楼主: 那个猎人
[提问] 求大神帮忙解决相同矩形编号问题
发表于 2015-3-3 17:04:08 | 显示全部楼层
  1. (defun SstoEs(ss / a en lst)
  2.   (if ss(repeat(setq a(sslength ss))
  3.          (setq a(1- a)lst(cons(ssname ss a)lst))))
  4.   lst)
  5. (defun plinexy(e / p i)
  6.   (setq i -1)
  7.   (mapcar(function(lambda(x)(list(car x)(cadr x))))(reverse(repeat(fix(1+(vlax-curve-getEndParam e)))
  8.     (setq i(1+ i)p(cons(vlax-curve-getPointAtParam e i)p)))))
  9.   (if(equal(car p)(last p))(reverse(cdr(reverse p)))p)
  10.   )
  11. (defun ABCOfRectangle(e / pt a b);;矩形中心及长宽
  12.   (if(and(=(length(setq pt(plinexy e)))4)
  13.          (equal(setq a(distance(car pt)(cadr pt)))
  14.                (distance(last pt)(caddr pt))1e-6)
  15.          (equal(setq b(distance(cadr pt)(caddr pt)))
  16.                (distance(last pt)(car pt))1e-6)
  17.          (equal(distance(car pt)(caddr pt))
  18.                (distance(last pt)(cadr pt))1e-6))
  19.     (list(mapcar'(lambda(x)(* x 0.5))(mapcar'+(car pt)(caddr pt)))(vl-sort(mapcar'atof(mapcar'rtos(list a b)))'>))))
  20. (defun subtotals(lst m ns / myfun a b c);;对lst以子表第m项为关键字进行分类,ns为整数时记录第ns项、为表(2 3)记录表中指定的项、为空或者其它记录关键字以外所有项
  21.   (cond((=(type ns)'LIST)(defun myfun(x)(list(mapcar'(lambda(y)(nth y x))ns))))
  22.        ((=(type ns)'INT)(defun myfun(x)(list(nth ns x))))
  23.        (t(defun myfun(x)(list(vl-remove c x)))))
  24.   (foreach x lst
  25.     (setq a(if(setq c(nth m x)b(assoc c a))
  26.        (subst(append b(myfun x))b a)
  27.        (append a(list(append(list c)(myfun x))))))))
  28. (defun maketxt(argments / InsOrDel);;argments pt txt la style color h hz jz z ro) txt后边的图层,字体可省
  29.   (defun InsOrDel(lst pos mod / qlst a hlst);{在指定位置删除或插入元素mod为要插入的元素为空时删除第pos项}
  30.     (setq a -1)
  31.     (setq hlst(vl-member-if-not'(lambda(x)(setq a(1+ a))(if(= a pos) nil(setq qlst (cons x qlst))))lst))
  32.     (if mod(apply 'append (list (reverse(cons mod qlst)) hlst))
  33.       (apply 'append (list (reverse qlst)(cdr hlst)))))
  34.   (setq argments(if(or(/=(type(nth 2 argments))'str)(null(tblsearch"layer"(nth 2 argments))))
  35.                       (InsOrDel argments 2(getvar'clayer))argments)
  36.         argments(if(or(/=(type(nth 3 argments))'str)(null(tblsearch"style"(nth 3 argments))))
  37.                       (InsOrDel argments 3"Standard"))argments)
  38. (entmakex(mapcar'cons'(0 10 11 1 8 7 62 40 41 72 73 50)(append(list"TEXT"(car argments))argments))))
  39. (defun c:tt(/ ss i a)
  40. (if(setq ss(SstoEs(ssget'((0 . "*polyline")(90 . 4)(-4 . "<OR") (70 . 1)(70 . 129)(-4 . "OR>")))))
  41.    (foreach x(subtotals(vl-remove'nil(mapcar'ABcOfRectangle ss))1 0)
  42.      (setq i 0 a(strcat(rtos(caar x))"X"(rtos(cadar x))))
  43.      (foreach y(cdr x)
  44.        (maketxt(list y(strcat a"-"(itoa(setq i(1+ i))))1 1.5 1.0 1 2)))))
  45.   )
凑热闹
发表于 2015-3-3 17:27:48 | 显示全部楼层
都什么时候的帖子了 还挂着 未解决
发表于 2015-3-10 01:15:19 | 显示全部楼层
我只能观摩了
发表于 2016-7-15 20:18:19 | 显示全部楼层
下载啦。。。。。。。。。。。。。。。。。。。。。
发表于 2016-8-4 17:31:15 | 显示全部楼层
求一个自动编号闭合面的插件
发表于 2018-8-25 15:06:55 | 显示全部楼层
进来学习一下。
发表于 2018-8-25 22:35:26 | 显示全部楼层
下载学了!!!!!谢谢分享!!!!
