楼主: xskfq
[提问] 谁能看懂这段代码?
发表于 2014-3-25 13:57:22 | 显示全部楼层
xyp1964 发表于 2014-3-25 13:48
院长的代码就是厉害呀..学习了,我弯子绕大了...考虑还不周全....
发表于 2014-3-25 14:05:31 | 显示全部楼层
(defun c:tt ( / dn el i lst-co lst-dn n s1 ss)
  (setq i -1
        lst-dn '(25 32 40 50 65 70 80 100 150)
        lst-co '(7 4 150 5 32 32 1 6 2)
  (if (setq ss (ssget "x" '((0 . "TCH_PIPE"))))
    (while (setq s1 (ssname ss (setq i (1+ i))))
      (setq el (entget s1)
            dn (fix (cdr (assoc 140 el)))
      (if (setq n (member dn lst-dn))(entmod (append el (list (cons 62 (nth (- 9 (length n)) lst-co))))))
院长的代码改了下...应该变成通用版了...
改得好!  发表于 2014-3-25 18:20
发表于 2014-3-25 18:28:24 | 显示全部楼层
  (setq i -1
        lst-dn '(25 32 40 50 65 70 8 ...
  1. ;; (aaa lst-dn lst-co)
  2. ;; (aaa '(25 32 40 50 65 70 80 100 150) '(7 4 150 5 32 32 1 6 2))
  3. (defun aaa (lst-dn lst-co / i ss s1 dn n)
  4.   (setq i -1)
  5.   (if (setq ss (ssget "x" '((0 . "TCH_PIPE"))))
  6.     (while (setq s1 (ssname ss (setq i (1+ i))))
  7.       (setq dn (fix (xyp-DXF 140 s1)))
  8.       (if (setq n (member dn lst-dn))
  9.         (xyp-SubUpd s1 62 (nth (- 9 (length n)) lst-co))
  10.       )
  11.     )
  12.   )
  13.   (princ)
  14. )
 楼主| 发表于 2014-3-29 13:51:37 | 显示全部楼层
谢谢高手Q3热心相助~~ 也谢谢院长~。
GMT+8, 2025-12-17 01:50 , Processed in 0.207389 second(s), 19 queries , Gzip On.
