (ENTNEXT E)))))
  17.          (setq p(reverse p))
  18.          ))
  19.    P)
;;二维、三维、多线段节点坐标(滤掉了多余点,未处理假闭合)
发表于 2014-1-25 14:17:26 | 显示全部楼层
;;;来一个固版主的:
那啥,这是提取多段线的吧,二维多段线是不行的
发表于 2014-1-25 14:18:44 | 显示全部楼层
谢谢大大帮助,感谢!
发表于 2014-1-25 16:15:04 来自手机 | 显示全部楼层
llsheng_73 发表于 2014-1-25 13:41 ;;二维、三维、多线段节点坐标(滤掉了多余点,未处理假闭合)
看看7楼的链接,可以省点代码。
发表于 2014-1-27 01:34:22 | 显示全部楼层
纯Alisp提取多段线 2D\3D多段线顶点,去重复点加闭合
  1. ;;支持2D\3D多段线点提取,重复点将去掉\处理假的闭合
  2. ;;暂时未考虑多点共线
  3. ;;edit by edata 2014-1-26
  4. ;;modfiy by edata 2014-1-27
  5. ;;要放假了,又得消失一段时间
  6. ;;(mapcar 'cdr (vl-remove-if-not '(lambda(x)(= 10 (car x)))(entget ent)))
  7. (defun sk_vertex(ent / lst ety x)
  8.   (defun sk_dxf(en code)
  9.     (cdr (assoc code (entget en)))
  10.     )
  11.   (defun sk_removept(lst flag / newlst)
  12.   (setq newlst '())
  13.     (while (car lst)
  14.       (if (not(equal (car lst) (cadr lst) 1e-8))
  15.         (setq newlst(cons (car lst) newlst)))
  16.       (setq lst(cdr lst))
  17.       )
  18.   (if(/= newlst '())
  19.     (if (or(and flag
  20.              (= flag 1)
  21.              (equal (car newlst)(last newlst) 1e-8))
  22.            (equal (car newlst)(last newlst) 1e-8))
  23.       (reverse (cdr newlst))
  24.       (reverse newlst)
  25.       )
  26.     nil )
  27.   )
  28.   (setq lst '()
  29.         ety (sk_dxf ent 0)
  30.         isclosed (logand 1(sk_dxf ent 70))
  31.         )
  32.   (cond
  33.     ((= ety "POLYLINE")
  34.      (while (/= (sk_dxf ent 0) "SEQEND")
  35.        (setq ent(entnext ent))
  36.        (if (= (sk_dxf ent 0) "VERTEX")
  37.          (setq lst(cons (sk_dxf ent 10) lst))))
  38.      (if(/= lst '())(sk_removept (reverse lst) isclosed) nil))
  39.     ((= ety "LWPOLYLINE")
  40.      (setq e1(entget ent))
  41.      (while (setq pt(car e1))
  42.        (if(= (car pt) 10)
  43.          (setq lst(cons (cdr pt) lst))
  44.          )
  45.        (setq e1(cdr e1)))
  46.      (if(/= lst '())(sk_removept (reverse lst) isclosed) nil)
  47.      )
  48.     )
  49.   )
  50. (defun c:tt()
  51.   (princ(sk_vertex (car (entsel))))
  52.   ;(princ(Plinexy (car (entsel))))
  53.   (princ)
  54.   )
发表于 2018-7-3 20:17:55 | 显示全部楼层
学习一下。。我一般都是把二维多段线转为多段线再编辑的。
GMT+8, 2026-1-20 02:16 , Processed in 0.924220 second(s), 20 queries , Gzip On.