发表于 2019-11-7 22:59:13 | 显示全部楼层
翻译下llsheng_73的回帖
;;选集转图元名列表
(defun SstoEs (ss / a en lst)
  (if ss
    (repeat (setq a (sslength ss))
      (setq a        (1- a)
                                lst        (cons (ssname ss a) lst)
  lst
;;多段线顶点列表
(defun plinexy (e / p i)
  (setq i -1)
  (mapcar (function (lambda (x) (list (car x) (cadr x))))
          (reverse ;;正的
                        (repeat (fix (1+ (vlax-curve-getEndParam e)))
                                (setq i (1+ i)
                                        p (cons (vlax-curve-getPointAtParam e i) p);;反的
  (if (equal (car p) (last p))
    (reverse (cdr (reverse p)));;如果闭合,则去掉最后一个点
    p
(defun ABCOfRectangle (e / pt a b)
  ;;矩形中心及长宽
  (if (and (= (length (setq pt (plinexy e))) 4)
                                (equal
                                        (setq a (distance (car pt) (cadr pt)));;AB
                                        (distance (last pt) (caddr pt));;DC
                                        1e-6
                                (equal
                                        (setq b (distance (cadr pt) (caddr pt)));;BC
                                        (distance (last pt) (car pt));;DA
                                        1e-6
                                (equal
                                        (distance (car pt) (caddr pt));;AC
                                        (distance (last pt) (cadr pt));;DB
                                        1e-6
      );;判断为矩形
    (list
                        (mapcar '(lambda (x) (* x 0.5))
                                (mapcar '+ (car pt) (caddr pt))
                        );;矩形中点
                        (vl-sort (mapcar 'atof (mapcar 'rtos (list a b))) '>);;矩形 '(W H)
    );;'(矩形中心点 (W H))
;;数据规整
;;对lst以子表第m项为关键字进行分类,ns为整数时记录第ns项、为表【如'(2 3)】记录表中指定的项(第2项,第3项)、为空或者其它,记录关键字以外所有项
(defun subtotals (lst m ns / myfun a b c)
  (cond
                ((= (type ns) 'LIST)
                        (defun myfun (x) (list (mapcar '(lambda (y) (nth y x)) ns)))
                ((= (type ns) 'INT) (defun myfun (x) (list (nth ns x))))
                (t (defun myfun (x) (list (vl-remove c x))))
  (foreach x lst
    (setq a (if        (setq c        (nth m x)
        b        (assoc c a)
        );;搜索主键中的数据
                                                        (subst (append b (myfun x)) b a);;主键相同,次键并入
                                                        (append a (list (append (list c) (myfun x))));;新建一个以关键字为主键,记录项为次键的新表,,比如以子表的第二项(W H),为主,然后以第一项的中心点为次键的新表,并合并
;;说实话这个函数有点炫技的意味
        ;;argments:(list pt txt la style color h hz jz z ro) ;;txt后边的图层,字体可省
    (setq a -1)
    (setq hlst (vl-member-if-not
        '(lambda (x)
        (setq a (1+ a))
        (if        (= a pos)
        nil
        lst
    (if        mod
      (apply 'append (list (reverse (cons mod qlst)) hlst))
      (apply 'append (list (reverse qlst) (cdr hlst)))
        (setq        argments
                (if (or (/= (type (nth 2 argments)) 'str)
                                        (null (tblsearch "layer" (nth 2 argments)))
                        (InsOrDel argments 2 (getvar 'clayer))
                        argments
                argments
                (if (or (/= (type (nth 3 argments)) 'str)
                                        (null (tblsearch "style" (nth 3 argments)))
                        (InsOrDel argments 3 "Standard")
                        argments
        (entmakex
                (mapcar 'cons
                        (append (list "TEXT" (car argments)) argments)
(defun c:tt (/ ss i a)
        (if (setq ss (SstoEs (ssget '((0 . "*polyline")
        (90 . 4)
        (-4 . "<OR")
        (70 . 1)
        (70 . 129)
        (-4 . "OR>")
                (foreach x (subtotals
        (vl-remove 'nil (mapcar 'ABcOfRectangle ss))
        1
        0
                                                         );;(((宽 高)(中心点 中心点 ...))((宽 高)(中心点 中心点 ...))((宽 高)(中心点 中心点 ...)))
                        (setq i 0
                                a (strcat (rtos (caar x)) "X" (rtos (cadar x)))
                        (foreach y (cdr x)
                                (maketxt
                                        (list y (strcat a "-" (itoa (setq i (1+ i)))) 1 1.5 1.0 1 2)
发表于 2023-3-3 20:07:53 | 显示全部楼层
可以相同规格尺寸,编号归类标同一个编号就好了,
GMT+8, 2026-1-15 17:25 , Processed in 0.184344 second(s), 19 queries , Gzip On.
