楼主: mccad
[2015] AutoCAD 2015 英文版已经出来了,喜欢尝新的可以试试
发表于 2014-3-16 15:54:20 | 显示全部楼层
密码好像不对
发表于 2014-3-17 14:07:43 | 显示全部楼层
老大,密码不对啊,打不开?
发表于 2014-3-17 19:00:36 | 显示全部楼层
天正建筑挂不上
发表于 2014-3-17 19:41:43 | 显示全部楼层
kwok 发表于 2014-3-14 10:10
已在试了,初试一下就第一感觉
加强了3D优化一些基本画图,底栏改了很多..
显卡支持要更好的 ...
老大,我下载了破解文件,R7R9覆盖到哪个文件夹啊?能指点一二吗?先谢谢了。
发表于 2014-3-17 19:46:14 | 显示全部楼层
里面不有个安装说明吗?->>readme.txt
Autodesk AutoCAD 2015 [64bit] Pre-Release Incl Keygen- X-FORCE- [MUMBAI-TPB]
Install Notes:
1. Install AutoCAD 2015 - English [Install using AutoCAD_2015_English_Win_64bit_dlm.sfx.exe]
2. While Installing use the Serial as 066-66666666 and Product Key as 001G1
3. After Installation Donot Launch the program.
4. Browse to C:\Program Files\Common Files\Autodesk Shared\AdLM\  ;;;;R7R9覆盖到这个文件夹
4a. Rename the folder "R7" to "R7old" and "R9" to "R9old".
4b. Now Copy the folders "R7" and "R9" from "AdLM" folder to C:\Program Files\Common Files\Autodesk Shared\AdLM\
5. Run AutoCAD 2015.
6. Before clicking on Activate
  You have 2 options :
6a) Disable Your network Card or pull the network cable out or block with firewall
(this is just to disable online checks) it will tell you that an internet Connection is Required
simply click on close and click on activate again
6b) Click on Activate and it will do an online check, simply click
on close and click on activate again.
7. Select I have an activation code from Autodesk.
8. Run the Keygen [32 or 64 Bit] as Administrator.
9. Click on Mem Patch (you should see successfully patched).
10. Copy the Request code into the keygen and press generate.
11. Now copy the activation code back to the activation screen and click Next
, it should show License Active.
12. Enjoy...!!!
发表于 2014-3-17 19:47:45 | 显示全部楼层
发表于 2014-3-17 20:04:44 | 显示全部楼层
谢谢老大,我试试。
发表于 2014-3-17 20:05:36 | 显示全部楼层
Autodesk AutoCAD 2015 [64bit] Pre-Release Incl Keygen- X-FORC ...
谢了,这个说明文件我下载不了。
发表于 2014-3-17 22:18:02 | 显示全部楼层
激活了,呵呵,庆贺一下!
发表于 2014-3-17 22:29:20 | 显示全部楼层
没有建筑软件支持,纯CAD没法用。
GMT+8, 2026-1-15 11:38 , Processed in 0.188415 second(s), 17 queries , Gzip On.
